RTEMS 6.2-rc1
| #define | COMP_OUTPUTPOL_NONINVERTED ((uint32_t)0x00000000) |
| #define | COMP_OUTPUTPOL_INVERTED (COMP_CFGRx_POLARITY) |
| #define COMP_OUTPUTPOL_INVERTED (COMP_CFGRx_POLARITY) |
COMP output level is inverted (comparator output is low when the input plus is at a higher voltage than the input minus)
| #define COMP_OUTPUTPOL_NONINVERTED ((uint32_t)0x00000000) |
COMP output level is not inverted (comparator output is high when the input plus is at a higher voltage than the input minus)
