RTEMS 6.2-rc1
TEMPSENSOR - Tempsensor Register | |
| #define | ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_MASK (0x8000U) |
| #define | ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_SHIFT (15U) |
| #define | ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_MASK) |
| #define | ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_MASK (0x10000U) |
| #define | ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_SHIFT (16U) |
| #define | ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_MASK) |
TEMPSNS_OTP_TRIM_VALUE - TEMPSNS_OTP_TRIM_VALUE_REGISTER | |
| #define | ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_MASK (0x3FFC00U) |
| #define | ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_SHIFT (10U) |
| #define | ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_MASK) |
| #define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_BUSY_MASK) |
TEMPSNS_AI_BUSY - AI Busy monitor
| #define ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSENSOR_TEMPSNS_AI_TOGGLE_MASK) |
TEMPSNS_AI_TOGGLE - AI toggle
| #define ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_SHIFT)) & ANADIG_TEMPSENSOR_TEMPSNS_OTP_TRIM_VALUE_TEMPSNS_TEMP_VAL_MASK) |
TEMPSNS_TEMP_VAL - Temperature Value at 25C
