RTEMS 6.2-rc1
ARM PL011 Support Package. More...
| struct | arm_pl011_uart |
| struct | arm_pl011_context |
| bool | arm_pl011_probe (rtems_termios_device_context *base) |
| Initialize pl011 registers. | |
| void | arm_pl011_write_polled (rtems_termios_device_context *base, char c) |
| Write a char using polling mode. | |
| int | arm_pl011_read_polled (rtems_termios_device_context *base) |
| Read a char using polling mode. | |
| volatile arm_pl011_uart * | arm_pl011_get_regs (rtems_termios_device_context *base) |
| Get register base address. | |
| int | arm_pl011_compute_baudrate_params (uint32_t *ibrd, uint32_t *fbrd, const uint32_t baudrate, const uint32_t clock, const unsigned short max_error) |
| Compute baudrate params. | |
| const rtems_termios_device_handler | arm_pl011_fns |
| int arm_pl011_compute_baudrate_params | ( | uint32_t * | ibrd, |
| uint32_t * | fbrd, | ||
| const uint32_t | baudrate, | ||
| const uint32_t | clock, | ||
| const unsigned short | max_error | ||
| ibrd | The integer part of the baud rate divisor value. |
| fbrd | The fractional part of the baud rate divisor value. |
| baudrate | Termios device context. |
| clock | The UART reference clock frequency. |
| max_error | Maximum error. |
| 0 | Success. |
| 1 | The error is too large. |
| 2 | ibrd is invalid. |
| volatile arm_pl011_uart * arm_pl011_get_regs | ( | rtems_termios_device_context * | base | ) |
| base | Termios device context. |
| Register | base address. |
| bool arm_pl011_probe | ( | rtems_termios_device_context * | base | ) |
| true | Successfully initialized pl011 registers. |
| int arm_pl011_read_polled | ( | rtems_termios_device_context * | base | ) |
| Character | read. |
| -1 | rxfifo is empty. |
| void arm_pl011_write_polled | ( | rtems_termios_device_context * | base, |
| char | c | ||
| c | Character to be written. |
