RTEMS 6.2-rc1
#include "chip.h"Functions | |
| void | AFEC_Initialize (Afec *pAFE, uint32_t dwID) |
| Initialize the AFE controller. | |
| uint32_t | AFEC_SetClock (Afec *pAFE, uint32_t dwClk, uint32_t dwMck) |
| Set AFE clock. | |
| void | AFEC_SetTiming (Afec *pAFE, uint32_t dwStartup, uint32_t dwTracking, uint32_t dwSettling) |
| Set AFE timing. | |
| void | AFEC_SetTrigger (Afec *pAFE, uint32_t dwTrgSel) |
| Set AFE trigger. | |
| void | AFEC_SetSleepMode (Afec *pAFE, uint8_t bEnDis) |
| Enable/Disable sleep mode. | |
| void | AFEC_SetFastWakeup (Afec *pAFE, uint8_t bEnDis) |
| Enable/Disable fast wake up. | |
| void | AFEC_SetSequenceMode (Afec *pAFE, uint8_t bEnDis) |
| Enable/Disable sequence mode. | |
| void | AFEC_SetSequence (Afec *pAFE, uint32_t dwSEQ1, uint32_t dwSEQ2) |
| Set channel sequence. | |
| void | AFEC_SetSequenceByList (Afec *pAFE, uint8_t ucChList[], uint8_t ucNumCh) |
| Set channel sequence by given channel list. | |
| void | AFEC_SetAnalogChange (Afec *pAFE, uint8_t bEnDis) |
| Set analog change. IF enabled, it allows different analog settings for each channel, otherwise, DIFF0, GAIN0 and OFF0 are used for all channels. | |
| void | AFEC_SetTagEnable (Afec *pAFE, uint8_t bEnDis) |
| Set "TAG" mode, show channel number in last data or not. | |
| void | AFEC_SetCompareChannel (Afec *pAFE, uint32_t dwChannel) |
| Set compare channel. | |
| void | AFEC_SetCompareMode (Afec *pAFE, uint32_t dwMode) |
| Set compare mode. | |
| void | AFEC_SetComparisonWindow (Afec *pAFE, uint32_t dwHi_Lo) |
| Set comparison window. | |
| uint32_t | AFEC_GetConvertedData (Afec *pAFE, uint32_t dwChannel) |
| Return the Channel Converted Data. | |
| void | AFEC_SetStartupTime (Afec *pAFE, uint32_t dwUs) |
| void | AFEC_SetTrackingTime (Afec *pAFE, uint32_t dwNs) |
| void | AFEC_SetAnalogOffset (Afec *pAFE, uint32_t dwChannel, uint32_t aoffset) |
| Set analog offset to be used for channel CSEL. | |
| void | AFEC_SetAnalogControl (Afec *pAFE, uint32_t control) |
Implementation of Analog-to-Digital Converter (AFE).
| uint32_t AFEC_GetConvertedData | ( | Afec * | pAFE, |
| uint32_t | dwChannel | ||
| pAFE | Pointer to an AFE instance. |
| dwChannel | channel to get converted value |
| void AFEC_Initialize | ( | Afec * | pAFE, |
| uint32_t | dwID | ||
| dwID | AFE Index |
| void AFEC_SetAnalogChange | ( | Afec * | pAFE, |
| uint8_t | bEnDis | ||
| bEnDis | Enable/Disable. |
| void AFEC_SetAnalogControl | ( | Afec * | pAFE, |
| uint32_t | control | ||
| afec | Base address of the AFEC. |
| control | Analog control value. |
| void AFEC_SetAnalogOffset | ( | Afec * | pAFE, |
| uint32_t | dwChannel, | ||
| uint32_t | aoffset | ||
| dwChannel | AFEC channel number. |
| aoffset | Analog offset value. |
| uint32_t AFEC_SetClock | ( | Afec * | pAFE, |
| uint32_t | dwClk, | ||
| uint32_t | dwMck | ||
Set AFE clock.
| dwPres | prescale value |
| dwMck | Board MCK (Hz) |
| void AFEC_SetCompareChannel | ( | Afec * | pAFE, |
| dwChannel | channel number to be set,16 for all channels |
| void AFEC_SetCompareMode | ( | Afec * | pAFE, |
| uint32_t | dwMode | ||
Set compare mode.
| dwMode | compare mode |
| void AFEC_SetComparisonWindow | ( | Afec * | pAFE, |
| uint32_t | dwHi_Lo | ||
| dwHi_Lo | Comparison Window |
| void AFEC_SetFastWakeup | ( | Afec * | pAFE, |
| bEnDis | Enable/Disable fast wake up in sleep mode. |
| void AFEC_SetSequence | ( | Afec * | pAFE, |
| uint32_t | dwSEQ1, | ||
| uint32_t | dwSEQ2 | ||
| dwSEQ1 | Sequence 1 ~ 8 channel number. |
| dwSEQ2 | Sequence 9 ~ 16 channel number. |
| void AFEC_SetSequenceByList | ( | Afec * | pAFE, |
| uint8_t | ucChList[], | ||
| uint8_t | ucNumCh | ||
| ucChList | Channel list. |
| ucNumCh | Number of channels in list. |
| void AFEC_SetSequenceMode | ( | Afec * | pAFE, |
| bEnDis | Enable/Disable sequence mode. |
| void AFEC_SetSleepMode | ( | Afec * | pAFE, |
| bEnDis | Enable/Disable sleep mode. |
| void AFEC_SetStartupTime | ( | Afec * | pAFE, |
| uint32_t | dwUs | ||
Sets the AFE startup time.
| dwUs | Startup time in uS. |
| void AFEC_SetTagEnable | ( | Afec * | pAFE, |
| bEnDis | Enable/Disable TAG value. |
| void AFEC_SetTiming | ( | Afec * | pAFE, |
| uint32_t | dwStartup, | ||
| uint32_t | dwTracking, | ||
| uint32_t | dwSettling | ||
Set AFE timing.
| dwStartup | startup value |
| dwTracking | tracking value |
| dwSettling | settling value |
| void AFEC_SetTrackingTime | ( | Afec * | pAFE, |
| uint32_t | dwNs | ||
Set AFE tracking time
| dwNs | Tracking time in nS. |
| void AFEC_SetTrigger | ( | Afec * | pAFE, |
| uint32_t | dwTrgSel | ||
Set AFE trigger.
| dwTrgSel | Trigger selection |
