RTEMS 6.1-rc8
zynq-slcr.h File Reference
SLCR support. More...
#include <stdint.h>
void zynq_slcr_fpga_clk_rst_mask_set (uint32_t mask)
 Set the mask that allows the FPGA resets to be modified.
void zynq_slcr_fpga_clk_rst (uint32_t val)
 Control the FPGA reset values.
void zynq_slcr_level_shifter_enable (uint32_t val)
 Control the level shifters between the PS and PL.
SLCR support.
◆ zynq_slcr_fpga_clk_rst()
void zynq_slcr_fpga_clk_rst ( uint32_t  val)
Parameters
valBits 0 through 3 correspond to FPGA RST 0 through 3. A bit value of 1 asserts the reset.
◆ zynq_slcr_fpga_clk_rst_mask_set()
void zynq_slcr_fpga_clk_rst_mask_set ( uint32_t  mask)
Bit 0 corresponds to FPGA0_OUT_RST, and bit 3 to FPGA3_OUT_RST. Setting a bit in the mask to 1 allows calls to zynq_slcr_fpga_clk_rst to modify that reset. The default mask is 0xf.
◆ zynq_slcr_level_shifter_enable()
void zynq_slcr_level_shifter_enable ( uint32_t  val)
Parameters
valAcceptable values are ZYNQ_SLCR_LVL_SHFTR_EN_DISABLE, ZYNQ_SLCR_LVL_SHFTR_EN_PS_TO_PL, and ZYNQ_SLCR_LVL_SHFTR_EN_ALL.
