RTEMS 6.1-rc8
The union of well bias basic options, such as clock source, power source and so on. More...
#include <fsl_pmu.h>
Data Fields | |
| uint16_t | wellBiasData |
| struct { | |
| uint16_t enablePWellOnly: 1U | |
| uint16_t reserved1: 1U | |
| uint16_t biasAreaSize: 3U | |
| uint16_t disableAdaptiveFreq: 1U | |
| uint16_t wellBiasFreq: 3U | |
| uint16_t clkSource: 1U | |
| uint16_t freqReduction: 2U | |
| uint16_t enablePowerDownOption: 1U | |
| uint16_t reserved2: 1U | |
| uint16_t powerSource: 1U | |
| uint16_t reserved3: 1U | |
| } | wellBiasStruct |
| uint16_t _pmu_well_bias_option::biasAreaSize |
Select size of bias area, please refer to pmu_bias_area_size_t
| uint16_t _pmu_well_bias_option::clkSource |
Config the adaptive clock source, please pmu_adaptive_clock_source_t.
| uint16_t _pmu_well_bias_option::disableAdaptiveFreq |
Enable/Disable adaptive frequency.
| uint16_t _pmu_well_bias_option::enablePowerDownOption |
Enable/Disable pull down option.
| uint16_t _pmu_well_bias_option::enablePWellOnly |
Turn on both PWELL and NWELL, or only trun on PWELL.
| uint16_t _pmu_well_bias_option::freqReduction |
Config the percent of frequency reduction due to cap increment, please refer to pmu_freq_reduction_t.
| uint16_t _pmu_well_bias_option::powerSource |
Set power source, please refer to pmu_well_bias_power_source_t.
| uint16_t _pmu_well_bias_option::reserved1 |
Reserved.
| uint16_t _pmu_well_bias_option::reserved2 |
Reserved.
| uint16_t _pmu_well_bias_option::reserved3 |
Reserved.
| uint16_t _pmu_well_bias_option::wellBiasData |
well bias configuration data.
| uint16_t _pmu_well_bias_option::wellBiasFreq |
Set well bias typical frequency, please refer to pmu_well_bias_typical_freq_t.
