RTEMS 6.1-rc8
This header file provides interfaces and functions used to implement the TFTP file system. More...
#include <stdint.h>
#include <rtems/fs.h>
struct  tftp_options
 This structure represents TFTP options negotiated between client and server. More...
struct  tftp_net_config
 This structure represents configuration value used by the TFTP client. More...
#define TFTP_RFC1350_BLOCK_SIZE   512
 This block size meets RFC 1350 and avoids the sending of the blksize option to the TFTP server.
#define TFTP_RFC1350_WINDOW_SIZE   1
 This window size avoids the sending of the windowsize option to the TFTP server.
#define TFTP_DEFAULT_BLOCK_SIZE   1456
 This block size is suggested in RFC 2348 and is used as default if no different block size is provided.
#define TFTP_DEFAULT_WINDOW_SIZE   8
 This window size is suggested in RFC 2348 and is used as default if no different window size is provided.
typedef struct tftp_options tftp_options
typedef struct tftp_net_config tftp_net_config
int rtems_tftpfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Do not call directly, use mount().
void tftp_initialize_net_config (tftp_net_config *config)
 Set all members of a tftp_net_config structure to their default values.
int tftp_open (const char *hostname, const char *path, bool is_for_reading, const tftp_net_config *config, void **tftp_handle)
 Opens and starts a TFTP client session to read or write a single file.
ssize_t tftp_read (void *tftp_handle, void *buffer, size_t count)
 Read data from a TFTP server.
ssize_t tftp_write (void *tftp_handle, const void *buffer, size_t count)
 Write data to a TFTP server.
int tftp_close (void *tftp_handle)
 Close a TFTP client connection.
This file declares the public functions of the Trivial File Transfer Protocol (TFTP) file system.
