RTEMS 6.1-rc8
rtems_interrupt_server_config Struct Reference
This structure defines an interrupt server configuration. More...
#include <intr.h>
rtems_name name
 This member is the task name of the interrupt server.
rtems_task_priority priority
 This member is the initial task priority of the interrupt server.
void * storage_area
 This member is the task storage area of the interrupt server.
size_t storage_size
 This member is the task storage size of the interrupt server.
rtems_mode modes
 This member is the initial mode set of the interrupt server.
rtems_attribute attributes
 This member is the attribute set of the interrupt server.
void(* destroy )(rtems_interrupt_server_control *)
 This member is an optional handler to destroy the interrupt server control handed over to rtems_interrupt_server_create().
Notes
See also rtems_interrupt_server_create().
Constraints
The following constraints apply to this structure:
  • Members of the type shall not be accessed directly by the application.
Field Documentation
◆ destroy
void(* rtems_interrupt_server_config::destroy) (rtems_interrupt_server_control *)
The destroy handler is optional and may be NULL. If the destroy handler is present, it is called from within the context of the interrupt server to be deleted, see also rtems_interrupt_server_delete().
◆ storage_area
void* rtems_interrupt_server_config::storage_area
It shall be NULL for interrupt servers created by rtems_interrupt_server_create().
◆ storage_size
size_t rtems_interrupt_server_config::storage_size
For interrupt servers created by rtems_interrupt_server_create() this is the task stack size.
