RTEMS 6.1-rc8
This structure contains the device driver entries. More...
#include <io.h>
Data Fields | |
| rtems_device_driver_entry | initialization_entry |
| This member is the device driver initialization entry. | |
| rtems_device_driver_entry | open_entry |
| This member is the device driver open entry. | |
| rtems_device_driver_entry | close_entry |
| This member is the device driver close entry. | |
| rtems_device_driver_entry | read_entry |
| This member is the device driver read entry. | |
| rtems_device_driver_entry | write_entry |
| This member is the device driver write entry. | |
| rtems_device_driver_entry | control_entry |
| This member is the device driver control entry. | |
This structure is used to register a device driver via rtems_io_register_driver().
| rtems_device_driver_entry rtems_driver_address_table::close_entry |
This entry is called by rtems_io_close().
| rtems_device_driver_entry rtems_driver_address_table::control_entry |
This entry is called by rtems_io_control().
| rtems_device_driver_entry rtems_driver_address_table::initialization_entry |
This entry is called by rtems_io_initialize().
| rtems_device_driver_entry rtems_driver_address_table::open_entry |
This entry is called by rtems_io_open().
| rtems_device_driver_entry rtems_driver_address_table::read_entry |
This entry is called by rtems_io_read().
| rtems_device_driver_entry rtems_driver_address_table::write_entry |
This entry is called by rtems_io_write().
