RTEMS 6.1-rc8
Quad Timer config structure. More...
#include <fsl_qtmr.h>
Data Fields | |
| qtmr_primary_count_source_t | primarySource |
| qtmr_input_source_t | secondarySource |
| bool | enableMasterMode |
| bool | enableExternalForce |
| uint8_t | faultFilterCount |
| uint8_t | faultFilterPeriod |
| qtmr_debug_action_t | debugMode |
This structure holds the configuration settings for the Quad Timer peripheral. To initialize this structure to reasonable defaults, call the QTMR_GetDefaultConfig() function and pass a pointer to your config structure instance.
The config struct can be made const so it resides in flash
| qtmr_debug_action_t _qtmr_config::debugMode |
Operation in Debug mode
| bool _qtmr_config::enableExternalForce |
true: Compare from another counter force state of OFLAG signal false: OFLAG controlled by local counter
| bool _qtmr_config::enableMasterMode |
true: Broadcast compare function output to other counters; false no broadcast
| uint8_t _qtmr_config::faultFilterCount |
Fault filter count
| uint8_t _qtmr_config::faultFilterPeriod |
Fault filter period;value of 0 will bypass the filter
| qtmr_primary_count_source_t _qtmr_config::primarySource |
Specify the primary count source
| qtmr_input_source_t _qtmr_config::secondarySource |
Specify the secondary count source
