RTEMS 6.1-rc8
Structure is used to hold parameters to configure the capture capability of a signal pin. More...
#include <fsl_pwm.h>
Data Fields | |
| bool | captureInputSel |
| uint8_t | edgeCompareValue |
| pwm_input_capture_edge_t | edge0 |
| pwm_input_capture_edge_t | edge1 |
| bool | enableOneShotCapture |
| uint8_t | fifoWatermark |
| bool _pwm_input_capture_param::captureInputSel |
true: Use the edge counter signal as source false: Use the raw input signal from the pin as source
| pwm_input_capture_edge_t _pwm_input_capture_param::edge0 |
Specify which edge causes a capture for input circuitry 0
| pwm_input_capture_edge_t _pwm_input_capture_param::edge1 |
Specify which edge causes a capture for input circuitry 1
| uint8_t _pwm_input_capture_param::edgeCompareValue |
Compare value, used only if edge counter is used as source
| bool _pwm_input_capture_param::enableOneShotCapture |
true: Use one-shot capture mode; false: Use free-running capture mode
| uint8_t _pwm_input_capture_param::fifoWatermark |
Watermark level for capture FIFO. The capture flags in the status register will set if the word count in the FIFO is greater than this watermark level
