RTEMS 6.1-rc8
Serial NOR configuration block. More...
#include <fsl_romapi.h>
Data Fields | |
| flexspi_mem_config_t | memConfig |
| Common memory configuration info via FlexSPI. | |
| uint32_t | pageSize |
| Page size of Serial NOR. | |
| uint32_t | sectorSize |
| Sector size of Serial NOR. | |
| uint8_t | ipcmdSerialClkFreq |
| Clock frequency for IP command. | |
| uint8_t | isUniformBlockSize |
| Sector/Block size is the same. | |
| uint8_t | isDataOrderSwapped |
| The data order is swapped in OPI DDR mode (only i.MXRT11*) | |
| uint8_t | reserved0 |
| Reserved for future use. | |
| uint8_t | serialNorType |
| Serial NOR Flash type: 0/1/2/3. | |
| uint8_t | needExitNoCmdMode |
| Need to exit NoCmd mode before other IP command. | |
| uint8_t | halfClkForNonReadCmd |
| Half the Serial Clock for non-read command: true/false. | |
| uint8_t | needRestoreNoCmdMode |
| Need to Restore NoCmd mode after IP commmand execution. | |
| uint32_t | blockSize |
| Block size. | |
| uint32_t | FlashStateCtx |
| Flash State Context after being configured (only i.MXRT11*) | |
| uint32_t | reserve2 [10] |
