RTEMS 6.1-rc8
Configuration for the loop control. More...
#include <fsl_dcdc.h>
Data Fields | |
| bool | enableCommonHysteresis |
| bool | enableCommonThresholdDetection |
| bool | enableDifferentialHysteresis |
| bool | enableDifferentialThresholdDetection |
| bool | enableInvertHysteresisSign |
| bool | enableRCThresholdDetection |
| uint32_t | enableRCScaleCircuit |
| uint32_t | complementFeedForwardStep |
| uint32_t | controlParameterMagnitude |
| uint32_t | integralProportionalRatio |
| uint32_t _dcdc_loop_control_config::controlParameterMagnitude |
Available range is 0~15. Magnitude of proportional control parameter in the switching DC-DC converter control loop.
| bool _dcdc_loop_control_config::enableDifferentialHysteresis |
Enable hysteresis in switching converter differential mode analog comparators. This feature will improve transient supply ripple and efficiency.
| bool _dcdc_loop_control_config::enableDifferentialThresholdDetection |
Increase the threshold detection for differential mode analog comparators.
| uint32_t _dcdc_loop_control_config::integralProportionalRatio |
Available range is 0~3.Ratio of integral control parameter to proportional control parameter in the switching DC-DC converter, and can be used to optimize efficiency and loop response.
