RTEMS 6.1-rc8
_asrc_channel_pair_config Struct Reference
asrc channel pair configuation More...
#include <fsl_asrc.h>
asrc_audio_channel_t audioDataChannels
asrc_clock_source_t inClockSource
uint32_t inSourceClock_Hz
asrc_clock_source_t outClockSource
uint32_t outSourceClock_Hz
asrc_ratio_t sampleRateRatio
asrc_data_width_t inDataWidth
asrc_data_align_t inDataAlign
asrc_data_width_t outDataWidth
asrc_data_align_t outDataAlign
asrc_sign_extension_t outSignExtension
uint8_t outFifoThreshold
uint8_t inFifoThreshold
bool bufStallWhenFifoEmptyFull
Field Documentation
◆ audioDataChannels
asrc_audio_channel_t _asrc_channel_pair_config::audioDataChannels
audio data channel numbers
◆ bufStallWhenFifoEmptyFull
bool _asrc_channel_pair_config::bufStallWhenFifoEmptyFull
stall Pair A conversion in case of Buffer near empty full condition
◆ inClockSource
asrc_clock_source_t _asrc_channel_pair_config::inClockSource
input clock source, reference the clock source definition in SOC header file
◆ inDataAlign
asrc_data_align_t _asrc_channel_pair_config::inDataAlign
input data alignment
◆ inDataWidth
asrc_data_width_t _asrc_channel_pair_config::inDataWidth
input data width
◆ inFifoThreshold
uint8_t _asrc_channel_pair_config::inFifoThreshold
input fifo threshold
◆ inSourceClock_Hz
uint32_t _asrc_channel_pair_config::inSourceClock_Hz
input source clock frequency
◆ outClockSource
asrc_clock_source_t _asrc_channel_pair_config::outClockSource
output clock source, reference the clock source definition in SOC header file
◆ outDataAlign
asrc_data_align_t _asrc_channel_pair_config::outDataAlign
output data alignment
◆ outDataWidth
asrc_data_width_t _asrc_channel_pair_config::outDataWidth
output data width
◆ outFifoThreshold
uint8_t _asrc_channel_pair_config::outFifoThreshold
output fifo threshold
◆ outSignExtension
asrc_sign_extension_t _asrc_channel_pair_config::outSignExtension
output extension
◆ outSourceClock_Hz
uint32_t _asrc_channel_pair_config::outSourceClock_Hz
output source clock frequency
◆ sampleRateRatio
asrc_ratio_t _asrc_channel_pair_config::sampleRateRatio
sample rate ratio type
