RTEMS 6.1-rc8
Test context for spec:/score/sched/smp/edf/req/set-affinity test case. More...
Data Fields | |
| TQContext | tq_ctx |
| This member contains the thread queue test context. | |
| cpu_set_t | task_affinity_before |
| This member specifies the task affinity before changing the affinity. | |
| cpu_set_t | task_affinity_after |
| This member specifies the task affinity after changing the affinity. | |
| rtems_task_priority | task_priority |
| This member specifies the priority of the task. | |
| bool | task_ready |
| If this member is true, then the task state shall be ready. | |
| bool | task_sticky |
| If this member is true, then the task shall have obtained a sticky mutex. | |
| bool | task_pinned |
| If this member is true, then the task shall be pinned. | |
| rtems_task_priority | alpha_priority |
| This member specifies the priority of the alpha task. | |
| cpu_set_t | alpha_affinity |
| This member specifies the affinity of the alpha task. | |
| bool | alpha_idle |
| If this member is true, then an idle task shall execute on behalf of the alpha task. | |
| rtems_task_priority | beta_priority |
| This member specifies the priority of the beta task. | |
| cpu_set_t | beta_affinity |
| This member specifies the affinity of the beta task. | |
| bool | beta_idle |
| If this member is true, then an idle task shall execute on behalf of the beta task. | |
| struct { | |
| size_t pcs [12] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| ScoreSchedSmpEdfReqSetAffinity_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
