RTEMS 6.1-rc8
Test context for spec:/rtems/timer/req/create test case. More...
void * seized_objects
 This member is used by the T_seize_objects() and T_surrender_objects() support functions.
rtems_id id_value
 This member may contain the object identifier returned by rtems_timer_create().
rtems_name name
 This member specifies the name parameter for the action.
rtems_idid
 This member specifies the id parameter for the action.
rtems_status_code status
 This member contains the return status of the action.
struct {
   size_t   pcs [3]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTimerReqCreate_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
