RTEMS 6.1-rc8
Test context for spec:/rtems/signal/val/signal-constant test case. More...
rtems_signal_set signal_set
 This member contains the caught signal set.
 This member contains a copy of the corresponding RtemsSignalValSignalConstant_Run() parameter.
int number
