RTEMS 6.1-rc8
Test context for spec:/rtems/signal/req/send test case. More...
Data Fields | |
| rtems_id | runner_id |
| rtems_id | worker_id |
| rtems_asr_entry | handler |
| size_t | nested |
| size_t | handler_calls |
| size_t | calls_after_send |
| size_t | calls_after_dispatch |
| size_t | calls_after_enable |
| rtems_signal_set | processed_signal_sets [2] |
| uintptr_t | stack_pointers [2] |
| rtems_mode | mode |
| rtems_status_code | status |
| rtems_id | id |
| rtems_signal_set | signal_set |
| struct { | |
| size_t pcs [5] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSignalReqSend_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
