RTEMS 6.1-rc8
Test context for spec:/rtems/sem/req/delete test case. More...
Data Fields | |
| rtems_id | worker_id [2] |
| This member contains the worker task identifiers. | |
| uint32_t | counter |
| This member contains the worker activity counter. | |
| uint32_t | worker_counter [2] |
| This member contains the worker activity counter of a specific worker. | |
| rtems_status_code | obtain_status |
| This member specifies the expected rtems_semaphore_obtain() status. | |
| uint32_t | count |
| This member specifies if the initial count of the semaphore. | |
| rtems_attribute | attribute_set |
| This member specifies if the attribute set of the semaphore. | |
| rtems_id | semaphore_id |
| This member contains the semaphore identifier. | |
| bool | valid_id |
If this member is true, then the name parameter shall be valid, otherwise it should be NULL. | |
| bool | blocked |
| If this member is true, then tasks shall be blocked on the semaphore, otherwise no tasks shall be blocked on the semaphore. | |
| rtems_id | id |
This member specifies the name parameter for the rtems_semaphore_delete() call. | |
| rtems_status_code | delete_status |
| This member specifies the expected rtems_semaphore_delete() status. | |
| struct { | |
| size_t pcs [3] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSemReqDelete_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
