RTEMS 6.1-rc8
Test context for spec:/rtems/scheduler/req/add-processor test case. More...
Data Fields | |
| rtems_id | scheduler_id |
| This member specifies the scheduler used to add the processor. | |
| rtems_id | scheduler_a_id |
| This member contains the identifier of scheduler A. | |
| rtems_id | scheduler_b_id |
| This member contains the identifier of scheduler B. | |
| rtems_id | scheduler_c_id |
| This member contains the identifier of scheduler C. | |
| Per_CPU_Control * | cpu |
| This member references the processor control of the processor to add. | |
| bool | online |
| This member contains the online status of the processor to add before the rtems_scheduler_add_processor() call is prepared. | |
| bool | add_cpu_to_scheduler_b |
| If this member is true, then the processor should be added to the scheduler B during cleanup. | |
| T_scheduler_log_2 | scheduler_log |
| This member provides the scheduler operation records. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_scheduler_add_processor() call. | |
| rtems_id | id |
This member specifies if the scheduler_id parameter value. | |
| uint32_t | cpu_index |
This member specifies if the cpu_index parameter value. | |
| struct { | |
| size_t pci [4] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [4] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsSchedulerReqAddProcessor_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
