RTEMS 6.1-rc8
Test context for spec:/rtems/io/req/getchark test case. More...
Data Fields | |
| size_t | input_count |
| This member contains the character input count. | |
| BSP_polling_getchar_function_type | poll_char |
| This member specifies the value for BSP_poll_char. | |
| int | result |
| This member contains the return value of the getchark() call. | |
| struct { | |
| size_t pcs [1] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsIoReqGetchark_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
