RTEMS 6.1-rc8
Test context for spec:/rtems/intr/req/raise-on test case. More...
Data Fields | |
| volatile uint32_t | interrupt_count |
| This member contains the count of serviced interrupts. | |
| bool | do_clear |
| If this member is true, then the interrupt shall be cleared. | |
| rtems_vector_number | vector |
| This member contains the current vector number. | |
| rtems_vector_number | some_vector |
| This member contains some valid vector number. | |
| bool | valid_vector |
If this member is true, then the vector parameter shall be valid. | |
| uint32_t | cpu_index |
This member specifies the cpu_index parameter. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_interrupt_raise_on() call. | |
| struct { | |
| size_t pci [3] | |
| This member defines the pre-condition indices for the next action. | |
| size_t pcs [3] | |
| This member defines the pre-condition states for the next action. | |
| bool in_action_loop | |
| If this member is true, then the test action loop is executed. | |
| size_t index | |
| This member contains the next transition map index. | |
| RtemsIntrReqRaiseOn_Entry entry | |
| This member contains the current transition map entry. | |
| bool skip | |
| If this member is true, then the current transition variant should be skipped. | |
| } | Map |
