RTEMS 6.1-rc8
Test context for spec:/rtems/intr/req/get-attributes test case. More...
rtems_interrupt_attributes attributes_obj
 This member provides the rtems_interrupt_attributes object.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
rtems_interrupt_attributesattributes
 This member specifies if the attributes parameter value.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_get_attributes() call.
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsIntrReqGetAttributes_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
