RTEMS 6.1-rc8
This header file provides the implementation interfaces of the Timer Manager. More...
#include <rtems/rtems/timerdata.h>#include <rtems/score/objectimpl.h>#include <rtems/score/thread.h>#include <rtems/score/watchdogimpl.h>Go to the source code of this file.
| struct | Timer_server_Control |
Typedefs | |
| typedef struct Timer_server_Control | Timer_server_Control |
| rtems_status_code | _Timer_Fire (rtems_id id, rtems_interval interval, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor) |
| rtems_status_code | _Timer_Fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor) |
| rtems_status_code | _Timer_Fire_when (rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor) |
| void | _Timer_Cancel (Per_CPU_Control *cpu, Timer_Control *the_timer) |
| void | _Timer_Routine_adaptor (Watchdog_Control *the_watchdog) |
| void | _Timer_server_Routine_adaptor (Watchdog_Control *the_watchdog) |
| Timer_server_Control *volatile | _Timer_server |
| Pointer to default timer server control block. | |
