RTEMS 6.1-rc8
This header file defines the L2CACHE register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | l2cache |
| This structure defines the L2CACHE register block memory map. More... | |
| #define | L2CACHE_L2CC_EN 0x80000000U |
| #define | L2CACHE_L2CC_EDAC 0x40000000U |
| #define | L2CACHE_L2CC_REPL_SHIFT 28 |
| #define | L2CACHE_L2CC_REPL_MASK 0x30000000U |
| #define | L2CACHE_L2CC_REPL_GET(_reg) |
| #define | L2CACHE_L2CC_REPL_SET(_reg, _val) |
| #define | L2CACHE_L2CC_REPL(_val) |
| #define | L2CACHE_L2CC_BBS_SHIFT 16 |
| #define | L2CACHE_L2CC_BBS_MASK 0x70000U |
| #define | L2CACHE_L2CC_BBS_GET(_reg) |
| #define | L2CACHE_L2CC_BBS_SET(_reg, _val) |
| #define | L2CACHE_L2CC_BBS(_val) |
| #define | L2CACHE_L2CC_INDEX_WAY_SHIFT 12 |
| #define | L2CACHE_L2CC_INDEX_WAY_MASK 0xf000U |
| #define | L2CACHE_L2CC_INDEX_WAY_GET(_reg) |
| #define | L2CACHE_L2CC_INDEX_WAY_SET(_reg, _val) |
| #define | L2CACHE_L2CC_INDEX_WAY(_val) |
| #define | L2CACHE_L2CC_LOCK_SHIFT 8 |
| #define | L2CACHE_L2CC_LOCK_MASK 0xf00U |
| #define | L2CACHE_L2CC_LOCK_GET(_reg) |
| #define | L2CACHE_L2CC_LOCK_SET(_reg, _val) |
| #define | L2CACHE_L2CC_LOCK(_val) |
| #define | L2CACHE_L2CC_HPRHB 0x20U |
| #define | L2CACHE_L2CC_HPB 0x10U |
| #define | L2CACHE_L2CC_UC 0x8U |
| #define | L2CACHE_L2CC_HC 0x4U |
| #define | L2CACHE_L2CC_WP 0x2U |
| #define | L2CACHE_L2CC_HP 0x1U |
| #define | L2CACHE_L2CS_LS 0x1000000U |
| #define | L2CACHE_L2CS_AT 0x800000U |
| #define | L2CACHE_L2CS_MP 0x400000U |
| #define | L2CACHE_L2CS_MTRR_SHIFT 16 |
| #define | L2CACHE_L2CS_MTRR_MASK 0x3f0000U |
| #define | L2CACHE_L2CS_MTRR_GET(_reg) |
| #define | L2CACHE_L2CS_MTRR_SET(_reg, _val) |
| #define | L2CACHE_L2CS_MTRR(_val) |
| #define | L2CACHE_L2CS_BBUS_W_SHIFT 13 |
| #define | L2CACHE_L2CS_BBUS_W_MASK 0xe000U |
| #define | L2CACHE_L2CS_BBUS_W_GET(_reg) |
| #define | L2CACHE_L2CS_BBUS_W_SET(_reg, _val) |
| #define | L2CACHE_L2CS_BBUS_W(_val) |
| #define | L2CACHE_L2CS_WAY_SIZE_SHIFT 2 |
| #define | L2CACHE_L2CS_WAY_SIZE_MASK 0x1ffcU |
| #define | L2CACHE_L2CS_WAY_SIZE_GET(_reg) |
| #define | L2CACHE_L2CS_WAY_SIZE_SET(_reg, _val) |
| #define | L2CACHE_L2CS_WAY_SIZE(_val) |
| #define | L2CACHE_L2CS_WAY_SHIFT 0 |
| #define | L2CACHE_L2CS_WAY_MASK 0x3U |
| #define | L2CACHE_L2CS_WAY_GET(_reg) |
| #define | L2CACHE_L2CS_WAY_SET(_reg, _val) |
| #define | L2CACHE_L2CS_WAY(_val) |
| #define | L2CACHE_L2CFMA_ADDR_SHIFT 5 |
| #define | L2CACHE_L2CFMA_ADDR_MASK 0xffffffe0U |
| #define | L2CACHE_L2CFMA_ADDR_GET(_reg) |
| #define | L2CACHE_L2CFMA_ADDR_SET(_reg, _val) |
| #define | L2CACHE_L2CFMA_ADDR(_val) |
| #define | L2CACHE_L2CFMA_DI 0x8U |
| #define | L2CACHE_L2CFMA_FMODE_SHIFT 0 |
| #define | L2CACHE_L2CFMA_FMODE_MASK 0x7U |
| #define | L2CACHE_L2CFMA_FMODE_GET(_reg) |
| #define | L2CACHE_L2CFMA_FMODE_SET(_reg, _val) |
| #define | L2CACHE_L2CFMA_FMODE(_val) |
| #define | L2CACHE_L2CFSI_INDEX_SHIFT 16 |
| #define | L2CACHE_L2CFSI_INDEX_MASK 0xffff0000U |
| #define | L2CACHE_L2CFSI_INDEX_GET(_reg) |
| #define | L2CACHE_L2CFSI_INDEX_SET(_reg, _val) |
| #define | L2CACHE_L2CFSI_INDEX(_val) |
| #define | L2CACHE_L2CFSI_TAG_SHIFT 10 |
| #define | L2CACHE_L2CFSI_TAG_MASK 0xfffffc00U |
| #define | L2CACHE_L2CFSI_TAG_GET(_reg) |
| #define | L2CACHE_L2CFSI_TAG_SET(_reg, _val) |
| #define | L2CACHE_L2CFSI_TAG(_val) |
| #define | L2CACHE_L2CFSI_FL 0x200U |
| #define | L2CACHE_L2CFSI_VB 0x100U |
| #define | L2CACHE_L2CFSI_DB 0x80U |
| #define | L2CACHE_L2CFSI_WAY_SHIFT 4 |
| #define | L2CACHE_L2CFSI_WAY_MASK 0x30U |
| #define | L2CACHE_L2CFSI_WAY_GET(_reg) |
| #define | L2CACHE_L2CFSI_WAY_SET(_reg, _val) |
| #define | L2CACHE_L2CFSI_WAY(_val) |
| #define | L2CACHE_L2CFSI_DI 0x8U |
| #define | L2CACHE_L2CFSI_WF 0x4U |
| #define | L2CACHE_L2CFSI_FMODE_SHIFT 0 |
| #define | L2CACHE_L2CFSI_FMODE_MASK 0x3U |
| #define | L2CACHE_L2CFSI_FMODE_GET(_reg) |
| #define | L2CACHE_L2CFSI_FMODE_SET(_reg, _val) |
| #define | L2CACHE_L2CFSI_FMODE(_val) |
| #define | L2CACHE_L2CERR_AHB_MASTER_INDEX_SHIFT 28 |
| #define | L2CACHE_L2CERR_AHB_MASTER_INDEX_MASK 0xf0000000U |
| #define | L2CACHE_L2CERR_AHB_MASTER_INDEX_GET(_reg) |
| #define | L2CACHE_L2CERR_AHB_MASTER_INDEX_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_AHB_MASTER_INDEX(_val) |
| #define | L2CACHE_L2CERR_SCRUB 0x8000000U |
| #define | L2CACHE_L2CERR_TYPE_SHIFT 24 |
| #define | L2CACHE_L2CERR_TYPE_MASK 0x7000000U |
| #define | L2CACHE_L2CERR_TYPE_GET(_reg) |
| #define | L2CACHE_L2CERR_TYPE_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_TYPE(_val) |
| #define | L2CACHE_L2CERR_TAG_DATA 0x800000U |
| #define | L2CACHE_L2CERR_COR_UCOR 0x400000U |
| #define | L2CACHE_L2CERR_MULTI 0x200000U |
| #define | L2CACHE_L2CERR_VALID 0x100000U |
| #define | L2CACHE_L2CERR_DISERESP 0x80000U |
| #define | L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_SHIFT 16 |
| #define | L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_MASK 0x70000U |
| #define | L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_GET(_reg) |
| #define | L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_CORRECTABLE_ERROR_COUNTER(_val) |
| #define | L2CACHE_L2CERR_IRQ_PENDING_SHIFT 12 |
| #define | L2CACHE_L2CERR_IRQ_PENDING_MASK 0xf000U |
| #define | L2CACHE_L2CERR_IRQ_PENDING_GET(_reg) |
| #define | L2CACHE_L2CERR_IRQ_PENDING_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_IRQ_PENDING(_val) |
| #define | L2CACHE_L2CERR_IRQ_MASK_SHIFT 8 |
| #define | L2CACHE_L2CERR_IRQ_MASK_MASK 0xf00U |
| #define | L2CACHE_L2CERR_IRQ_MASK_GET(_reg) |
| #define | L2CACHE_L2CERR_IRQ_MASK_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_IRQ_MASK(_val) |
| #define | L2CACHE_L2CERR_SELECT_CB_SHIFT 6 |
| #define | L2CACHE_L2CERR_SELECT_CB_MASK 0xc0U |
| #define | L2CACHE_L2CERR_SELECT_CB_GET(_reg) |
| #define | L2CACHE_L2CERR_SELECT_CB_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_SELECT_CB(_val) |
| #define | L2CACHE_L2CERR_SELECT_TCB_SHIFT 4 |
| #define | L2CACHE_L2CERR_SELECT_TCB_MASK 0x30U |
| #define | L2CACHE_L2CERR_SELECT_TCB_GET(_reg) |
| #define | L2CACHE_L2CERR_SELECT_TCB_SET(_reg, _val) |
| #define | L2CACHE_L2CERR_SELECT_TCB(_val) |
| #define | L2CACHE_L2CERR_XCB 0x8U |
| #define | L2CACHE_L2CERR_RCB 0x4U |
| #define | L2CACHE_L2CERR_COMP 0x2U |
| #define | L2CACHE_L2CERR_RST 0x1U |
| #define | L2CACHE_L2CERRA_EADDR_SHIFT 0 |
| #define | L2CACHE_L2CERRA_EADDR_MASK 0xffffffffU |
| #define | L2CACHE_L2CERRA_EADDR_GET(_reg) |
| #define | L2CACHE_L2CERRA_EADDR_SET(_reg, _val) |
| #define | L2CACHE_L2CERRA_EADDR(_val) |
| #define | L2CACHE_L2CTCB_TCB_SHIFT 0 |
| #define | L2CACHE_L2CTCB_TCB_MASK 0x7fU |
| #define | L2CACHE_L2CTCB_TCB_GET(_reg) |
| #define | L2CACHE_L2CTCB_TCB_SET(_reg, _val) |
| #define | L2CACHE_L2CTCB_TCB(_val) |
| #define | L2CACHE_L2CCB_CB_SHIFT 0 |
| #define | L2CACHE_L2CCB_CB_MASK 0xfffffffU |
| #define | L2CACHE_L2CCB_CB_GET(_reg) |
| #define | L2CACHE_L2CCB_CB_SET(_reg, _val) |
| #define | L2CACHE_L2CCB_CB(_val) |
| #define | L2CACHE_L2CSCRUB_INDEX_SHIFT 16 |
| #define | L2CACHE_L2CSCRUB_INDEX_MASK 0xffff0000U |
| #define | L2CACHE_L2CSCRUB_INDEX_GET(_reg) |
| #define | L2CACHE_L2CSCRUB_INDEX_SET(_reg, _val) |
| #define | L2CACHE_L2CSCRUB_INDEX(_val) |
| #define | L2CACHE_L2CSCRUB_WAY_SHIFT 2 |
| #define | L2CACHE_L2CSCRUB_WAY_MASK 0xcU |
| #define | L2CACHE_L2CSCRUB_WAY_GET(_reg) |
| #define | L2CACHE_L2CSCRUB_WAY_SET(_reg, _val) |
| #define | L2CACHE_L2CSCRUB_WAY(_val) |
| #define | L2CACHE_L2CSCRUB_PEN 0x2U |
| #define | L2CACHE_L2CSCRUB_EN 0x1U |
| #define | L2CACHE_L2CSDEL_DEL_SHIFT 0 |
| #define | L2CACHE_L2CSDEL_DEL_MASK 0xffffU |
| #define | L2CACHE_L2CSDEL_DEL_GET(_reg) |
| #define | L2CACHE_L2CSDEL_DEL_SET(_reg, _val) |
| #define | L2CACHE_L2CSDEL_DEL(_val) |
| #define | L2CACHE_L2CEINJ_ADDR_SHIFT 2 |
| #define | L2CACHE_L2CEINJ_ADDR_MASK 0xfffffffcU |
| #define | L2CACHE_L2CEINJ_ADDR_GET(_reg) |
| #define | L2CACHE_L2CEINJ_ADDR_SET(_reg, _val) |
| #define | L2CACHE_L2CEINJ_ADDR(_val) |
| #define | L2CACHE_L2CEINJ_INJ 0x1U |
| #define | L2CACHE_L2CACCC_DSC 0x4000U |
| #define | L2CACHE_L2CACCC_SH 0x2000U |
| #define | L2CACHE_L2CACCC_SPLITQ 0x400U |
| #define | L2CACHE_L2CACCC_NHM 0x200U |
| #define | L2CACHE_L2CACCC_BERR 0x100U |
| #define | L2CACHE_L2CACCC_OAPM 0x80U |
| #define | L2CACHE_L2CACCC_FLINE 0x40U |
| #define | L2CACHE_L2CACCC_DBPF 0x20U |
| #define | L2CACHE_L2CACCC_128WF 0x10U |
| #define | L2CACHE_L2CACCC_DBPWS 0x4U |
| #define | L2CACHE_L2CACCC_SPLIT 0x2U |
| #define | L2CACHE_L2CEINJCFG_EDI 0x400U |
| #define | L2CACHE_L2CEINJCFG_TER 0x200U |
| #define | L2CACHE_L2CEINJCFG_IMD 0x100U |
| #define | L2CACHE_L2CMTRR_ADDR_SHIFT 18 |
| #define | L2CACHE_L2CMTRR_ADDR_MASK 0xfffc0000U |
| #define | L2CACHE_L2CMTRR_ADDR_GET(_reg) |
| #define | L2CACHE_L2CMTRR_ADDR_SET(_reg, _val) |
| #define | L2CACHE_L2CMTRR_ADDR(_val) |
| #define | L2CACHE_L2CMTRR_ACC_SHIFT 16 |
| #define | L2CACHE_L2CMTRR_ACC_MASK 0x30000U |
| #define | L2CACHE_L2CMTRR_ACC_GET(_reg) |
| #define | L2CACHE_L2CMTRR_ACC_SET(_reg, _val) |
| #define | L2CACHE_L2CMTRR_ACC(_val) |
| #define | L2CACHE_L2CMTRR_MASK_SHIFT 2 |
| #define | L2CACHE_L2CMTRR_MASK_MASK 0xfffcU |
| #define | L2CACHE_L2CMTRR_MASK_GET(_reg) |
| #define | L2CACHE_L2CMTRR_MASK_SET(_reg, _val) |
| #define | L2CACHE_L2CMTRR_MASK(_val) |
| #define | L2CACHE_L2CMTRR_WP 0x2U |
| #define | L2CACHE_L2CMTRR_AC 0x1U |
Typedefs | |
| typedef struct l2cache | l2cache |
| This structure defines the L2CACHE register block memory map. | |
