RTEMS 6.1-rc8
This group contains the L2CACHE interfaces. More...
Modules | |
| L2C Access control register (L2CACCC) | |
| This group contains register bit definitions. | |
| L2C Control register (L2CC) | |
| L2C Data-Check-Bits register (L2CCB) | |
| L2C Error address register (L2CERRA) | |
| L2C Error injection register (L2CEINJ) | |
| L2C Flush (Memory address) register (L2CFMA) | |
| L2C Flush (Set, Index) register (L2CFSI) | |
| L2C Memory type range register (L2CMTRR) | |
| L2C Scrub control/status register (L2CSCRUB) | |
| L2C Scrub delay register (L2CSDEL) | |
| L2C Status register (L2CS) | |
| L2C TAG-Check-Bits register (L2CTCB) | |
| L2C injection configuration register (L2CEINJCFG) | |
| L2CError status/control register (L2CERR) | |
Files | |
| file | l2cache-regs.h |
| This header file defines the L2CACHE register block interface. | |
| struct | l2cache |
| This structure defines the L2CACHE register block memory map. More... | |
Typedefs | |
| typedef struct l2cache | l2cache |
| This structure defines the L2CACHE register block memory map. | |
