RTEMS 6.1-rc8
| struct | _spdif_edma_transfer |
| SPDIF transfer structure. More... | |
| struct | _spdif_edma_handle |
| SPDIF DMA transfer handle, users should not touch the content of the handle. More... | |
Driver version | |
| typedef struct _spdif_edma_handle | spdif_edma_handle_t |
| typedef void(* | spdif_edma_callback_t) (SPDIF_Type *base, spdif_edma_handle_t *handle, status_t status, void *userData) |
| SPDIF eDMA transfer callback function for finish and error. | |
| typedef struct _spdif_edma_transfer | spdif_edma_transfer_t |
| SPDIF transfer structure. | |
| #define | FSL_SPDIF_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 0, 5)) |
eDMA Transactional | |
| void | SPDIF_TransferTxCreateHandleEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle, spdif_edma_callback_t callback, void *userData, edma_handle_t *dmaLeftHandle, edma_handle_t *dmaRightHandle) |
| Initializes the SPDIF eDMA handle. | |
| void | SPDIF_TransferRxCreateHandleEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle, spdif_edma_callback_t callback, void *userData, edma_handle_t *dmaLeftHandle, edma_handle_t *dmaRightHandle) |
| Initializes the SPDIF Rx eDMA handle. | |
| status_t | SPDIF_TransferSendEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle, spdif_edma_transfer_t *xfer) |
| Performs a non-blocking SPDIF transfer using DMA. | |
| status_t | SPDIF_TransferReceiveEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle, spdif_edma_transfer_t *xfer) |
| Performs a non-blocking SPDIF receive using eDMA. | |
| void | SPDIF_TransferAbortSendEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle) |
| Aborts a SPDIF transfer using eDMA. | |
| void | SPDIF_TransferAbortReceiveEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle) |
| Aborts a SPDIF receive using eDMA. | |
| status_t | SPDIF_TransferGetSendCountEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle, size_t *count) |
| Gets byte count sent by SPDIF. | |
| status_t | SPDIF_TransferGetReceiveCountEDMA (SPDIF_Type *base, spdif_edma_handle_t *handle, size_t *count) |
| Gets byte count received by SPDIF. | |
| #define FSL_SPDIF_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 0, 5)) |
Version 2.0.5
| void SPDIF_TransferAbortReceiveEDMA | ( | SPDIF_Type * | base, |
| spdif_edma_handle_t * | handle | ||
| base | SPDIF base pointer |
| handle | SPDIF eDMA handle pointer. |
brief Aborts a SPDIF receive using eDMA.
param base SPDIF base pointer param handle SPDIF eDMA handle pointer.
| void SPDIF_TransferAbortSendEDMA | ( | SPDIF_Type * | base, |
| base | SPDIF base pointer. |
brief Aborts a SPDIF transfer using eDMA.
param base SPDIF base pointer. param handle SPDIF eDMA handle pointer.
| status_t SPDIF_TransferGetReceiveCountEDMA | ( | SPDIF_Type * | base, |
| spdif_edma_handle_t * | handle, | ||
| size_t * | count | ||
| count | Bytes count received by SPDIF. |
| kStatus_Success | Succeed get the transfer count. |
| kStatus_NoTransferInProgress | There is no non-blocking transaction in progress. |
brief Gets byte count received by SPDIF.
param base SPDIF base pointer param handle SPDIF eDMA handle pointer. param count Bytes count received by SPDIF. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is no non-blocking transaction in progress.
| status_t SPDIF_TransferGetSendCountEDMA | ( | SPDIF_Type * | base, |
| count | Bytes count sent by SPDIF. |
brief Gets byte count sent by SPDIF.
param base SPDIF base pointer. param handle SPDIF eDMA handle pointer. param count Bytes count sent by SPDIF. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is no non-blocking transaction in progress.
| status_t SPDIF_TransferReceiveEDMA | ( | SPDIF_Type * | base, |
| spdif_edma_transfer_t * | xfer | ||
| xfer | Pointer to DMA transfer structure. |
| kStatus_Success | Start a SPDIF eDMA receive successfully. |
| kStatus_InvalidArgument | The input argument is invalid. |
| kStatus_RxBusy | SPDIF is busy receiving data. |
brief Performs a non-blocking SPDIF receive using eDMA.
note This interface returns immediately after the transfer initiates. Call the SPDIF_GetReceiveRemainingBytes to poll the transfer status and check whether the SPDIF transfer is finished.
param base SPDIF base pointer param handle SPDIF eDMA handle pointer. param xfer Pointer to DMA transfer structure. retval kStatus_Success Start a SPDIF eDMA receive successfully. retval kStatus_InvalidArgument The input argument is invalid. retval kStatus_RxBusy SPDIF is busy receiving data.
| void SPDIF_TransferRxCreateHandleEDMA | ( | SPDIF_Type * | base, |
| spdif_edma_callback_t | callback, | ||
| void * | userData, | ||
| edma_handle_t * | dmaLeftHandle, | ||
| edma_handle_t * | dmaRightHandle | ||
This function initializes the SPDIF slave DMA handle, which can be used for other SPDIF master transactional APIs. Usually, for a specified SPDIF instance, call this API once to get the initialized handle.
| base | SPDIF peripheral base address. |
| callback | Pointer to user callback function. |
| userData | User parameter passed to the callback function. |
| dmaLeftHandle | eDMA handle pointer for left channel, this handle shall be static allocated by users. |
| dmaRightHandle | eDMA handle pointer for right channel, this handle shall be static allocated by users. |
brief Initializes the SPDIF Rx eDMA handle.
param base SPDIF base pointer. param handle SPDIF eDMA handle pointer. param base SPDIF peripheral base address. param callback Pointer to user callback function. param userData User parameter passed to the callback function. param dmaLeftHandle eDMA handle pointer for left channel, this handle shall be static allocated by users. param dmaRightHandle eDMA handle pointer for right channel, this handle shall be static allocated by users.
| status_t SPDIF_TransferSendEDMA | ( | SPDIF_Type * | base, |
| xfer | Pointer to the DMA transfer structure. |
| kStatus_Success | Start a SPDIF eDMA send successfully. |
| kStatus_TxBusy | SPDIF is busy sending data. |
brief Performs a non-blocking SPDIF transfer using DMA.
note This interface returns immediately after the transfer initiates. Call SPDIF_GetTransferStatus to poll the transfer status and check whether the SPDIF transfer is finished.
param base SPDIF base pointer. param handle SPDIF eDMA handle pointer. param xfer Pointer to the DMA transfer structure. retval kStatus_Success Start a SPDIF eDMA send successfully. retval kStatus_InvalidArgument The input argument is invalid. retval kStatus_TxBusy SPDIF is busy sending data.
| void SPDIF_TransferTxCreateHandleEDMA | ( | SPDIF_Type * | base, |
This function initializes the SPDIF master DMA handle, which can be used for other SPDIF master transactional APIs. Usually, for a specified SPDIF instance, call this API once to get the initialized handle.
brief Initializes the SPDIF eDMA handle.
