RTEMS 6.1-rc8
Driver version | |
| void | SEMA4_Init (SEMA4_Type *base) |
| Initializes the SEMA4 module. | |
| void | SEMA4_Deinit (SEMA4_Type *base) |
| De-initializes the SEMA4 module. | |
| status_t | SEMA4_TryLock (SEMA4_Type *base, uint8_t gateNum, uint8_t procNum) |
| Tries to lock the SEMA4 gate. | |
| void | SEMA4_Lock (SEMA4_Type *base, uint8_t gateNum, uint8_t procNum) |
| Locks the SEMA4 gate. | |
| status_t | SEMA4_ResetGate (SEMA4_Type *base, uint8_t gateNum) |
| Resets the SEMA4 gate to an unlocked status. | |
| status_t | SEMA4_ResetGateNotify (SEMA4_Type *base, uint8_t gateNum) |
| Resets the SEMA4 gate IRQ notification. | |
| #define | FSL_SEMA4_DRIVER_VERSION (MAKE_VERSION(2, 0, 3)) |
| SEMA4 driver version. | |
| #define | SEMA4_GATE_NUM_RESET_ALL (64U) |
| The number to reset all SEMA4 gates. | |
| #define | SEMA4_GATEn(base, n) (((volatile uint8_t *)(&((base)->Gate00)))[(n)]) |
| SEMA4 gate n register address. | |
| void SEMA4_Deinit | ( | SEMA4_Type * | base | ) |
This function de-initializes the SEMA4 module. It only disables the clock.
| base | SEMA4 peripheral base address. |
brief De-initializes the SEMA4 module.
param base SEMA4 peripheral base address.
| void SEMA4_Init | ( | SEMA4_Type * | base | ) |
This function initializes the SEMA4 module. It only enables the clock but does not reset the gates because the module might be used by other processors at the same time. To reset the gates, call either SEMA4_ResetGate or SEMA4_ResetAllGates function.
brief Initializes the SEMA4 module.
| void SEMA4_Lock | ( | SEMA4_Type * | base, |
| uint8_t | gateNum, | ||
| uint8_t | procNum | ||
This function locks the specific SEMA4 gate. If the gate has been locked by other processors, this function waits until it is unlocked and then lock it.
| gateNum | Gate number to lock. |
| procNum | Current processor number. |
brief Locks the SEMA4 gate.
param base SEMA4 peripheral base address. param gateNum Gate number to lock. param procNum Current processor number.
| status_t SEMA4_ResetGate | ( | SEMA4_Type * | base, |
| uint8_t | gateNum | ||
This function resets a SEMA4 gate to an unlocked status.
| gateNum | Gate number. |
| kStatus_Success | SEMA4 gate is reset successfully. |
| kStatus_Fail | Some other reset process is ongoing. |
brief Resets the SEMA4 gate to an unlocked status.
param base SEMA4 peripheral base address. param gateNum Gate number.
retval kStatus_Success SEMA4 gate is reset successfully. retval kStatus_Fail Some other reset process is ongoing.
| status_t SEMA4_ResetGateNotify | ( | SEMA4_Type * | base, |
This function resets a SEMA4 gate IRQ notification.
| kStatus_Success | Reset successfully. |
brief Resets the SEMA4 gate IRQ notification.
retval kStatus_Success Reset successfully. retval kStatus_Fail Some other reset process is ongoing.
| status_t SEMA4_TryLock | ( | SEMA4_Type * | base, |
This function tries to lock the specific SEMA4 gate. If the gate has been locked by another processor, this function returns an error code.
| kStatus_Success | Lock the sema4 gate successfully. |
| kStatus_Fail | Sema4 gate has been locked by another processor. |
brief Tries to lock the SEMA4 gate.
retval kStatus_Success Lock the sema4 gate successfully. retval kStatus_Fail Sema4 gate has been locked by another processor.
