RTEMS 6.1-rc8
| #define | RBUTTON MV_BUTTON_RIGHT |
| #define | MBUTTON MV_BUTTON_CENTER |
| #define | LBUTTON MV_BUTTON_LEFT |
Typedefs | |
| typedef int | COORD |
| typedef unsigned int | BUTTON |
| typedef void(* | mouse_parser_enqueue_handler) (unsigned char *, size_t) |
| int | mouse_parser_initialize (const char *type) |
| Initialize the mouse parser engine. | |
| void | mouse_parser_enqueue (unsigned char *buffer, size_t size) |
| Enqueue input to the mouse parser engine. | |
| #define LBUTTON MV_BUTTON_LEFT |
This is the mask for the left button.
| #define MBUTTON MV_BUTTON_CENTER |
This is the mask for the center button.
| #define RBUTTON MV_BUTTON_RIGHT |
This is the mask for the right button.
| typedef unsigned int BUTTON |
This type is the mouse button mask.
| typedef int COORD |
This type is the device coordinates.
| typedef void(* mouse_parser_enqueue_handler) (unsigned char *, size_t) |
This type defines a pointer to the enqueue method. It is available since some device drivers keep pointers to the method to know when to enqueue or not.
| void mouse_parser_enqueue | ( | unsigned char * | buffer, |
| size_t | size | ||
This method is used to pass mouse input to the Mouse Parser Engine.
param[in] buffer is the data to enqueue param[in] size is the amount of data to enqueue
| int mouse_parser_initialize | ( | const char * | type | ) |
This method initializes the Mouse Parser Engine for the mouse of type. The type should be one of the following strings: pc ms, logi, ps2.
param[in] type indicates the type of mouse.
| This | method returns 0 on success and -1 on error. |
