RTEMS 6.1-rc8
| struct | _flexio_i2s_edma_handle |
| FlexIO I2S DMA transfer handle, users should not touch the content of the handle. More... | |
Driver version | |
| typedef struct _flexio_i2s_edma_handle | flexio_i2s_edma_handle_t |
| typedef void(* | flexio_i2s_edma_callback_t) (FLEXIO_I2S_Type *base, flexio_i2s_edma_handle_t *handle, status_t status, void *userData) |
| FlexIO I2S eDMA transfer callback function for finish and error. | |
| #define | FSL_FLEXIO_I2S_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 1, 7)) |
| FlexIO I2S EDMA driver version 2.1.7. | |
| void FLEXIO_I2S_TransferAbortReceiveEDMA | ( | FLEXIO_I2S_Type * | base, |
| flexio_i2s_edma_handle_t * | handle | ||
Aborts a FlexIO I2S receive using eDMA.
| base | FlexIO I2S peripheral base address. |
| handle | FlexIO I2S DMA handle pointer. |
brief Aborts a FlexIO I2S receive using eDMA.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S DMA handle pointer.
| void FLEXIO_I2S_TransferAbortSendEDMA | ( | FLEXIO_I2S_Type * | base, |
Aborts a FlexIO I2S transfer using eDMA.
brief Aborts a FlexIO I2S transfer using eDMA.
| status_t FLEXIO_I2S_TransferGetReceiveCountEDMA | ( | FLEXIO_I2S_Type * | base, |
| flexio_i2s_edma_handle_t * | handle, | ||
| size_t * | count | ||
Get the remaining bytes to be received.
| count | Bytes received. |
| kStatus_Success | Succeed get the transfer count. |
| kStatus_NoTransferInProgress | There is not a non-blocking transaction currently in progress. |
brief Get the remaining bytes to be received.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S DMA handle pointer. param count Bytes received. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
| status_t FLEXIO_I2S_TransferGetSendCountEDMA | ( | FLEXIO_I2S_Type * | base, |
Gets the remaining bytes to be sent.
| count | Bytes sent. |
brief Gets the remaining bytes to be sent.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S DMA handle pointer. param count Bytes sent. retval kStatus_Success Succeed get the transfer count. retval kStatus_NoTransferInProgress There is not a non-blocking transaction currently in progress.
| status_t FLEXIO_I2S_TransferReceiveEDMA | ( | FLEXIO_I2S_Type * | base, |
| flexio_i2s_transfer_t * | xfer | ||
Performs a non-blocking FlexIO I2S receive using eDMA.
| xfer | Pointer to DMA transfer structure. |
| kStatus_Success | Start a FlexIO I2S eDMA receive successfully. |
| kStatus_InvalidArgument | The input arguments is invalid. |
| kStatus_RxBusy | FlexIO I2S is busy receiving data. |
brief Performs a non-blocking FlexIO I2S receive using eDMA.
note This interface returned immediately after transfer initiates. Users should call FLEXIO_I2S_GetReceiveRemainingBytes to poll the transfer status and check whether the FlexIO I2S transfer is finished.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S DMA handle pointer. param xfer Pointer to DMA transfer structure. retval kStatus_Success Start a FlexIO I2S eDMA receive successfully. retval kStatus_InvalidArgument The input arguments is invalid. retval kStatus_RxBusy FlexIO I2S is busy receiving data.
| void FLEXIO_I2S_TransferRxCreateHandleEDMA | ( | FLEXIO_I2S_Type * | base, |
| flexio_i2s_edma_callback_t | callback, | ||
| void * | userData, | ||
| edma_handle_t * | dmaHandle | ||
Initializes the FlexIO I2S Rx eDMA handle.
This function initializes the FlexIO I2S slave DMA handle which can be used for other FlexIO I2S master transactional APIs. Usually, for a specified FlexIO I2S instance, call this API once to get the initialized handle.
| handle | FlexIO I2S eDMA handle pointer. |
| callback | FlexIO I2S eDMA callback function called while finished a block. |
| userData | User parameter for callback. |
| dmaHandle | eDMA handle for FlexIO I2S. This handle is a static value allocated by users. |
brief Initializes the FlexIO I2S Rx eDMA handle.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S eDMA handle pointer. param callback FlexIO I2S eDMA callback function called while finished a block. param userData User parameter for callback. param dmaHandle eDMA handle for FlexIO I2S. This handle is a static value allocated by users.
| status_t FLEXIO_I2S_TransferSendEDMA | ( | FLEXIO_I2S_Type * | base, |
Performs a non-blocking FlexIO I2S transfer using DMA.
| kStatus_Success | Start a FlexIO I2S eDMA send successfully. |
| kStatus_TxBusy | FlexIO I2S is busy sending data. |
brief Performs a non-blocking FlexIO I2S transfer using DMA.
note This interface returned immediately after transfer initiates. Users should call FLEXIO_I2S_GetTransferStatus to poll the transfer status and check whether the FlexIO I2S transfer is finished.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S DMA handle pointer. param xfer Pointer to DMA transfer structure. retval kStatus_Success Start a FlexIO I2S eDMA send successfully. retval kStatus_InvalidArgument The input arguments is invalid. retval kStatus_TxBusy FlexIO I2S is busy sending data.
| void FLEXIO_I2S_TransferSetFormatEDMA | ( | FLEXIO_I2S_Type * | base, |
| flexio_i2s_format_t * | format, | ||
| uint32_t | srcClock_Hz | ||
Configures the FlexIO I2S Tx audio format.
Audio format can be changed in run-time of FlexIO I2S. This function configures the sample rate and audio data format to be transferred. This function also sets the eDMA parameter according to format.
| handle | FlexIO I2S eDMA handle pointer |
| format | Pointer to FlexIO I2S audio data format structure. |
| srcClock_Hz | FlexIO I2S clock source frequency in Hz, it should be 0 while in slave mode. |
brief Configures the FlexIO I2S Tx audio format.
param base FlexIO I2S peripheral base address. param handle FlexIO I2S eDMA handle pointer param format Pointer to FlexIO I2S audio data format structure. param srcClock_Hz FlexIO I2S clock source frequency in Hz, it should be 0 while in slave mode.
| void FLEXIO_I2S_TransferTxCreateHandleEDMA | ( | FLEXIO_I2S_Type * | base, |
Initializes the FlexIO I2S eDMA handle.
This function initializes the FlexIO I2S master DMA handle which can be used for other FlexIO I2S master transactional APIs. Usually, for a specified FlexIO I2S instance, call this API once to get the initialized handle.
brief Initializes the FlexIO I2S eDMA handle.
