RTEMS 6.1-rc8
Data Structures | Enumerator | Variables
Csi2rx
struct  _csi2rx_config
 CSI2RX configuration.
More...
uint8_t _csi2rx_config::laneNum
uint8_t _csi2rx_config::tHsSettle_EscClk
Driver version
enum  _csi2rx_data_lane { kCSI2RX_DataLane0 = (1U << 0U) , kCSI2RX_DataLane1 = (1U << 1U) , kCSI2RX_DataLane2 = (1U << 2U) , kCSI2RX_DataLane3 = (1U << 3U) }
 CSI2RX data lanes.
More...
enum  _csi2rx_payload {
  kCSI2RX_PayloadGroup0Null = (1U << 0U) , kCSI2RX_PayloadGroup0Blank = (1U << 1U) , kCSI2RX_PayloadGroup0Embedded = (1U << 2U) , kCSI2RX_PayloadGroup0YUV420_8Bit = (1U << 10U) ,
  kCSI2RX_PayloadGroup0YUV422_8Bit = (1U << 14U) , kCSI2RX_PayloadGroup0YUV422_10Bit = (1U << 15U) , kCSI2RX_PayloadGroup0RGB444 = (1U << 16U) , kCSI2RX_PayloadGroup0RGB555 = (1U << 17U) ,
  kCSI2RX_PayloadGroup0RGB565 = (1U << 18U) , kCSI2RX_PayloadGroup0RGB666 = (1U << 19U) , kCSI2RX_PayloadGroup0RGB888 = (1U << 20U) , kCSI2RX_PayloadGroup0Raw6 = (1U << 24U) ,
  kCSI2RX_PayloadGroup0Raw7 = (1U << 25U) , kCSI2RX_PayloadGroup0Raw8 = (1U << 26U) , kCSI2RX_PayloadGroup0Raw10 = (1U << 27U) , kCSI2RX_PayloadGroup0Raw12 = (1U << 28U) ,
  kCSI2RX_PayloadGroup0Raw14 = (1U << 29U) , kCSI2RX_PayloadGroup1UserDefined1 = (1U << 0U) , kCSI2RX_PayloadGroup1UserDefined2 = (1U << 1U) , kCSI2RX_PayloadGroup1UserDefined3 = (1U << 2U) ,
  kCSI2RX_PayloadGroup1UserDefined4 = (1U << 3U) , kCSI2RX_PayloadGroup1UserDefined5 = (1U << 4U) , kCSI2RX_PayloadGroup1UserDefined6 = (1U << 5U) , kCSI2RX_PayloadGroup1UserDefined7 = (1U << 6U) ,
  kCSI2RX_PayloadGroup1UserDefined8 = (1U << 7U)
 CSI2RX payload type.
More...
enum  _csi2rx_bit_error { kCSI2RX_BitErrorEccTwoBit = (1U << 0U) , kCSI2RX_BitErrorEccOneBit = (1U << 1U) }
 MIPI CSI2RX bit errors. More...
enum  _csi2rx_ppi_error {
  kCSI2RX_PpiErrorSotHs , kCSI2RX_PpiErrorSotSyncHs , kCSI2RX_PpiErrorEsc , kCSI2RX_PpiErrorSyncEsc ,
  kCSI2RX_PpiErrorControl
 MIPI CSI2RX PPI error types. More...
enum  _csi2rx_interrupt {
  kCSI2RX_InterruptCrcError = (1U << 0U) , kCSI2RX_InterruptEccOneBitError = (1U << 1U) , kCSI2RX_InterruptEccTwoBitError = (1U << 2U) , kCSI2RX_InterruptUlpsStatusChange = (1U << 3U) ,
  kCSI2RX_InterruptErrorSotHs = (1U << 4U) , kCSI2RX_InterruptErrorSotSyncHs = (1U << 5U) , kCSI2RX_InterruptErrorEsc = (1U << 6U) , kCSI2RX_InterruptErrorSyncEsc = (1U << 7U) ,
  kCSI2RX_InterruptErrorControl = (1U << 8U)
 MIPI CSI2RX interrupt.
enum  _csi2rx_ulps_status {
  kCSI2RX_ClockLaneUlps = (1U << 0U) , kCSI2RX_DataLane0Ulps = (1U << 1U) , kCSI2RX_DataLane1Ulps = (1U << 2U) , kCSI2RX_DataLane2Ulps = (1U << 3U) ,
  kCSI2RX_DataLane3Ulps = (1U << 4U) , kCSI2RX_ClockLaneMark = (1U << 5U) , kCSI2RX_DataLane0Mark = (1U << 6U) , kCSI2RX_DataLane1Mark = (1U << 7U) ,
  kCSI2RX_DataLane2Mark = (1U << 8U) , kCSI2RX_DataLane3Mark = (1U << 9U)
 MIPI CSI2RX D-PHY ULPS state. More...
typedef struct _csi2rx_config csi2rx_config_t
typedef enum _csi2rx_ppi_error csi2rx_ppi_error_t
void CSI2RX_Init (MIPI_CSI2RX_Type *base, const csi2rx_config_t *config)
 Enables and configures the CSI2RX peripheral module.
void CSI2RX_Deinit (MIPI_CSI2RX_Type *base)
 Disables the CSI2RX peripheral module.
#define FSL_CSI2RX_DRIVER_VERSION   (MAKE_VERSION(2, 0, 4))
 CSI2RX driver version.
#define CSI2RX_REG_CFG_NUM_LANES(base)   (base)->CSI2RX_CFG_NUM_LANES
#define CSI2RX_REG_CFG_DISABLE_DATA_LANES(base)   (base)->CSI2RX_CFG_DISABLE_DATA_LANES
#define CSI2RX_REG_BIT_ERR(base)   (base)->CSI2RX_BIT_ERR
#define CSI2RX_REG_IRQ_STATUS(base)   (base)->CSI2RX_IRQ_STATUS
#define CSI2RX_REG_IRQ_MASK(base)   (base)->CSI2RX_IRQ_MASK
#define CSI2RX_REG_ULPS_STATUS(base)   (base)->CSI2RX_ULPS_STATUS
#define CSI2RX_REG_PPI_ERRSOT_HS(base)   (base)->CSI2RX_PPI_ERRSOT_HS
#define CSI2RX_REG_PPI_ERRSOTSYNC_HS(base)   (base)->CSI2RX_PPI_ERRSOTSYNC_HS
#define CSI2RX_REG_PPI_ERRESC(base)   (base)->CSI2RX_PPI_ERRESC
#define CSI2RX_REG_PPI_ERRSYNCESC(base)   (base)->CSI2RX_PPI_ERRSYNCESC
#define CSI2RX_REG_PPI_ERRCONTROL(base)   (base)->CSI2RX_PPI_ERRCONTROL
#define CSI2RX_REG_CFG_DISABLE_PAYLOAD_0(base)   (base)->CSI2RX_CFG_DISABLE_PAYLOAD_0
#define CSI2RX_REG_CFG_DISABLE_PAYLOAD_1(base)   (base)->CSI2RX_CFG_DISABLE_PAYLOAD_1
#define CSI2RX_REG_CFG_IGNORE_VC(base)   (base)->CSI2RX_CFG_IGNORE_VC
#define CSI2RX_REG_CFG_VID_VC(base)   (base)->CSI2RX_CFG_VID_VC
#define CSI2RX_REG_CFG_VID_P_FIFO_SEND_LEVEL(base)   (base)->CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL
#define CSI2RX_REG_CFG_VID_VSYNC(base)   (base)->CSI2RX_CFG_VID_VSYNC
#define CSI2RX_REG_CFG_VID_HSYNC_FP(base)   (base)->CSI2RX_CFG_VID_HSYNC_FP
#define CSI2RX_REG_CFG_VID_HSYNC(base)   (base)->CSI2RX_CFG_VID_HSYNC
#define CSI2RX_REG_CFG_VID_HSYNC_BP(base)   (base)->CSI2RX_CFG_VID_HSYNC_BP
#define MIPI_CSI2RX_CSI2RX_CFG_NUM_LANES_csi2rx_cfg_num_lanes_MASK   MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK
#define MIPI_CSI2RX_CSI2RX_IRQ_MASK_csi2rx_irq_mask_MASK   MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK
◆ _csi2rx_bit_error
ECC two bit error has occurred.
ECC one bit error has occurred.
◆ _csi2rx_data_lane
CSI2RX data lanes.
kCSI2RX_DataLane0
Data lane 0.
kCSI2RX_DataLane1
Data lane 1.
kCSI2RX_DataLane2
Data lane 2.
kCSI2RX_DataLane3
Data lane 3.
◆ _csi2rx_payload
NULL.
Blank.
Embedded.
Legacy YUV420 8 bit.
YUV422 8 bit.
YUV422 10 bit.
RGB444.
RGB555.
RGB565.
RGB666.
RGB888.
Raw 6.
Raw 7.
Raw 8.
Raw 10.
Raw 12.
Raw 14.
User defined 8-bit data type 1, 0x30.
User defined 8-bit data type 2, 0x31.
User defined 8-bit data type 3, 0x32.
User defined 8-bit data type 4, 0x33.
User defined 8-bit data type 5, 0x34.
User defined 8-bit data type 6, 0x35.
User defined 8-bit data type 7, 0x36.
User defined 8-bit data type 8, 0x37.
◆ _csi2rx_ppi_error
CSI2RX DPHY PPI error ErrSotHS.
CSI2RX DPHY PPI error ErrSotSync_HS.
kCSI2RX_PpiErrorEsc
CSI2RX DPHY PPI error ErrEsc.
CSI2RX DPHY PPI error ErrSyncEsc.
CSI2RX DPHY PPI error ErrControl.
◆ _csi2rx_ulps_status
Clock lane is in ULPS state.
Data lane 0 is in ULPS state.
Data lane 1 is in ULPS state.
Data lane 2 is in ULPS state.
Data lane 3 is in ULPS state.
Clock lane is in mark state.
Data lane 0 is in mark state.
Data lane 1 is in mark state.
Data lane 2 is in mark state.
Data lane 3 is in mark state.
◆ CSI2RX_Deinit()
void CSI2RX_Deinit ( MIPI_CSI2RX_Type base)
Parameters
baseCSI2RX peripheral address.
brief Disables the CSI2RX peripheral module.
param base CSI2RX peripheral address.
◆ CSI2RX_Init()
void CSI2RX_Init ( MIPI_CSI2RX_Type base,
const csi2rx_config_t config
Parameters
configCSI2RX module configuration structure.
brief Enables and configures the CSI2RX peripheral module.
param base CSI2RX peripheral address. param config CSI2RX module configuration structure.
Variable Documentation
◆ laneNum
Number of active lanes used for receiving data.
◆ tHsSettle_EscClk
Number of rx_clk_esc clock periods for T_HS_SETTLE. The T_HS_SETTLE should be in the range of 85ns + 6UI to 145ns + 10UI.
