RTEMS 6.1-rc8
Control for cortex-m7 L1 cache | |
| void | L1CACHE_InvalidateICacheByRange (uint32_t address, uint32_t size_byte) |
| Invalidate cortex-m7 L1 instruction cache by range. | |
Unified Cache Control for all caches (cortex-m7 L1 cache + l2 pl310) | |
Mainly used for many drivers for easy cache operation. | |
| void | ICACHE_InvalidateByRange (uint32_t address, uint32_t size_byte) |
| Invalidates all instruction caches by range. | |
| void | DCACHE_InvalidateByRange (uint32_t address, uint32_t size_byte) |
| Invalidates all data caches by range. | |
| void | DCACHE_CleanByRange (uint32_t address, uint32_t size_byte) |
| Cleans all data caches by range. | |
| void | DCACHE_CleanInvalidateByRange (uint32_t address, uint32_t size_byte) |
| Cleans and Invalidates all data caches by range. | |
Driver version | |
| #define | FSL_CACHE_DRIVER_VERSION (MAKE_VERSION(2, 0, 4)) |
| cache driver version 2.0.4. | |
Driver version | |
| void DCACHE_CleanByRange | ( | uint32_t | address, |
| uint32_t | size_byte | ||
Both cortex-m7 L1 cache line and L2 PL310 cache line length is 32-byte.
| address | The physical address. |
| size_byte | size of the memory to be cleaned. |
brief Cleans all data caches by range.
param address The physical address. param size_byte size of the memory to be cleaned. note address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
| void DCACHE_CleanInvalidateByRange | ( | uint32_t | address, |
| size_byte | size of the memory to be cleaned and invalidated. |
brief Cleans and Invalidates all data caches by range.
param address The physical address. param size_byte size of the memory to be cleaned and invalidated. note address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
| void DCACHE_InvalidateByRange | ( | uint32_t | address, |
| size_byte | size of the memory to be invalidated. |
brief Invalidates all data caches by range.
param address The physical address. param size_byte size of the memory to be invalidated. note address and size should be aligned to cache line size 32-Byte due to the cache operation unit is one cache line. The startAddr here will be forced to align to the cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
| void ICACHE_InvalidateByRange | ( | uint32_t | address, |
brief Invalidates all instruction caches by range.
| void L1CACHE_InvalidateICacheByRange | ( | uint32_t | address, |
| address | The start address of the memory to be invalidated. |
| size_byte | The memory size. |
brief Invalidates cortex-m4 L1 instrument cache by range.
param address The start address of the memory to be invalidated. param size_byte The memory size. note The start address and size_byte should be 16-Byte(FSL_FEATURE_L1ICACHE_LINESIZE_BYTE) aligned.
brief Invalidate cortex-m7 L1 instruction cache by range.
param address The start address of the memory to be invalidated. param size_byte The memory size. note The start address and size_byte should be 32-byte(FSL_FEATURE_L1ICACHE_LINESIZE_BYTE) aligned. The startAddr here will be forced to align to L1 I-cache line size if startAddr is not aligned. For the size_byte, application should make sure the alignment or make sure the right operation order if the size_byte is not aligned.
