RTEMS 6.1-rc8
| #define | UTILS_PLLVCO_INPUT_MIN1 1000000U |
| #define | UTILS_PLLVCO_INPUT_MAX1 2000000U |
| #define | UTILS_PLLVCO_INPUT_MIN2 2000000U |
| #define | UTILS_PLLVCO_INPUT_MAX2 4000000U |
| #define | UTILS_PLLVCO_INPUT_MIN3 4000000U |
| #define | UTILS_PLLVCO_INPUT_MAX3 8000000U |
| #define | UTILS_PLLVCO_INPUT_MIN4 8000000U |
| #define | UTILS_PLLVCO_INPUT_MAX4 16000000U |
| #define | UTILS_PLLVCO_MEDIUM_OUTPUT_MIN 150000000U |
| #define | UTILS_PLLVCO_WIDE_OUTPUT_MIN 128000000U |
| #define | UTILS_PLLVCO_MEDIUM_OUTPUT_MAX 420000000U |
| #define | UTILS_PLLVCO_WIDE_OUTPUT_MAX 560000000U |
| #define | UTILS_HSE_FREQUENCY_MIN 4000000U |
| #define | UTILS_HSE_FREQUENCY_MAX 48000000U |
| #define | LL_MAX_DELAY 0xFFFFFFFFU |
| #define | UID_BASE_ADDRESS UID_BASE |
| Unique device ID register base address. | |
| #define | FLASHSIZE_BASE_ADDRESS FLASHSIZE_BASE |
| Flash size data register base address. | |
| #define | PACKAGE_BASE_ADDRESS PACKAGE_BASE |
| Package data register base address. | |
| #define UTILS_HSE_FREQUENCY_MAX 48000000U |
Frequency max for HSE frequency, in Hz
| #define UTILS_HSE_FREQUENCY_MIN 4000000U |
Frequency min for HSE frequency, in Hz
| #define UTILS_PLLVCO_INPUT_MAX1 2000000U |
Frequency max for the wide range PLLVCO input, in Hz
| #define UTILS_PLLVCO_INPUT_MAX2 4000000U |
| #define UTILS_PLLVCO_INPUT_MAX3 8000000U |
| #define UTILS_PLLVCO_INPUT_MAX4 16000000U |
| #define UTILS_PLLVCO_INPUT_MIN1 1000000U |
Frequency min for the low range PLLVCO input, in Hz
| #define UTILS_PLLVCO_INPUT_MIN2 2000000U |
| #define UTILS_PLLVCO_INPUT_MIN3 4000000U |
| #define UTILS_PLLVCO_INPUT_MIN4 8000000U |
| #define UTILS_PLLVCO_MEDIUM_OUTPUT_MAX 420000000U |
Frequency max for the medium range PLLVCO output, in Hz
| #define UTILS_PLLVCO_MEDIUM_OUTPUT_MIN 150000000U |
Frequency min for the medium range PLLVCO output, in Hz
| #define UTILS_PLLVCO_WIDE_OUTPUT_MAX 560000000U |
Frequency max for the wide range PLLVCO output, in Hz
| #define UTILS_PLLVCO_WIDE_OUTPUT_MIN 128000000U |
Frequency min for the wide range PLLVCO output, in Hz
