RTEMS 6.1-rc8
COMP1 - Timer Channel Compare Register 1 | |
| #define | TMR_COMP1_COMPARISON_1_MASK (0xFFFFU) |
| #define | TMR_COMP1_COMPARISON_1_SHIFT (0U) |
| #define | TMR_COMP1_COMPARISON_1(x) (((uint16_t)(((uint16_t)(x)) << TMR_COMP1_COMPARISON_1_SHIFT)) & TMR_COMP1_COMPARISON_1_MASK) |
COMP2 - Timer Channel Compare Register 2 | |
| #define | TMR_COMP2_COMPARISON_2_MASK (0xFFFFU) |
| #define | TMR_COMP2_COMPARISON_2_SHIFT (0U) |
| #define | TMR_COMP2_COMPARISON_2(x) (((uint16_t)(((uint16_t)(x)) << TMR_COMP2_COMPARISON_2_SHIFT)) & TMR_COMP2_COMPARISON_2_MASK) |
CAPT - Timer Channel Capture Register | |
| #define | TMR_CAPT_CAPTURE_MASK (0xFFFFU) |
| #define | TMR_CAPT_CAPTURE_SHIFT (0U) |
| #define | TMR_CAPT_CAPTURE(x) (((uint16_t)(((uint16_t)(x)) << TMR_CAPT_CAPTURE_SHIFT)) & TMR_CAPT_CAPTURE_MASK) |
LOAD - Timer Channel Load Register | |
| #define | TMR_LOAD_LOAD_MASK (0xFFFFU) |
| #define | TMR_LOAD_LOAD_SHIFT (0U) |
| #define | TMR_LOAD_LOAD(x) (((uint16_t)(((uint16_t)(x)) << TMR_LOAD_LOAD_SHIFT)) & TMR_LOAD_LOAD_MASK) |
CTRL - Timer Channel Control Register | |
| #define | TMR_CTRL_OUTMODE_MASK (0x7U) |
| #define | TMR_CTRL_OUTMODE_SHIFT (0U) |
| #define | TMR_CTRL_OUTMODE(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_OUTMODE_SHIFT)) & TMR_CTRL_OUTMODE_MASK) |
| #define | TMR_CTRL_COINIT_MASK (0x8U) |
| #define | TMR_CTRL_COINIT_SHIFT (3U) |
| #define | TMR_CTRL_COINIT(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_COINIT_SHIFT)) & TMR_CTRL_COINIT_MASK) |
| #define | TMR_CTRL_DIR_MASK (0x10U) |
| #define | TMR_CTRL_DIR_SHIFT (4U) |
| #define | TMR_CTRL_DIR(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_DIR_SHIFT)) & TMR_CTRL_DIR_MASK) |
| #define | TMR_CTRL_LENGTH_MASK (0x20U) |
| #define | TMR_CTRL_LENGTH_SHIFT (5U) |
| #define | TMR_CTRL_LENGTH(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_LENGTH_SHIFT)) & TMR_CTRL_LENGTH_MASK) |
| #define | TMR_CTRL_ONCE_MASK (0x40U) |
| #define | TMR_CTRL_ONCE_SHIFT (6U) |
| #define | TMR_CTRL_ONCE(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_ONCE_SHIFT)) & TMR_CTRL_ONCE_MASK) |
| #define | TMR_CTRL_SCS_MASK (0x180U) |
| #define | TMR_CTRL_SCS_SHIFT (7U) |
| #define | TMR_CTRL_SCS(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_SCS_SHIFT)) & TMR_CTRL_SCS_MASK) |
| #define | TMR_CTRL_PCS_MASK (0x1E00U) |
| #define | TMR_CTRL_PCS_SHIFT (9U) |
| #define | TMR_CTRL_PCS(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_PCS_SHIFT)) & TMR_CTRL_PCS_MASK) |
| #define | TMR_CTRL_CM_MASK (0xE000U) |
| #define | TMR_CTRL_CM_SHIFT (13U) |
| #define | TMR_CTRL_CM(x) (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_CM_SHIFT)) & TMR_CTRL_CM_MASK) |
SCTRL - Timer Channel Status and Control Register | |
| #define | TMR_SCTRL_OEN_MASK (0x1U) |
| #define | TMR_SCTRL_OEN_SHIFT (0U) |
| #define | TMR_SCTRL_OEN(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_OEN_SHIFT)) & TMR_SCTRL_OEN_MASK) |
| #define | TMR_SCTRL_OPS_MASK (0x2U) |
| #define | TMR_SCTRL_OPS_SHIFT (1U) |
| #define | TMR_SCTRL_OPS(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_OPS_SHIFT)) & TMR_SCTRL_OPS_MASK) |
| #define | TMR_SCTRL_FORCE_MASK (0x4U) |
| #define | TMR_SCTRL_FORCE_SHIFT (2U) |
| #define | TMR_SCTRL_FORCE(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_FORCE_SHIFT)) & TMR_SCTRL_FORCE_MASK) |
| #define | TMR_SCTRL_VAL_MASK (0x8U) |
| #define | TMR_SCTRL_VAL_SHIFT (3U) |
| #define | TMR_SCTRL_VAL(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_VAL_SHIFT)) & TMR_SCTRL_VAL_MASK) |
| #define | TMR_SCTRL_EEOF_MASK (0x10U) |
| #define | TMR_SCTRL_EEOF_SHIFT (4U) |
| #define | TMR_SCTRL_EEOF(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_EEOF_SHIFT)) & TMR_SCTRL_EEOF_MASK) |
| #define | TMR_SCTRL_MSTR_MASK (0x20U) |
| #define | TMR_SCTRL_MSTR_SHIFT (5U) |
| #define | TMR_SCTRL_MSTR(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_MSTR_SHIFT)) & TMR_SCTRL_MSTR_MASK) |
| #define | TMR_SCTRL_CAPTURE_MODE_MASK (0xC0U) |
| #define | TMR_SCTRL_CAPTURE_MODE_SHIFT (6U) |
| #define | TMR_SCTRL_CAPTURE_MODE(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_CAPTURE_MODE_SHIFT)) & TMR_SCTRL_CAPTURE_MODE_MASK) |
| #define | TMR_SCTRL_INPUT_MASK (0x100U) |
| #define | TMR_SCTRL_INPUT_SHIFT (8U) |
| #define | TMR_SCTRL_INPUT(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_INPUT_SHIFT)) & TMR_SCTRL_INPUT_MASK) |
| #define | TMR_SCTRL_IPS_MASK (0x200U) |
| #define | TMR_SCTRL_IPS_SHIFT (9U) |
| #define | TMR_SCTRL_IPS(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_IPS_SHIFT)) & TMR_SCTRL_IPS_MASK) |
| #define | TMR_SCTRL_IEFIE_MASK (0x400U) |
| #define | TMR_SCTRL_IEFIE_SHIFT (10U) |
| #define | TMR_SCTRL_IEFIE(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_IEFIE_SHIFT)) & TMR_SCTRL_IEFIE_MASK) |
| #define | TMR_SCTRL_IEF_MASK (0x800U) |
| #define | TMR_SCTRL_IEF_SHIFT (11U) |
| #define | TMR_SCTRL_IEF(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_IEF_SHIFT)) & TMR_SCTRL_IEF_MASK) |
| #define | TMR_SCTRL_TOFIE_MASK (0x1000U) |
| #define | TMR_SCTRL_TOFIE_SHIFT (12U) |
| #define | TMR_SCTRL_TOFIE(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TOFIE_SHIFT)) & TMR_SCTRL_TOFIE_MASK) |
| #define | TMR_SCTRL_TOF_MASK (0x2000U) |
| #define | TMR_SCTRL_TOF_SHIFT (13U) |
| #define | TMR_SCTRL_TOF(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TOF_SHIFT)) & TMR_SCTRL_TOF_MASK) |
| #define | TMR_SCTRL_TCFIE_MASK (0x4000U) |
| #define | TMR_SCTRL_TCFIE_SHIFT (14U) |
| #define | TMR_SCTRL_TCFIE(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TCFIE_SHIFT)) & TMR_SCTRL_TCFIE_MASK) |
| #define | TMR_SCTRL_TCF_MASK (0x8000U) |
| #define | TMR_SCTRL_TCF_SHIFT (15U) |
| #define | TMR_SCTRL_TCF(x) (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TCF_SHIFT)) & TMR_SCTRL_TCF_MASK) |
CSCTRL - Timer Channel Comparator Status and Control Register | |
| #define | TMR_CSCTRL_CL1_MASK (0x3U) |
| #define | TMR_CSCTRL_CL1_SHIFT (0U) |
| #define | TMR_CSCTRL_CL1(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_CL1_SHIFT)) & TMR_CSCTRL_CL1_MASK) |
| #define | TMR_CSCTRL_CL2_MASK (0xCU) |
| #define | TMR_CSCTRL_CL2_SHIFT (2U) |
| #define | TMR_CSCTRL_CL2(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_CL2_SHIFT)) & TMR_CSCTRL_CL2_MASK) |
| #define | TMR_CSCTRL_TCF1_MASK (0x10U) |
| #define | TMR_CSCTRL_TCF1_SHIFT (4U) |
| #define | TMR_CSCTRL_TCF1(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF1_SHIFT)) & TMR_CSCTRL_TCF1_MASK) |
| #define | TMR_CSCTRL_TCF2_MASK (0x20U) |
| #define | TMR_CSCTRL_TCF2_SHIFT (5U) |
| #define | TMR_CSCTRL_TCF2(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF2_SHIFT)) & TMR_CSCTRL_TCF2_MASK) |
| #define | TMR_CSCTRL_TCF1EN_MASK (0x40U) |
| #define | TMR_CSCTRL_TCF1EN_SHIFT (6U) |
| #define | TMR_CSCTRL_TCF1EN(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF1EN_SHIFT)) & TMR_CSCTRL_TCF1EN_MASK) |
| #define | TMR_CSCTRL_TCF2EN_MASK (0x80U) |
| #define | TMR_CSCTRL_TCF2EN_SHIFT (7U) |
| #define | TMR_CSCTRL_TCF2EN(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF2EN_SHIFT)) & TMR_CSCTRL_TCF2EN_MASK) |
| #define | TMR_CSCTRL_UP_MASK (0x200U) |
| #define | TMR_CSCTRL_UP_SHIFT (9U) |
| #define | TMR_CSCTRL_UP(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_UP_SHIFT)) & TMR_CSCTRL_UP_MASK) |
| #define | TMR_CSCTRL_TCI_MASK (0x400U) |
| #define | TMR_CSCTRL_TCI_SHIFT (10U) |
| #define | TMR_CSCTRL_TCI(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCI_SHIFT)) & TMR_CSCTRL_TCI_MASK) |
| #define | TMR_CSCTRL_ROC_MASK (0x800U) |
| #define | TMR_CSCTRL_ROC_SHIFT (11U) |
| #define | TMR_CSCTRL_ROC(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_ROC_SHIFT)) & TMR_CSCTRL_ROC_MASK) |
| #define | TMR_CSCTRL_ALT_LOAD_MASK (0x1000U) |
| #define | TMR_CSCTRL_ALT_LOAD_SHIFT (12U) |
| #define | TMR_CSCTRL_ALT_LOAD(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_ALT_LOAD_SHIFT)) & TMR_CSCTRL_ALT_LOAD_MASK) |
| #define | TMR_CSCTRL_FAULT_MASK (0x2000U) |
| #define | TMR_CSCTRL_FAULT_SHIFT (13U) |
| #define | TMR_CSCTRL_FAULT(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_FAULT_SHIFT)) & TMR_CSCTRL_FAULT_MASK) |
| #define | TMR_CSCTRL_DBG_EN_MASK (0xC000U) |
| #define | TMR_CSCTRL_DBG_EN_SHIFT (14U) |
| #define | TMR_CSCTRL_DBG_EN(x) (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_DBG_EN_SHIFT)) & TMR_CSCTRL_DBG_EN_MASK) |
FILT - Timer Channel Input Filter Register | |
| #define | TMR_FILT_FILT_PER_MASK (0xFFU) |
| #define | TMR_FILT_FILT_PER_SHIFT (0U) |
| #define | TMR_FILT_FILT_PER(x) (((uint16_t)(((uint16_t)(x)) << TMR_FILT_FILT_PER_SHIFT)) & TMR_FILT_FILT_PER_MASK) |
| #define | TMR_FILT_FILT_CNT_MASK (0x700U) |
| #define | TMR_FILT_FILT_CNT_SHIFT (8U) |
| #define | TMR_FILT_FILT_CNT(x) (((uint16_t)(((uint16_t)(x)) << TMR_FILT_FILT_CNT_SHIFT)) & TMR_FILT_FILT_CNT_MASK) |
DMA - Timer Channel DMA Enable Register | |
| #define | TMR_DMA_IEFDE_MASK (0x1U) |
| #define | TMR_DMA_IEFDE_SHIFT (0U) |
| #define | TMR_DMA_IEFDE(x) (((uint16_t)(((uint16_t)(x)) << TMR_DMA_IEFDE_SHIFT)) & TMR_DMA_IEFDE_MASK) |
| #define | TMR_DMA_CMPLD1DE_MASK (0x2U) |
| #define | TMR_DMA_CMPLD1DE_SHIFT (1U) |
| #define | TMR_DMA_CMPLD1DE(x) (((uint16_t)(((uint16_t)(x)) << TMR_DMA_CMPLD1DE_SHIFT)) & TMR_DMA_CMPLD1DE_MASK) |
| #define | TMR_DMA_CMPLD2DE_MASK (0x4U) |
| #define | TMR_DMA_CMPLD2DE_SHIFT (2U) |
| #define | TMR_DMA_CMPLD2DE(x) (((uint16_t)(((uint16_t)(x)) << TMR_DMA_CMPLD2DE_SHIFT)) & TMR_DMA_CMPLD2DE_MASK) |
ENBL - Timer Channel Enable Register | |
| #define | TMR_ENBL_ENBL_MASK (0xFU) |
| #define | TMR_ENBL_ENBL_SHIFT (0U) |
| #define | TMR_ENBL_ENBL(x) (((uint16_t)(((uint16_t)(x)) << TMR_ENBL_ENBL_SHIFT)) & TMR_ENBL_ENBL_MASK) |
HOLD - Timer Channel Hold Register | |
| #define | TMR_HOLD_HOLD_MASK (0xFFFFU) |
| #define | TMR_HOLD_HOLD_SHIFT (0U) |
| #define | TMR_HOLD_HOLD(x) (((uint16_t)(((uint16_t)(x)) << TMR_HOLD_HOLD_SHIFT)) & TMR_HOLD_HOLD_MASK) |
CNTR - Timer Channel Counter Register | |
| #define | TMR_CNTR_COUNTER_MASK (0xFFFFU) |
| #define | TMR_CNTR_COUNTER_SHIFT (0U) |
| #define | TMR_CNTR_COUNTER(x) (((uint16_t)(((uint16_t)(x)) << TMR_CNTR_COUNTER_SHIFT)) & TMR_CNTR_COUNTER_MASK) |
CMPLD1 - Timer Channel Comparator Load Register 1 | |
| #define | TMR_CMPLD1_COMPARATOR_LOAD_1_MASK (0xFFFFU) |
| #define | TMR_CMPLD1_COMPARATOR_LOAD_1_SHIFT (0U) |
| #define | TMR_CMPLD1_COMPARATOR_LOAD_1(x) (((uint16_t)(((uint16_t)(x)) << TMR_CMPLD1_COMPARATOR_LOAD_1_SHIFT)) & TMR_CMPLD1_COMPARATOR_LOAD_1_MASK) |
CMPLD2 - Timer Channel Comparator Load Register 2 | |
| #define | TMR_CMPLD2_COMPARATOR_LOAD_2_MASK (0xFFFFU) |
| #define | TMR_CMPLD2_COMPARATOR_LOAD_2_SHIFT (0U) |
| #define | TMR_CMPLD2_COMPARATOR_LOAD_2(x) (((uint16_t)(((uint16_t)(x)) << TMR_CMPLD2_COMPARATOR_LOAD_2_SHIFT)) & TMR_CMPLD2_COMPARATOR_LOAD_2_MASK) |
| #define TMR_CAPT_CAPTURE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CAPT_CAPTURE_SHIFT)) & TMR_CAPT_CAPTURE_MASK) |
CAPTURE - Capture Value
| #define TMR_CMPLD1_COMPARATOR_LOAD_1 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CMPLD1_COMPARATOR_LOAD_1_SHIFT)) & TMR_CMPLD1_COMPARATOR_LOAD_1_MASK) |
COMPARATOR_LOAD_1 - COMPARATOR_LOAD_1
| #define TMR_CMPLD2_COMPARATOR_LOAD_2 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CMPLD2_COMPARATOR_LOAD_2_SHIFT)) & TMR_CMPLD2_COMPARATOR_LOAD_2_MASK) |
COMPARATOR_LOAD_2 - COMPARATOR_LOAD_2
| #define TMR_CNTR_COUNTER | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CNTR_COUNTER_SHIFT)) & TMR_CNTR_COUNTER_MASK) |
COUNTER - COUNTER
COUNTER - COUNTER
| #define TMR_COMP1_COMPARISON_1 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_COMP1_COMPARISON_1_SHIFT)) & TMR_COMP1_COMPARISON_1_MASK) |
COMPARISON_1 - Comparison Value 1
| #define TMR_COMP2_COMPARISON_2 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_COMP2_COMPARISON_2_SHIFT)) & TMR_COMP2_COMPARISON_2_MASK) |
COMPARISON_2 - Comparison Value 2
| #define TMR_CSCTRL_ALT_LOAD | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_ALT_LOAD_SHIFT)) & TMR_CSCTRL_ALT_LOAD_MASK) |
ALT_LOAD - Alternative Load Enable 0b0..Counter can be re-initialized only with the LOAD register. 0b1..Counter can be re-initialized with the LOAD or CMPLD2 registers depending on count direction.
| #define TMR_CSCTRL_CL1 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_CL1_SHIFT)) & TMR_CSCTRL_CL1_MASK) |
CL1 - Compare Load Control 1 0b00..Never preload 0b01..Load upon successful compare with the value in COMP1 0b10..Load upon successful compare with the value in COMP2 0b11..Reserved
| #define TMR_CSCTRL_CL2 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_CL2_SHIFT)) & TMR_CSCTRL_CL2_MASK) |
CL2 - Compare Load Control 2 0b00..Never preload 0b01..Load upon successful compare with the value in COMP1 0b10..Load upon successful compare with the value in COMP2 0b11..Reserved
| #define TMR_CSCTRL_DBG_EN | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_DBG_EN_SHIFT)) & TMR_CSCTRL_DBG_EN_MASK) |
DBG_EN - Debug Actions Enable 0b00..Continue with normal operation during debug mode. (default) 0b01..Halt TMR counter during debug mode. 0b10..Force TMR output to logic 0 (prior to consideration of SCTRL[OPS]). 0b11..Both halt counter and force output to 0 during debug mode.
| #define TMR_CSCTRL_FAULT | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_FAULT_SHIFT)) & TMR_CSCTRL_FAULT_MASK) |
FAULT - Fault Enable 0b0..Fault function disabled. 0b1..Fault function enabled.
| #define TMR_CSCTRL_ROC | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_ROC_SHIFT)) & TMR_CSCTRL_ROC_MASK) |
ROC - Reload on Capture 0b0..Do not reload the counter on a capture event. 0b1..Reload the counter on a capture event.
| #define TMR_CSCTRL_TCF1 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF1_SHIFT)) & TMR_CSCTRL_TCF1_MASK) |
TCF1 - Timer Compare 1 Interrupt Flag
| #define TMR_CSCTRL_TCF1EN | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF1EN_SHIFT)) & TMR_CSCTRL_TCF1EN_MASK) |
TCF1EN - Timer Compare 1 Interrupt Enable
| #define TMR_CSCTRL_TCF2 | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF2_SHIFT)) & TMR_CSCTRL_TCF2_MASK) |
TCF2 - Timer Compare 2 Interrupt Flag
| #define TMR_CSCTRL_TCF2EN | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCF2EN_SHIFT)) & TMR_CSCTRL_TCF2EN_MASK) |
TCF2EN - Timer Compare 2 Interrupt Enable
| #define TMR_CSCTRL_TCI | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_TCI_SHIFT)) & TMR_CSCTRL_TCI_MASK) |
TCI - Triggered Count Initialization Control 0b0..Stop counter upon receiving a second trigger event while still counting from the first trigger event. 0b1..Reload the counter upon receiving a second trigger event while still counting from the first trigger event.
| #define TMR_CSCTRL_UP | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CSCTRL_UP_SHIFT)) & TMR_CSCTRL_UP_MASK) |
UP - Counting Direction Indicator 0b0..The last count was in the DOWN direction. 0b1..The last count was in the UP direction.
| #define TMR_CTRL_CM | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_CM_SHIFT)) & TMR_CTRL_CM_MASK) |
CM - Count Mode 0b000..No operation 0b001..Count rising edges of primary sourceRising edges are counted only when SCTRL[IPS] = 0. Falling edges are counted when SCTRL[IPS] = 1. If the primary count source is IP bus clock divide by 1, only rising edges are counted regardless of the value of SCTRL[IPS]. 0b010..Count rising and falling edges of primary sourceIP bus clock divide by 1 cannot be used as a primary count source in edge count mode. 0b011..Count rising edges of primary source while secondary input high active 0b100..Quadrature count mode, uses primary and secondary sources 0b101..Count rising edges of primary source; secondary source specifies directionRising edges are counted only when SCTRL[IPS] = 0. Falling edges are counted when SCTRL[IPS] = 1. 0b110..Edge of secondary source triggers primary count until compare 0b111..Cascaded counter mode (up/down)The primary count source must be set to one of the counter outputs.
| #define TMR_CTRL_COINIT | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_COINIT_SHIFT)) & TMR_CTRL_COINIT_MASK) |
COINIT - Co-Channel Initialization 0b0..Co-channel counter/timers cannot force a re-initialization of this counter/timer 0b1..Co-channel counter/timers may force a re-initialization of this counter/timer
| #define TMR_CTRL_DIR | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_DIR_SHIFT)) & TMR_CTRL_DIR_MASK) |
DIR - Count Direction 0b0..Count up. 0b1..Count down.
| #define TMR_CTRL_LENGTH | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_LENGTH_SHIFT)) & TMR_CTRL_LENGTH_MASK) |
LENGTH - Count Length 0b0..Count until roll over at $FFFF and continue from $0000. 0b1..Count until compare, then re-initialize. If counting up, a successful compare occurs when the counter reaches a COMP1 value. If counting down, a successful compare occurs when the counter reaches a COMP2 value. When output mode $4 is used, alternating values of COMP1 and COMP2 are used to generate successful comparisons. For example, the counter counts until a COMP1 value is reached, re-initializes, counts until COMP2 value is reached, re-initializes, counts until COMP1 value is reached, and so on.
| #define TMR_CTRL_ONCE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_ONCE_SHIFT)) & TMR_CTRL_ONCE_MASK) |
ONCE - Count Once 0b0..Count repeatedly. 0b1..Count until compare and then stop. If counting up, a successful compare occurs when the counter reaches a COMP1 value. If counting down, a successful compare occurs when the counter reaches a COMP2 value. When output mode $4 is used, the counter re-initializes after reaching the COMP1 value, continues to count to the COMP2 value, and then stops.
| #define TMR_CTRL_OUTMODE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_OUTMODE_SHIFT)) & TMR_CTRL_OUTMODE_MASK) |
OUTMODE - Output Mode 0b000..Asserted while counter is active 0b001..Clear OFLAG output on successful compare 0b010..Set OFLAG output on successful compare 0b011..Toggle OFLAG output on successful compare 0b100..Toggle OFLAG output using alternating compare registers 0b101..Set on compare, cleared on secondary source input edge 0b110..Set on compare, cleared on counter rollover 0b111..Enable gated clock output while counter is active
| #define TMR_CTRL_PCS | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_PCS_SHIFT)) & TMR_CTRL_PCS_MASK) |
PCS - Primary Count Source 0b0000..Counter 0 input pin 0b0001..Counter 1 input pin 0b0010..Counter 2 input pin 0b0011..Counter 3 input pin 0b0100..Counter 0 output 0b0101..Counter 1 output 0b0110..Counter 2 output 0b0111..Counter 3 output 0b1000..IP bus clock divide by 1 prescaler 0b1001..IP bus clock divide by 2 prescaler 0b1010..IP bus clock divide by 4 prescaler 0b1011..IP bus clock divide by 8 prescaler 0b1100..IP bus clock divide by 16 prescaler 0b1101..IP bus clock divide by 32 prescaler 0b1110..IP bus clock divide by 64 prescaler 0b1111..IP bus clock divide by 128 prescaler
| #define TMR_CTRL_SCS | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_CTRL_SCS_SHIFT)) & TMR_CTRL_SCS_MASK) |
SCS - Secondary Count Source 0b00..Counter 0 input pin 0b01..Counter 1 input pin 0b10..Counter 2 input pin 0b11..Counter 3 input pin
| #define TMR_DMA_CMPLD1DE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_DMA_CMPLD1DE_SHIFT)) & TMR_DMA_CMPLD1DE_MASK) |
CMPLD1DE - Comparator Preload Register 1 DMA Enable
| #define TMR_DMA_CMPLD2DE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_DMA_CMPLD2DE_SHIFT)) & TMR_DMA_CMPLD2DE_MASK) |
CMPLD2DE - Comparator Preload Register 2 DMA Enable
| #define TMR_DMA_IEFDE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_DMA_IEFDE_SHIFT)) & TMR_DMA_IEFDE_MASK) |
IEFDE - Input Edge Flag DMA Enable
| #define TMR_ENBL_ENBL | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_ENBL_ENBL_SHIFT)) & TMR_ENBL_ENBL_MASK) |
ENBL - Timer Channel Enable 0b0000..Timer channel is disabled. 0b0001..Timer channel is enabled. (default)
| #define TMR_FILT_FILT_CNT | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_FILT_FILT_CNT_SHIFT)) & TMR_FILT_FILT_CNT_MASK) |
FILT_CNT - Input Filter Sample Count
| #define TMR_FILT_FILT_PER | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_FILT_FILT_PER_SHIFT)) & TMR_FILT_FILT_PER_MASK) |
FILT_PER - Input Filter Sample Period
| #define TMR_HOLD_HOLD | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_HOLD_HOLD_SHIFT)) & TMR_HOLD_HOLD_MASK) |
HOLD - HOLD
HOLD - HOLD
| #define TMR_LOAD_LOAD | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_LOAD_LOAD_SHIFT)) & TMR_LOAD_LOAD_MASK) |
LOAD - Timer Load Register
| #define TMR_SCTRL_CAPTURE_MODE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_CAPTURE_MODE_SHIFT)) & TMR_SCTRL_CAPTURE_MODE_MASK) |
CAPTURE_MODE - Input Capture Mode 0b00..Capture function is disabled 0b01..Load capture register on rising edge (when IPS=0) or falling edge (when IPS=1) of input 0b10..Load capture register on falling edge (when IPS=0) or rising edge (when IPS=1) of input 0b11..Load capture register on both edges of input
| #define TMR_SCTRL_EEOF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_EEOF_SHIFT)) & TMR_SCTRL_EEOF_MASK) |
EEOF - Enable External OFLAG Force
| #define TMR_SCTRL_FORCE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_FORCE_SHIFT)) & TMR_SCTRL_FORCE_MASK) |
FORCE - Force OFLAG Output
| #define TMR_SCTRL_IEF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_IEF_SHIFT)) & TMR_SCTRL_IEF_MASK) |
IEF - Input Edge Flag
| #define TMR_SCTRL_IEFIE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_IEFIE_SHIFT)) & TMR_SCTRL_IEFIE_MASK) |
IEFIE - Input Edge Flag Interrupt Enable
| #define TMR_SCTRL_INPUT | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_INPUT_SHIFT)) & TMR_SCTRL_INPUT_MASK) |
INPUT - External Input Signal
| #define TMR_SCTRL_IPS | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_IPS_SHIFT)) & TMR_SCTRL_IPS_MASK) |
IPS - Input Polarity Select
| #define TMR_SCTRL_MSTR | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_MSTR_SHIFT)) & TMR_SCTRL_MSTR_MASK) |
MSTR - Master Mode
MSTR - Master Mode
MSTR - Master Mode
| #define TMR_SCTRL_OEN | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_OEN_SHIFT)) & TMR_SCTRL_OEN_MASK) |
OEN - Output Enable 0b0..The external pin is configured as an input. 0b1..The OFLAG output signal is driven on the external pin. Other timer groups using this external pin as their input see the driven value. The polarity of the signal is determined by OPS.
| #define TMR_SCTRL_OPS | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_OPS_SHIFT)) & TMR_SCTRL_OPS_MASK) |
OPS - Output Polarity Select 0b0..True polarity. 0b1..Inverted polarity.
| #define TMR_SCTRL_TCF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TCF_SHIFT)) & TMR_SCTRL_TCF_MASK) |
TCF - Timer Compare Flag
| #define TMR_SCTRL_TCFIE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TCFIE_SHIFT)) & TMR_SCTRL_TCFIE_MASK) |
TCFIE - Timer Compare Flag Interrupt Enable
| #define TMR_SCTRL_TOF | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TOF_SHIFT)) & TMR_SCTRL_TOF_MASK) |
TOF - Timer Overflow Flag
| #define TMR_SCTRL_TOFIE | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_TOFIE_SHIFT)) & TMR_SCTRL_TOFIE_MASK) |
TOFIE - Timer Overflow Flag Interrupt Enable
| #define TMR_SCTRL_VAL | ( | x | ) | (((uint16_t)(((uint16_t)(x)) << TMR_SCTRL_VAL_SHIFT)) & TMR_SCTRL_VAL_MASK) |
VAL - Forced OFLAG Value
