RTEMS 6.1-rc8
| #define | __HAL_SMBUS_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SMBUS_STATE_RESET) |
| Reset SMBUS handle state. | |
| #define | __HAL_SMBUS_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__)) |
| Enable the specified SMBUS interrupts. | |
| #define | __HAL_SMBUS_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__))) |
| Disable the specified SMBUS interrupts. | |
| #define | __HAL_SMBUS_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((((__HANDLE__)->Instance->CR1 & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET) |
| Check whether the specified SMBUS interrupt source is enabled or not. | |
| #define | SMBUS_FLAG_MASK (0x0001FFFFU) |
| Check whether the specified SMBUS flag is set or not. | |
| #define | __HAL_SMBUS_GET_FLAG(__HANDLE__, __FLAG__) |
| #define | __HAL_SMBUS_CLEAR_FLAG(__HANDLE__, __FLAG__) |
| Clear the SMBUS pending flags which are cleared by writing 1 in a specific bit. | |
| #define | __HAL_SMBUS_ENABLE(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| Enable the specified SMBUS peripheral. | |
| #define | __HAL_SMBUS_DISABLE(__HANDLE__) (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| Disable the specified SMBUS peripheral. | |
| #define | __HAL_SMBUS_GENERATE_NACK(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK)) |
| Generate a Non-Acknowledge SMBUS peripheral in Slave mode. | |
| #define __HAL_SMBUS_CLEAR_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| __HANDLE__ | specifies the SMBUS Handle. |
| __FLAG__ | specifies the flag to clear. This parameter can be any combination of the following values:
| None |
| #define __HAL_SMBUS_DISABLE | ( | __HANDLE__ | ) | (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| None |
| #define __HAL_SMBUS_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__))) |
| __INTERRUPT__ | specifies the interrupt source to disable. This parameter can be one of the following values:
| None |
| #define __HAL_SMBUS_ENABLE | ( | __HANDLE__ | ) | (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE)) |
| None |
| #define __HAL_SMBUS_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__)) |
| __INTERRUPT__ | specifies the interrupt source to enable. This parameter can be one of the following values:
| None |
| #define __HAL_SMBUS_GENERATE_NACK | ( | __HANDLE__ | ) | (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK)) |
| None |
| #define __HAL_SMBUS_GET_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| #define __HAL_SMBUS_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| ) | ((((__HANDLE__)->Instance->CR1 & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET) |
| __INTERRUPT__ | specifies the SMBUS interrupt source to check. This parameter can be one of the following values:
| The | new state of IT (SET or RESET). |
| #define __HAL_SMBUS_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_SMBUS_STATE_RESET) |
| None |
| #define SMBUS_FLAG_MASK (0x0001FFFFU) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of FLAG (SET or RESET). |
