RTEMS 6.1-rc8
This group contains the BSP for the Application Processing Unit (APU) contained in AMD Zynq UltraScale+ MPSoC and RFSoC devices. More...
Files | |
| file | console.c |
| This source file contains this BSP's console configuration. | |
| file | management_apu.c |
| This source file contains the management console implementation. | |
| file | management_cfc400x.c |
| file | cache.c |
| This source file contains the implementation of zynqmp_ecc_init(). | |
| file | ddr.c |
| This source file contains the implementation of DDR ECC support. | |
| file | ocm.c |
| This source file contains the implementation of OCM ECC support. | |
| file | bsp_fdt.c |
| This source file contains the implementatin of bsp_fdt_get(). | |
| file | bsp.h |
| This header file provides BSP-specific interfaces. | |
| file | ecc.h |
| This header file provides internal APIs for managing ECC events. | |
| file | ecc_priv.h |
| file | irq.h |
| This header file provides the BSP's IRQ definitions. | |
| file | jffs2_xqspipsu.h |
| XilinxZynqMP QSPI JFFS2 flash driver definitions. | |
| file | xil-compat.h |
| file | tm27.h |
| This header file provides functionality for the tm27 test. | |
| file | bspstart.c |
| This source file contains the implementation of bsp_start(). | |
| file | bspstartecc_cfc400x.c |
| This source file contains the implementation of zynqmp_ecc_init_bsp(). | |
| file | bspstartecc_hw.c |
| file | bspstartecc_qemu.c |
| file | bspstartecc_zu3eg.c |
| file | bspstarthooks.c |
| This source file contains the implementation of this BSP's startup hooks. | |
| file | bspstartmmu.c |
| This source file contains the default MMU tables and setup. | |
| file | i2c-clocks.c |
| This source file contains the implementation of zynqmp_clock_i2c0() and zynqmp_clock_i2c1(). | |
| file | mmu-config.c |
| This source file contains the definition of aarch64_mmu_config_table and aarch64_mmu_config_table_size. | |
| #define | BSP_ARM_GIC_CPUIF_BASE 0xf9020000 |
| #define | BSP_ARM_GIC_DIST_BASE 0xf9010000 |
| #define | BSP_FDT_IS_SUPPORTED |
| #define | NANDPSU_BASEADDR 0xFF100000 |
| BSP_START_TEXT_SECTION void | zynqmp_setup_mmu_and_cache (void) |
| Zynq UltraScale+ MPSoC specific set up of the MMU. | |
| BSP_START_TEXT_SECTION void | zynqmp_setup_secondary_cpu_mmu_and_cache (void) |
| Zynq UltraScale+ MPSoC specific set up of the MMU for non-primary cores. | |
| void | zynqmp_management_console_termios_init (void) |
| void | zynqmp_debug_console_flush (void) |
| uint32_t | zynqmp_clock_i2c0 (void) |
| uint32_t | zynqmp_clock_i2c1 (void) |
| void | zynqmp_configure_management_console (struct rtems_termios_device_context *base) |
| Zynq UltraScale+ MPSoC specific set up of a management console. | |
| unsigned int | zynqmp_dtb_len |
| unsigned char | zynqmp_dtb [] |
| void zynqmp_configure_management_console | ( | struct rtems_termios_device_context * | base | ) |
Some systems may have a management interface which needs special initialization. Provide in the application to override the defaults in the BSP. This will only be called if the interface is found in the device tree.
| BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache | ( | void | ) |
| BSP_START_TEXT_SECTION void zynqmp_setup_secondary_cpu_mmu_and_cache | ( | void | ) |
