RTEMS 6.1-rc8
Modules | |
| RCCEx CRS Extended Features | |
| #define | __HAL_RCC_PLL2_ENABLE() SET_BIT(RCC->CR, RCC_CR_PLL2ON) |
| Macros to enable or disable PLL2. | |
| #define | __HAL_RCC_PLL2_DISABLE() CLEAR_BIT(RCC->CR, RCC_CR_PLL2ON) |
| #define | __HAL_RCC_PLL2CLKOUT_ENABLE(__RCC_PLL2ClockOut__) SET_BIT(RCC->PLLCFGR, (__RCC_PLL2ClockOut__)) |
| Enables or disables each clock output (PLL2_P_CLK, PLL2_Q_CLK, PLL2_R_CLK) | |
| #define | __HAL_RCC_PLL2CLKOUT_DISABLE(__RCC_PLL2ClockOut__) CLEAR_BIT(RCC->PLLCFGR, (__RCC_PLL2ClockOut__)) |
| #define | __HAL_RCC_PLL2FRACN_ENABLE() SET_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLL2FRACEN) |
| Enables or disables Fractional Part Of The Multiplication Factor of PLL2 VCO. | |
| #define | __HAL_RCC_PLL2FRACN_DISABLE() CLEAR_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLL2FRACEN) |
| #define | __HAL_RCC_PLL2_CONFIG(__PLL2M__, __PLL2N__, __PLL2P__, __PLL2Q__, __PLL2R__) |
| Macro to configures the PLL2 multiplication and division factors. | |
| #define | __HAL_RCC_PLL2FRACN_CONFIG(__RCC_PLL2FRACN__) MODIFY_REG(RCC->PLL2FRACR, RCC_PLL2FRACR_FRACN2,((uint32_t)(__RCC_PLL2FRACN__) << RCC_PLL2FRACR_FRACN2_Pos)) |
| Macro to configures PLL2 clock Fractional Part Of The Multiplication Factor. | |
| #define | __HAL_RCC_PLL2_VCIRANGE(__RCC_PLL2VCIRange__) MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL2RGE, (__RCC_PLL2VCIRange__)) |
| Macro to select the PLL2 reference frequency range. | |
| #define | __HAL_RCC_PLL2_VCORANGE(__RCC_PLL2VCORange__) MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL2VCOSEL, (__RCC_PLL2VCORange__)) |
| #define | __HAL_RCC_PLL3_ENABLE() SET_BIT(RCC->CR, RCC_CR_PLL3ON) |
| Macros to enable or disable the main PLL3. | |
| #define | __HAL_RCC_PLL3_DISABLE() CLEAR_BIT(RCC->CR, RCC_CR_PLL3ON) |
| #define | __HAL_RCC_PLL3FRACN_ENABLE() SET_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLL3FRACEN) |
| Enables or disables Fractional Part Of The Multiplication Factor of PLL3 VCO. | |
| #define | __HAL_RCC_PLL3FRACN_DISABLE() CLEAR_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLL3FRACEN) |
| #define | __HAL_RCC_PLL3CLKOUT_ENABLE(__RCC_PLL3ClockOut__) SET_BIT(RCC->PLLCFGR, (__RCC_PLL3ClockOut__)) |
| Enables or disables each clock output (PLL3_P_CLK, PLL3_Q_CLK, PLL3_R_CLK) | |
| #define | __HAL_RCC_PLL3CLKOUT_DISABLE(__RCC_PLL3ClockOut__) CLEAR_BIT(RCC->PLLCFGR, (__RCC_PLL3ClockOut__)) |
| #define | __HAL_RCC_PLL3_CONFIG(__PLL3M__, __PLL3N__, __PLL3P__, __PLL3Q__, __PLL3R__) |
| Macro to configures the PLL3 multiplication and division factors. | |
| #define | __HAL_RCC_PLL3FRACN_CONFIG(__RCC_PLL3FRACN__) MODIFY_REG(RCC->PLL3FRACR, RCC_PLL3FRACR_FRACN3, (uint32_t)(__RCC_PLL3FRACN__) << RCC_PLL3FRACR_FRACN3_Pos) |
| Macro to configures PLL3 clock Fractional Part of The Multiplication Factor. | |
| #define | __HAL_RCC_PLL3_VCIRANGE(__RCC_PLL3VCIRange__) MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL3RGE, (__RCC_PLL3VCIRange__)) |
| Macro to select the PLL3 reference frequency range. | |
| #define | __HAL_RCC_PLL3_VCORANGE(__RCC_PLL3VCORange__) MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL3VCOSEL, (__RCC_PLL3VCORange__)) |
| #define | __HAL_RCC_SAI1_CONFIG(__RCC_SAI1CLKSource__) MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SAI1SEL, (__RCC_SAI1CLKSource__)) |
| Macro to Configure the SAI1 clock source. | |
| #define | __HAL_RCC_GET_SAI1_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SAI1SEL))) |
| Macro to get the SAI1 clock source. | |
| #define | __HAL_RCC_SPDIFRX_CONFIG(__RCC_SPDIFCLKSource__) MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SPDIFSEL, (__RCC_SPDIFCLKSource__)) |
| Macro to Configure the SPDIFRX clock source. | |
| #define | __HAL_RCC_GET_SPDIFRX_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SPDIFSEL))) |
| Macro to get the SPDIFRX clock source. | |
| #define | __HAL_RCC_I2C1235_CONFIG(__I2C1235CLKSource__) MODIFY_REG(RCC->D2CCIP2R, RCC_D2CCIP2R_I2C1235SEL, (uint32_t)(__I2C1235CLKSource__)) |
| macro to configure the I2C1/2/3/5* clock (I2C123CLK). | |
| #define | __HAL_RCC_I2C123_CONFIG __HAL_RCC_I2C1235_CONFIG |
| #define | __HAL_RCC_GET_I2C1235_SOURCE() ((uint32_t)(READ_BIT(RCC->D2CCIP2R, RCC_D2CCIP2R_I2C1235SEL))) |
| macro to get the I2C1/2/3/5* clock source. | |
| #define | __HAL_RCC_GET_I2C123_SOURCE __HAL_RCC_GET_I2C1235_SOURCE |
| #define | __HAL_RCC_I2C1_CONFIG __HAL_RCC_I2C123_CONFIG |
| macro to configure the I2C1 clock (I2C1CLK). | |
| #define | __HAL_RCC_GET_I2C1_SOURCE __HAL_RCC_GET_I2C123_SOURCE |
| macro to get the I2C1 clock source. | |
| #define | __HAL_RCC_I2C2_CONFIG __HAL_RCC_I2C123_CONFIG |
| macro to configure the I2C2 clock (I2C2CLK). | |
| #define | __HAL_RCC_GET_I2C2_SOURCE __HAL_RCC_GET_I2C123_SOURCE |
| macro to get the I2C2 clock source. | |
| #define | __HAL_RCC_I2C3_CONFIG __HAL_RCC_I2C123_CONFIG |
| macro to configure the I2C3 clock (I2C3CLK). | |
| #define | __HAL_RCC_GET_I2C3_SOURCE __HAL_RCC_GET_I2C123_SOURCE |
| macro to get the I2C3 clock source. | |
| #define | __HAL_RCC_I2C4_CONFIG(__I2C4CLKSource__) MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_I2C4SEL, (uint32_t)(__I2C4CLKSource__)) |
| macro to configure the I2C4 clock (I2C4CLK). | |
| #define | __HAL_RCC_GET_I2C4_SOURCE() ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_I2C4SEL))) |
| macro to get the I2C4 clock source. | |
| #define | __HAL_RCC_USART16910_CONFIG(__USART16910CLKSource__) MODIFY_REG(RCC->D2CCIP2R, RCC_D2CCIP2R_USART16910SEL, (uint32_t)(__USART16910CLKSource__)) |
| macro to configure the USART1/6/9* /10* clock (USART16CLK). | |
| #define | __HAL_RCC_USART16_CONFIG __HAL_RCC_USART16910_CONFIG |
| #define | __HAL_RCC_GET_USART16910_SOURCE() ((uint32_t)(READ_BIT(RCC->D2CCIP2R, RCC_D2CCIP2R_USART16910SEL))) |
| macro to get the USART1/6/9* /10* clock source. | |
| #define | __HAL_RCC_GET_USART16_SOURCE __HAL_RCC_GET_USART16910_SOURCE |
| #define | __HAL_RCC_USART234578_CONFIG(__USART234578CLKSource__) MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_USART234578SEL, (uint32_t)(__USART234578CLKSource__)) |
| macro to configure the USART234578 clock (USART234578CLK). | |
| #define | __HAL_RCC_GET_USART234578_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_USART234578SEL))) |
| macro to get the USART2/3/4/5/7/8 clock source. | |
| #define | __HAL_RCC_USART1_CONFIG __HAL_RCC_USART16_CONFIG |
| macro to configure the USART1 clock (USART1CLK). | |
| #define | __HAL_RCC_GET_USART1_SOURCE __HAL_RCC_GET_USART16_SOURCE |
| macro to get the USART1 clock source. | |
| #define | __HAL_RCC_USART2_CONFIG __HAL_RCC_USART234578_CONFIG |
| macro to configure the USART2 clock (USART2CLK). | |
| #define | __HAL_RCC_GET_USART2_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| macro to get the USART2 clock source. | |
| #define | __HAL_RCC_USART3_CONFIG __HAL_RCC_USART234578_CONFIG |
| macro to configure the USART3 clock (USART3CLK). | |
| #define | __HAL_RCC_GET_USART3_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| macro to get the USART3 clock source. | |
| #define | __HAL_RCC_UART4_CONFIG __HAL_RCC_USART234578_CONFIG |
| macro to configure the UART4 clock (UART4CLK). | |
| #define | __HAL_RCC_GET_UART4_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| macro to get the UART4 clock source. | |
| #define | __HAL_RCC_UART5_CONFIG __HAL_RCC_USART234578_CONFIG |
| macro to configure the UART5 clock (UART5CLK). | |
| #define | __HAL_RCC_GET_UART5_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| macro to get the UART5 clock source. | |
| #define | __HAL_RCC_USART6_CONFIG __HAL_RCC_USART16_CONFIG |
| macro to configure the USART6 clock (USART6CLK). | |
| #define | __HAL_RCC_GET_USART6_SOURCE __HAL_RCC_GET_USART16_SOURCE |
| macro to get the USART6 clock source. | |
| #define | __HAL_RCC_UART7_CONFIG __HAL_RCC_USART234578_CONFIG |
| macro to configure the UART5 clock (UART7CLK). | |
| #define | __HAL_RCC_GET_UART7_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| macro to get the UART7 clock source. | |
| #define | __HAL_RCC_UART8_CONFIG __HAL_RCC_USART234578_CONFIG |
| macro to configure the UART8 clock (UART8CLK). | |
| #define | __HAL_RCC_GET_UART8_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| macro to get the UART8 clock source. | |
| #define | __HAL_RCC_LPUART1_CONFIG(__LPUART1CLKSource__) MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_LPUART1SEL, (uint32_t)(__LPUART1CLKSource__)) |
| macro to configure the LPUART1 clock (LPUART1CLK). | |
| #define | __HAL_RCC_GET_LPUART1_SOURCE() ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_LPUART1SEL))) |
| macro to get the LPUART1 clock source. | |
| #define | __HAL_RCC_LPTIM1_CONFIG(__LPTIM1CLKSource__) MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_LPTIM1SEL, (uint32_t)(__LPTIM1CLKSource__)) |
| macro to configure the LPTIM1 clock source. | |
| #define | __HAL_RCC_GET_LPTIM1_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_LPTIM1SEL))) |
| macro to get the LPTIM1 clock source. | |
| #define | __HAL_RCC_LPTIM2_CONFIG(__LPTIM2CLKSource__) MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM2SEL, (uint32_t)(__LPTIM2CLKSource__)) |
| macro to configure the LPTIM2 clock source. | |
| #define | __HAL_RCC_GET_LPTIM2_SOURCE() ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM2SEL))) |
| macro to get the LPTIM2 clock source. | |
| #define | __HAL_RCC_LPTIM345_CONFIG(__LPTIM345CLKSource__) MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM3SEL, (uint32_t)(__LPTIM345CLKSource__)) |
| macro to configure the LPTIM3/4/5 clock source. | |
| #define | __HAL_RCC_GET_LPTIM345_SOURCE() ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM3SEL))) |
| macro to get the LPTIM3/4/5 clock source. | |
| #define | __HAL_RCC_LPTIM3_CONFIG __HAL_RCC_LPTIM345_CONFIG |
| macro to configure the LPTIM3 clock source. | |
| #define | __HAL_RCC_GET_LPTIM3_SOURCE __HAL_RCC_GET_LPTIM345_SOURCE |
| macro to get the LPTIM3 clock source. | |
| #define | __HAL_RCC_FMC_CONFIG(__FMCCLKSource__) MODIFY_REG(RCC->CDCCIPR, RCC_CDCCIPR_FMCSEL, (uint32_t)(__FMCCLKSource__)) |
| macro to configure the FMC clock source. | |
| #define | __HAL_RCC_GET_FMC_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIPR, RCC_CDCCIPR_FMCSEL))) |
| macro to get the FMC clock source. | |
| #define | __HAL_RCC_USB_CONFIG(__USBCLKSource__) MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_USBSEL, (uint32_t)(__USBCLKSource__)) |
| Macro to configure the USB clock (USBCLK). | |
| #define | __HAL_RCC_GET_USB_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_USBSEL))) |
| Macro to get the USB clock source. | |
| #define | __HAL_RCC_ADC_CONFIG(__ADCCLKSource__) MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_ADCSEL, (uint32_t)(__ADCCLKSource__)) |
| Macro to configure the ADC clock. | |
| #define | __HAL_RCC_GET_ADC_SOURCE() ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_ADCSEL))) |
| Macro to get the ADC clock source. | |
| #define | __HAL_RCC_SWPMI1_CONFIG(__SWPMI1CLKSource__) MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SWPSEL, (uint32_t)(__SWPMI1CLKSource__)) |
| Macro to configure the SWPMI1 clock. | |
| #define | __HAL_RCC_GET_SWPMI1_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SWPSEL))) |
| Macro to get the SWPMI1 clock source. | |
| #define | __HAL_RCC_DFSDM1_CONFIG(__DFSDM1CLKSource__) MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_DFSDM1SEL, (uint32_t)(__DFSDM1CLKSource__)) |
| Macro to configure the DFSDM1 clock. | |
| #define | __HAL_RCC_GET_DFSDM1_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_DFSDM1SEL))) |
| Macro to get the DFSDM1 clock source. | |
| #define | __HAL_RCC_CEC_CONFIG(__CECCLKSource__) MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_CECSEL, (uint32_t)(__CECCLKSource__)) |
| macro to configure the CEC clock (CECCLK). | |
| #define | __HAL_RCC_GET_CEC_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_CECSEL))) |
| macro to get the CEC clock source. | |
| #define | __HAL_RCC_CLKP_CONFIG(__CLKPSource__) MODIFY_REG(RCC->CDCCIPR, RCC_CDCCIPR_CKPERSEL, (uint32_t)(__CLKPSource__)) |
| Macro to configure the CLKP : Oscillator clock for peripheral. | |
| #define | __HAL_RCC_GET_CLKP_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIPR, RCC_CDCCIPR_CKPERSEL))) |
| Macro to get the Oscillator clock for peripheral source. | |
| #define | __HAL_RCC_SPI123_CONFIG(__RCC_SPI123CLKSource__) MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI123SEL, (__RCC_SPI123CLKSource__)) |
| Macro to Configure the SPI1/2/3 clock source. | |
| #define | __HAL_RCC_GET_SPI123_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI123SEL))) |
| Macro to get the SPI1/2/3 clock source. | |
| #define | __HAL_RCC_SPI1_CONFIG __HAL_RCC_SPI123_CONFIG |
| Macro to Configure the SPI1 clock source. | |
| #define | __HAL_RCC_GET_SPI1_SOURCE __HAL_RCC_GET_SPI123_SOURCE |
| Macro to get the SPI1 clock source. | |
| #define | __HAL_RCC_SPI2_CONFIG __HAL_RCC_SPI123_CONFIG |
| Macro to Configure the SPI2 clock source. | |
| #define | __HAL_RCC_GET_SPI2_SOURCE __HAL_RCC_GET_SPI123_SOURCE |
| Macro to get the SPI2 clock source. | |
| #define | __HAL_RCC_SPI3_CONFIG __HAL_RCC_SPI123_CONFIG |
| Macro to Configure the SPI3 clock source. | |
| #define | __HAL_RCC_GET_SPI3_SOURCE __HAL_RCC_GET_SPI123_SOURCE |
| Macro to get the SPI3 clock source. | |
| #define | __HAL_RCC_SPI45_CONFIG(__RCC_SPI45CLKSource__) MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI45SEL, (__RCC_SPI45CLKSource__)) |
| Macro to Configure the SPI4/5 clock source. | |
| #define | __HAL_RCC_GET_SPI45_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI45SEL))) |
| Macro to get the SPI4/5 clock source. | |
| #define | __HAL_RCC_SPI4_CONFIG __HAL_RCC_SPI45_CONFIG |
| Macro to Configure the SPI4 clock source. | |
| #define | __HAL_RCC_GET_SPI4_SOURCE __HAL_RCC_GET_SPI45_SOURCE |
| Macro to get the SPI4 clock source. | |
| #define | __HAL_RCC_SPI5_CONFIG __HAL_RCC_SPI45_CONFIG |
| Macro to Configure the SPI5 clock source. | |
| #define | __HAL_RCC_GET_SPI5_SOURCE __HAL_RCC_GET_SPI45_SOURCE |
| Macro to get the SPI5 clock source. | |
| #define | __HAL_RCC_SPI6_CONFIG(__RCC_SPI6CLKSource__) MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_SPI6SEL, (__RCC_SPI6CLKSource__)) |
| Macro to Configure the SPI6 clock source. | |
| #define | __HAL_RCC_GET_SPI6_SOURCE() ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_SPI6SEL))) |
| Macro to get the SPI6 clock source. | |
| #define | __HAL_RCC_SDMMC_CONFIG(__SDMMCCLKSource__) MODIFY_REG(RCC->CDCCIPR, RCC_CDCCIPR_SDMMCSEL, (uint32_t)(__SDMMCCLKSource__)) |
| Macro to configure the SDMMC clock. | |
| #define | __HAL_RCC_GET_SDMMC_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIPR, RCC_CDCCIPR_SDMMCSEL))) |
| Macro to get the SDMMC clock. | |
| #define | __HAL_RCC_RNG_CONFIG(__RNGCLKSource__) MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_RNGSEL, (uint32_t)(__RNGCLKSource__)) |
| macro to configure the RNG clock (RNGCLK). | |
| #define | __HAL_RCC_GET_RNG_SOURCE() ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_RNGSEL))) |
| macro to get the RNG clock source. | |
| #define | __HAL_RCC_TIMCLKPRESCALER(__PRESC__) |
| Macro to configure the Timers clocks prescalers. | |
| #define | __HAL_RCC_LSECSS_EXTI_ENABLE_IT() SET_BIT(EXTI->IMR1, RCC_EXTI_LINE_LSECSS) |
| Enable the RCC LSE CSS Extended Interrupt Line. | |
| #define | __HAL_RCC_LSECSS_EXTI_DISABLE_IT() CLEAR_BIT(EXTI->IMR1, RCC_EXTI_LINE_LSECSS) |
| Disable the RCC LSE CSS Extended Interrupt Line. | |
| #define | __HAL_RCC_LSECSS_EXTI_ENABLE_EVENT() SET_BIT(EXTI->EMR1, RCC_EXTI_LINE_LSECSS) |
| Enable the RCC LSE CSS Event Line. | |
| #define | __HAL_RCC_LSECSS_EXTI_DISABLE_EVENT() CLEAR_BIT(EXTI->EMR1, RCC_EXTI_LINE_LSECSS) |
| Disable the RCC LSE CSS Event Line. | |
| #define | __HAL_RCC_LSECSS_EXTI_ENABLE_FALLING_EDGE() SET_BIT(EXTI->FTSR1, RCC_EXTI_LINE_LSECSS) |
| Enable the RCC LSE CSS Extended Interrupt Falling Trigger. | |
| #define | __HAL_RCC_LSECSS_EXTI_DISABLE_FALLING_EDGE() CLEAR_BIT(EXTI->FTSR1, RCC_EXTI_LINE_LSECSS) |
| Disable the RCC LSE CSS Extended Interrupt Falling Trigger. | |
| #define | __HAL_RCC_LSECSS_EXTI_ENABLE_RISING_EDGE() SET_BIT(EXTI->RTSR1, RCC_EXTI_LINE_LSECSS) |
| Enable the RCC LSE CSS Extended Interrupt Rising Trigger. | |
| #define | __HAL_RCC_LSECSS_EXTI_DISABLE_RISING_EDGE() CLEAR_BIT(EXTI->RTSR1, RCC_EXTI_LINE_LSECSS) |
| Disable the RCC LSE CSS Extended Interrupt Rising Trigger. | |
| #define | __HAL_RCC_LSECSS_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable the RCC LSE CSS Extended Interrupt Rising & Falling Trigger. | |
| #define | __HAL_RCC_LSECSS_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable the RCC LSE CSS Extended Interrupt Rising & Falling Trigger. | |
| #define | __HAL_RCC_LSECSS_EXTI_GET_FLAG() (READ_BIT(EXTI->PR1, RCC_EXTI_LINE_LSECSS) == RCC_EXTI_LINE_LSECSS) |
| Check whether the specified RCC LSE CSS EXTI interrupt flag is set or not. | |
| #define | __HAL_RCC_LSECSS_EXTI_CLEAR_FLAG() WRITE_REG(EXTI->PR1, RCC_EXTI_LINE_LSECSS) |
| Clear the RCC LSE CSS EXTI flag. | |
| #define | __HAL_RCC_LSECSS_EXTI_GENERATE_SWIT() SET_BIT(EXTI->SWIER1, RCC_EXTI_LINE_LSECSS) |
| Generate a Software interrupt on the RCC LSE CSS EXTI line. | |
| #define | __HAL_RCC_CRS_ENABLE_IT(__INTERRUPT__) SET_BIT(CRS->CR, (__INTERRUPT__)) |
| Enable the specified CRS interrupts. | |
| #define | __HAL_RCC_CRS_DISABLE_IT(__INTERRUPT__) CLEAR_BIT(CRS->CR, (__INTERRUPT__)) |
| Disable the specified CRS interrupts. | |
| #define | __HAL_RCC_CRS_GET_IT_SOURCE(__INTERRUPT__) ((READ_BIT(CRS->CR, (__INTERRUPT__)) != 0U) ? SET : RESET) |
| Check whether the CRS interrupt has occurred or not. | |
| #define | RCC_CRS_IT_ERROR_MASK ((uint32_t)(RCC_CRS_IT_TRIMOVF | RCC_CRS_IT_SYNCERR | RCC_CRS_IT_SYNCMISS)) |
| Clear the CRS interrupt pending bits. | |
| #define | __HAL_RCC_CRS_CLEAR_IT(__INTERRUPT__) |
| #define | __HAL_RCC_CRS_GET_FLAG(__FLAG__) (READ_BIT(CRS->ISR, (__FLAG__)) == (__FLAG__)) |
| Check whether the specified CRS flag is set or not. | |
| #define | RCC_CRS_FLAG_ERROR_MASK ((uint32_t)(RCC_CRS_FLAG_TRIMOVF | RCC_CRS_FLAG_SYNCERR | RCC_CRS_FLAG_SYNCMISS)) |
| Clear the CRS specified FLAG. | |
| #define | __HAL_RCC_CRS_CLEAR_FLAG(__FLAG__) |
| #define __HAL_RCC_ADC_CONFIG | ( | __ADCCLKSource__ | ) | MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_ADCSEL, (uint32_t)(__ADCCLKSource__)) |
| __ADCCLKSource__ | specifies the ADC digital interface clock source. This parameter can be one of the following values:
| #define __HAL_RCC_CEC_CONFIG | ( | __CECCLKSource__ | ) | MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_CECSEL, (uint32_t)(__CECCLKSource__)) |
| __CECCLKSource__ | specifies the CEC clock source. This parameter can be one of the following values:
| #define __HAL_RCC_CLKP_CONFIG | ( | __CLKPSource__ | ) | MODIFY_REG(RCC->CDCCIPR, RCC_CDCCIPR_CKPERSEL, (uint32_t)(__CLKPSource__)) |
| __CLKPSource__ | specifies Oscillator clock for peripheral This parameter can be one of the following values:
| #define __HAL_RCC_CRS_CLEAR_FLAG | ( | __FLAG__ | ) |
| #define __HAL_RCC_CRS_CLEAR_IT | ( | __INTERRUPT__ | ) |
| #define __HAL_RCC_CRS_DISABLE_IT | ( | __INTERRUPT__ | ) | CLEAR_BIT(CRS->CR, (__INTERRUPT__)) |
| __INTERRUPT__ | specifies the CRS interrupt sources to be disabled. This parameter can be any combination of the following values:
| None |
| #define __HAL_RCC_CRS_ENABLE_IT | ( | __INTERRUPT__ | ) | SET_BIT(CRS->CR, (__INTERRUPT__)) |
| __INTERRUPT__ | specifies the CRS interrupt sources to be enabled. This parameter can be any combination of the following values:
| None |
| #define __HAL_RCC_CRS_GET_FLAG | ( | __FLAG__ | ) | (READ_BIT(CRS->ISR, (__FLAG__)) == (__FLAG__)) |
| __FLAG__ | specifies the flag to check. This parameter can be one of the following values:
| The | new state of FLAG (TRUE or FALSE). |
| #define __HAL_RCC_CRS_GET_IT_SOURCE | ( | __INTERRUPT__ | ) | ((READ_BIT(CRS->CR, (__INTERRUPT__)) != 0U) ? SET : RESET) |
| __INTERRUPT__ | specifies the CRS interrupt source to check. This parameter can be one of the following values:
| The | new state of INTERRUPT (SET or RESET). |
| #define __HAL_RCC_DFSDM1_CONFIG | ( | __DFSDM1CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_DFSDM1SEL, (uint32_t)(__DFSDM1CLKSource__)) |
| __DFSDM1CLKSource__ | specifies the DFSDM1 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_FMC_CONFIG | ( | __FMCCLKSource__ | ) | MODIFY_REG(RCC->CDCCIPR, RCC_CDCCIPR_FMCSEL, (uint32_t)(__FMCCLKSource__)) |
| __FMCCLKSource__ | specifies the FMC clock source.
| #define __HAL_RCC_GET_ADC_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_ADCSEL))) |
| The | clock source can be one of the following values:
| #define __HAL_RCC_GET_CEC_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_CECSEL))) |
| #define __HAL_RCC_GET_CLKP_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIPR, RCC_CDCCIPR_CKPERSEL))) |
| #define __HAL_RCC_GET_DFSDM1_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_DFSDM1SEL))) |
| #define __HAL_RCC_GET_FMC_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIPR, RCC_CDCCIPR_FMCSEL))) |
| #define __HAL_RCC_GET_I2C1235_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->D2CCIP2R, RCC_D2CCIP2R_I2C1235SEL))) |
| #define __HAL_RCC_GET_I2C1_SOURCE __HAL_RCC_GET_I2C123_SOURCE |
| #define __HAL_RCC_GET_I2C2_SOURCE __HAL_RCC_GET_I2C123_SOURCE |
| #define __HAL_RCC_GET_I2C3_SOURCE __HAL_RCC_GET_I2C123_SOURCE |
| #define __HAL_RCC_GET_I2C4_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_I2C4SEL))) |
| #define __HAL_RCC_GET_LPTIM1_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_LPTIM1SEL))) |
| #define __HAL_RCC_GET_LPTIM2_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM2SEL))) |
| #define __HAL_RCC_GET_LPTIM345_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM3SEL))) |
| #define __HAL_RCC_GET_LPTIM3_SOURCE __HAL_RCC_GET_LPTIM345_SOURCE |
| #define __HAL_RCC_GET_LPUART1_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_LPUART1SEL))) |
| #define __HAL_RCC_GET_RNG_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_RNGSEL))) |
| #define __HAL_RCC_GET_SAI1_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SAI1SEL))) |
| #define __HAL_RCC_GET_SPDIFRX_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SPDIFSEL))) |
| None |
| #define __HAL_RCC_GET_SPI123_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI123SEL))) |
| #define __HAL_RCC_GET_SPI1_SOURCE __HAL_RCC_GET_SPI123_SOURCE |
| #define __HAL_RCC_GET_SPI2_SOURCE __HAL_RCC_GET_SPI123_SOURCE |
| #define __HAL_RCC_GET_SPI3_SOURCE __HAL_RCC_GET_SPI123_SOURCE |
| #define __HAL_RCC_GET_SPI45_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI45SEL))) |
| #define __HAL_RCC_GET_SPI4_SOURCE __HAL_RCC_GET_SPI45_SOURCE |
| #define __HAL_RCC_GET_SPI5_SOURCE __HAL_RCC_GET_SPI45_SOURCE |
| #define __HAL_RCC_GET_SPI6_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->SRDCCIPR, RCC_SRDCCIPR_SPI6SEL))) |
| #define __HAL_RCC_GET_SWPMI1_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP1R, RCC_CDCCIP1R_SWPSEL))) |
| #define __HAL_RCC_GET_UART4_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| #define __HAL_RCC_GET_UART5_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| #define __HAL_RCC_GET_UART7_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| #define __HAL_RCC_GET_UART8_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| #define __HAL_RCC_GET_USART16910_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->D2CCIP2R, RCC_D2CCIP2R_USART16910SEL))) |
| #define __HAL_RCC_GET_USART1_SOURCE __HAL_RCC_GET_USART16_SOURCE |
| #define __HAL_RCC_GET_USART234578_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_USART234578SEL))) |
| #define __HAL_RCC_GET_USART2_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| #define __HAL_RCC_GET_USART3_SOURCE __HAL_RCC_GET_USART234578_SOURCE |
| #define __HAL_RCC_GET_USART6_SOURCE __HAL_RCC_GET_USART16_SOURCE |
| #define __HAL_RCC_GET_USB_SOURCE | ( | ) | ((uint32_t)(READ_BIT(RCC->CDCCIP2R, RCC_CDCCIP2R_USBSEL))) |
| #define __HAL_RCC_I2C1235_CONFIG | ( | __I2C1235CLKSource__ | ) | MODIFY_REG(RCC->D2CCIP2R, RCC_D2CCIP2R_I2C1235SEL, (uint32_t)(__I2C1235CLKSource__)) |
| __I2C1235CLKSource__ | specifies the I2C1/2/3/5* clock source. This parameter can be one of the following values:
| #define __HAL_RCC_I2C1_CONFIG __HAL_RCC_I2C123_CONFIG |
| __I2C1CLKSource__ | specifies the I2C1 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_I2C2_CONFIG __HAL_RCC_I2C123_CONFIG |
| __I2C2CLKSource__ | specifies the I2C2 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_I2C3_CONFIG __HAL_RCC_I2C123_CONFIG |
| __I2C3CLKSource__ | specifies the I2C3 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_I2C4_CONFIG | ( | __I2C4CLKSource__ | ) | MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_I2C4SEL, (uint32_t)(__I2C4CLKSource__)) |
| __I2C4CLKSource__ | specifies the I2C4 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_LPTIM1_CONFIG | ( | __LPTIM1CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_LPTIM1SEL, (uint32_t)(__LPTIM1CLKSource__)) |
| __LPTIM1CLKSource__ | specifies the LPTIM1 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_LPTIM2_CONFIG | ( | __LPTIM2CLKSource__ | ) | MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM2SEL, (uint32_t)(__LPTIM2CLKSource__)) |
| __LPTIM2CLKSource__ | specifies the LPTIM2 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_LPTIM345_CONFIG | ( | __LPTIM345CLKSource__ | ) | MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_LPTIM3SEL, (uint32_t)(__LPTIM345CLKSource__)) |
| __LPTIM345CLKSource__ | specifies the LPTIM3/4/5 clock source.
| #define __HAL_RCC_LPTIM3_CONFIG __HAL_RCC_LPTIM345_CONFIG |
| __LPTIM3CLKSource__ | specifies the LPTIM3 clock source.
| #define __HAL_RCC_LPUART1_CONFIG | ( | __LPUART1CLKSource__ | ) | MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_LPUART1SEL, (uint32_t)(__LPUART1CLKSource__)) |
| __LPUART1CLKSource__ | specifies the LPUART1 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_LSECSS_EXTI_CLEAR_FLAG | ( | ) | WRITE_REG(EXTI->PR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_DISABLE_EVENT | ( | ) | CLEAR_BIT(EXTI->EMR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_DISABLE_FALLING_EDGE | ( | ) | CLEAR_BIT(EXTI->FTSR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_DISABLE_IT | ( | ) | CLEAR_BIT(EXTI->IMR1, RCC_EXTI_LINE_LSECSS) |
| None |
| #define __HAL_RCC_LSECSS_EXTI_DISABLE_RISING_EDGE | ( | ) | CLEAR_BIT(EXTI->RTSR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_DISABLE_RISING_FALLING_EDGE | ( | ) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_ENABLE_EVENT | ( | ) | SET_BIT(EXTI->EMR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_ENABLE_FALLING_EDGE | ( | ) | SET_BIT(EXTI->FTSR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_ENABLE_IT | ( | ) | SET_BIT(EXTI->IMR1, RCC_EXTI_LINE_LSECSS) |
| None |
| #define __HAL_RCC_LSECSS_EXTI_ENABLE_RISING_EDGE | ( | ) | SET_BIT(EXTI->RTSR1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_ENABLE_RISING_FALLING_EDGE | ( | ) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_GENERATE_SWIT | ( | ) | SET_BIT(EXTI->SWIER1, RCC_EXTI_LINE_LSECSS) |
| None. |
| #define __HAL_RCC_LSECSS_EXTI_GET_FLAG | ( | ) | (READ_BIT(EXTI->PR1, RCC_EXTI_LINE_LSECSS) == RCC_EXTI_LINE_LSECSS) |
| EXTI | RCC LSE CSS Line Status. |
| #define __HAL_RCC_PLL2_CONFIG | ( | __PLL2M__, | |
| __PLL2N__, | |||
| __PLL2P__, | |||
| __PLL2Q__, | |||
| __PLL2R__ | |||
| __PLL2M__ | specifies the division factor for PLL2 VCO input clock This parameter must be a number between 1 and 63. |
| __PLL2N__ | specifies the multiplication factor for PLL2 VCO output clock This parameter must be a number between 4 and 512 or between 8 and 420(*). |
| __PLL2P__ | specifies the division factor for peripheral kernel clocks This parameter must be a number between 1 and 128. |
| __PLL2Q__ | specifies the division factor for peripheral kernel clocks This parameter must be a number between 1 and 128. |
| __PLL2R__ | specifies the division factor for peripheral kernel clocks This parameter must be a number between 1 and 128. |
| None |
(*) : For stm32h7a3xx and stm32h7b3xx family lines.
| #define __HAL_RCC_PLL2_ENABLE | ( | ) | SET_BIT(RCC->CR, RCC_CR_PLL2ON) |
| #define __HAL_RCC_PLL2_VCIRANGE | ( | __RCC_PLL2VCIRange__ | ) | MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL2RGE, (__RCC_PLL2VCIRange__)) |
| __RCC_PLL2VCIRange__ | specifies the PLL2 input frequency range This parameter can be one of the following values:
| None |
| #define __HAL_RCC_PLL2_VCORANGE | ( | __RCC_PLL2VCORange__ | ) | MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL2VCOSEL, (__RCC_PLL2VCORange__)) |
| __RCC_PLL2VCORange__ | Specifies the PLL2 input frequency range This parameter can be one of the following values:
| None |
| #define __HAL_RCC_PLL2CLKOUT_ENABLE | ( | __RCC_PLL2ClockOut__ | ) | SET_BIT(RCC->PLLCFGR, (__RCC_PLL2ClockOut__)) |
| __RCC_PLL2ClockOut__ | Specifies the PLL2 clock to be outputted This parameter can be one of the following values:
| None |
| #define __HAL_RCC_PLL2FRACN_CONFIG | ( | __RCC_PLL2FRACN__ | ) | MODIFY_REG(RCC->PLL2FRACR, RCC_PLL2FRACR_FRACN2,((uint32_t)(__RCC_PLL2FRACN__) << RCC_PLL2FRACR_FRACN2_Pos)) |
| __RCC_PLL2FRACN__ | Specifies Fractional Part Of The Multiplication factor for PLL2 VCO It should be a value between 0 and 8191 |
| None |
| #define __HAL_RCC_PLL2FRACN_ENABLE | ( | ) | SET_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLL2FRACEN) |
| None |
| #define __HAL_RCC_PLL3_CONFIG | ( | __PLL3M__, | |
| __PLL3N__, | |||
| __PLL3P__, | |||
| __PLL3Q__, | |||
| __PLL3R__ | |||
| __PLL3M__ | specifies the division factor for PLL3 VCO input clock This parameter must be a number between 1 and 63. |
| __PLL3N__ | specifies the multiplication factor for PLL3 VCO output clock This parameter must be a number between 4 and 512. |
| __PLL3P__ | specifies the division factor for peripheral kernel clocks This parameter must be a number between 2 and 128 (where odd numbers not allowed) |
| __PLL3Q__ | specifies the division factor for peripheral kernel clocks This parameter must be a number between 1 and 128 |
| __PLL3R__ | specifies the division factor for peripheral kernel clocks This parameter must be a number between 1 and 128 |
| None |
| #define __HAL_RCC_PLL3_ENABLE | ( | ) | SET_BIT(RCC->CR, RCC_CR_PLL3ON) |
| #define __HAL_RCC_PLL3_VCIRANGE | ( | __RCC_PLL3VCIRange__ | ) | MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL3RGE, (__RCC_PLL3VCIRange__)) |
| __RCC_PLL3VCIRange__ | specifies the PLL1 input frequency range This parameter can be one of the following values:
| None |
| #define __HAL_RCC_PLL3_VCORANGE | ( | __RCC_PLL3VCORange__ | ) | MODIFY_REG(RCC->PLLCFGR, RCC_PLLCFGR_PLL3VCOSEL, (__RCC_PLL3VCORange__)) |
| __RCC_PLL3VCORange__ | specifies the PLL1 input frequency range This parameter can be one of the following values:
| None |
| #define __HAL_RCC_PLL3CLKOUT_ENABLE | ( | __RCC_PLL3ClockOut__ | ) | SET_BIT(RCC->PLLCFGR, (__RCC_PLL3ClockOut__)) |
| __RCC_PLL3ClockOut__ | specifies the PLL3 clock to be outputted This parameter can be one of the following values:
| None |
| #define __HAL_RCC_PLL3FRACN_CONFIG | ( | __RCC_PLL3FRACN__ | ) | MODIFY_REG(RCC->PLL3FRACR, RCC_PLL3FRACR_FRACN3, (uint32_t)(__RCC_PLL3FRACN__) << RCC_PLL3FRACR_FRACN3_Pos) |
| __RCC_PLL3FRACN__ | specifies Fractional Part Of The Multiplication Factor for PLL3 VCO It should be a value between 0 and 8191 |
| None |
| #define __HAL_RCC_PLL3FRACN_ENABLE | ( | ) | SET_BIT(RCC->PLLCFGR, RCC_PLLCFGR_PLL3FRACEN) |
| None |
| #define __HAL_RCC_RNG_CONFIG | ( | __RNGCLKSource__ | ) | MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_RNGSEL, (uint32_t)(__RNGCLKSource__)) |
| __RNGCLKSource__ | specifies the RNG clock source. This parameter can be one of the following values:
| #define __HAL_RCC_SAI1_CONFIG | ( | __RCC_SAI1CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SAI1SEL, (__RCC_SAI1CLKSource__)) |
| __RCC_SAI1CLKSource__ | defines the SAI1 clock source. This clock is derived from system PLL, PLL2, PLL3, OSC or external clock (through a dedicated PIN) This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SDMMC_CONFIG | ( | __SDMMCCLKSource__ | ) | MODIFY_REG(RCC->CDCCIPR, RCC_CDCCIPR_SDMMCSEL, (uint32_t)(__SDMMCCLKSource__)) |
| __SDMMCCLKSource__ | specifies clock source for SDMMC This parameter can be one of the following values:
| #define __HAL_RCC_SPDIFRX_CONFIG | ( | __RCC_SPDIFCLKSource__ | ) | MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SPDIFSEL, (__RCC_SPDIFCLKSource__)) |
| __RCC_SPDIFCLKSource__ | defines the SPDIFRX clock source. This clock is derived from system PLL, PLL2, PLL3, or internal OSC clock This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI123_CONFIG | ( | __RCC_SPI123CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI123SEL, (__RCC_SPI123CLKSource__)) |
| __RCC_SPI123CLKSource__ | defines the SPI1/2/3 clock source. This clock is derived from system PLL, PLL2, PLL3, OSC or external clock (through a dedicated PIN) This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI1_CONFIG __HAL_RCC_SPI123_CONFIG |
| __RCC_SPI1CLKSource__ | defines the SPI1 clock source. This clock is derived from system PLL, PLL2, PLL3, OSC or external clock (through a dedicated PIN) This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI2_CONFIG __HAL_RCC_SPI123_CONFIG |
| __RCC_SPI2CLKSource__ | defines the SPI2 clock source. This clock is derived from system PLL, PLL2, PLL3, OSC or external clock (through a dedicated PIN) This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI3_CONFIG __HAL_RCC_SPI123_CONFIG |
| __RCC_SPI3CLKSource__ | defines the SPI3 clock source. This clock is derived from system PLL, PLL2, PLL3, OSC or external clock (through a dedicated PIN) This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI45_CONFIG | ( | __RCC_SPI45CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SPI45SEL, (__RCC_SPI45CLKSource__)) |
| __RCC_SPI45CLKSource__ | defines the SPI4/5 clock source. This clock is derived from system PCLK, PLL2, PLL3, OSC This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI4_CONFIG __HAL_RCC_SPI45_CONFIG |
| __RCC_SPI4CLKSource__ | defines the SPI4 clock source. This clock is derived from system PCLK, PLL2, PLL3, OSC This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI5_CONFIG __HAL_RCC_SPI45_CONFIG |
| __RCC_SPI5CLKSource__ | defines the SPI5 clock source. This clock is derived from system PCLK, PLL2, PLL3, OSC This parameter can be one of the following values:
| None |
| #define __HAL_RCC_SPI6_CONFIG | ( | __RCC_SPI6CLKSource__ | ) | MODIFY_REG(RCC->SRDCCIPR, RCC_SRDCCIPR_SPI6SEL, (__RCC_SPI6CLKSource__)) |
| __RCC_SPI6CLKSource__ | defines the SPI6 clock source. This clock is derived from system PCLK, PLL2, PLL3, OSC This parameter can be one of the following values:
| None |
(*) : Available on stm32h7a3xx and stm32h7b3xx family lines.
| #define __HAL_RCC_SWPMI1_CONFIG | ( | __SWPMI1CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP1R, RCC_CDCCIP1R_SWPSEL, (uint32_t)(__SWPMI1CLKSource__)) |
| __SWPMI1CLKSource__ | specifies the SWPMI1 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_TIMCLKPRESCALER | ( | __PRESC__ | ) |
| __PRESC__ | specifies the Timers clocks prescalers selection This parameter can be one of the following values:
| #define __HAL_RCC_UART4_CONFIG __HAL_RCC_USART234578_CONFIG |
| __UART4CLKSource__ | specifies the UART4 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_UART5_CONFIG __HAL_RCC_USART234578_CONFIG |
| __UART5CLKSource__ | specifies the UART5 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_UART7_CONFIG __HAL_RCC_USART234578_CONFIG |
| __UART7CLKSource__ | specifies the UART7 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_UART8_CONFIG __HAL_RCC_USART234578_CONFIG |
| __UART8CLKSource__ | specifies the UART8 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USART16910_CONFIG | ( | __USART16910CLKSource__ | ) | MODIFY_REG(RCC->D2CCIP2R, RCC_D2CCIP2R_USART16910SEL, (uint32_t)(__USART16910CLKSource__)) |
| __USART16910CLKSource__ | specifies the USART1/6/9* /10* clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USART1_CONFIG __HAL_RCC_USART16_CONFIG |
| __USART1CLKSource__ | specifies the USART1 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USART234578_CONFIG | ( | __USART234578CLKSource__ | ) | MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_USART234578SEL, (uint32_t)(__USART234578CLKSource__)) |
| __USART234578CLKSource__ | specifies the USART2/3/4/5/7/8 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USART2_CONFIG __HAL_RCC_USART234578_CONFIG |
| __USART2CLKSource__ | specifies the USART2 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USART3_CONFIG __HAL_RCC_USART234578_CONFIG |
| __USART3CLKSource__ | specifies the USART3 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USART6_CONFIG __HAL_RCC_USART16_CONFIG |
| __USART6CLKSource__ | specifies the USART6 clock source. This parameter can be one of the following values:
| #define __HAL_RCC_USB_CONFIG | ( | __USBCLKSource__ | ) | MODIFY_REG(RCC->CDCCIP2R, RCC_CDCCIP2R_USBSEL, (uint32_t)(__USBCLKSource__)) |
| __USBCLKSource__ | specifies the USB clock source. This parameter can be one of the following values:
| #define RCC_CRS_FLAG_ERROR_MASK ((uint32_t)(RCC_CRS_FLAG_TRIMOVF | RCC_CRS_FLAG_SYNCERR | RCC_CRS_FLAG_SYNCMISS)) |
| __FLAG__ | specifies the flag to clear. This parameter can be one of the following values:
| None |
| #define RCC_CRS_IT_ERROR_MASK ((uint32_t)(RCC_CRS_IT_TRIMOVF | RCC_CRS_IT_SYNCERR | RCC_CRS_IT_SYNCMISS)) |
| __INTERRUPT__ | specifies the interrupt pending bit to clear. This parameter can be any combination of the following values:
