RTEMS 6.1-rc8
| #define | MMCAU_CA_COUNT (9U) |
CASR - Status Register | |
| #define | MMCAU_CASR_IC_MASK (0x1U) |
| #define | MMCAU_CASR_IC_SHIFT (0U) |
| #define | MMCAU_CASR_IC(x) (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_IC_SHIFT)) & MMCAU_CASR_IC_MASK) |
| #define | MMCAU_CASR_DPE_MASK (0x2U) |
| #define | MMCAU_CASR_DPE_SHIFT (1U) |
| #define | MMCAU_CASR_DPE(x) (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_DPE_SHIFT)) & MMCAU_CASR_DPE_MASK) |
| #define | MMCAU_CASR_VER_MASK (0xF0000000U) |
| #define | MMCAU_CASR_VER_SHIFT (28U) |
| #define | MMCAU_CASR_VER(x) (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_VER_SHIFT)) & MMCAU_CASR_VER_MASK) |
CAA - Accumulator | |
| #define | MMCAU_CAA_ACC_MASK (0xFFFFFFFFU) |
| #define | MMCAU_CAA_ACC_SHIFT (0U) |
| #define | MMCAU_CAA_ACC(x) (((uint32_t)(((uint32_t)(x)) << MMCAU_CAA_ACC_SHIFT)) & MMCAU_CAA_ACC_MASK) |
CA - General Purpose Register | |
| #define | MMCAU_CA_CAn_MASK (0xFFFFFFFFU) |
| #define | MMCAU_CA_CAn_SHIFT (0U) |
| #define | MMCAU_CA_CAn(x) (((uint32_t)(((uint32_t)(x)) << MMCAU_CA_CAn_SHIFT)) & MMCAU_CA_CAn_MASK) |
| #define MMCAU_CA_CAn | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MMCAU_CA_CAn_SHIFT)) & MMCAU_CA_CAn_MASK) |
CAn - General Purpose Registers
| #define MMCAU_CAA_ACC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MMCAU_CAA_ACC_SHIFT)) & MMCAU_CAA_ACC_MASK) |
ACC - Accumulator
| #define MMCAU_CASR_DPE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_DPE_SHIFT)) & MMCAU_CASR_DPE_MASK) |
DPE - DES Parity Error 0b0..No error detected. 0b1..DES key parity error detected.
| #define MMCAU_CASR_IC | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_IC_SHIFT)) & MMCAU_CASR_IC_MASK) |
IC - Illegal Command 0b0..No illegal commands issued. 0b1..Illegal command issued.
| #define MMCAU_CASR_VER | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MMCAU_CASR_VER_SHIFT)) & MMCAU_CASR_VER_MASK) |
VER - CAU Version 0b0001..Initial CAU version. 0b0010..Second version, added support for SHA-256 algorithm (This is the value on this device).
