RTEMS 6.1-rc8
| #define | __HAL_FLASH_CALC_BOOT_BASE_ADR(__ADDRESS__) ((__ADDRESS__) >> 14U) |
| Calculate the FLASH Boot Base Address (BOOT_ADD0 or BOOT_ADD1) | |
| #define | __HAL_FLASH_SET_PROGRAM_DELAY(__DELAY__) MODIFY_REG(FLASH->ACR, FLASH_ACR_WRHIGHFREQ, (__DELAY__)) |
| Set the FLASH Programming Delay. | |
| #define | __HAL_FLASH_GET_PROGRAM_DELAY() READ_BIT(FLASH->ACR, FLASH_ACR_WRHIGHFREQ) |
| Get the FLASH Programming Delay. | |
| #define __HAL_FLASH_CALC_BOOT_BASE_ADR | ( | __ADDRESS__ | ) | ((__ADDRESS__) >> 14U) |
| __ADDRESS__ | FLASH Boot Address (in the range 0x0000 0000 to 0x2004 FFFF with a granularity of 16KB) |
| The | FLASH Boot Base Address |
| #define __HAL_FLASH_GET_PROGRAM_DELAY | ( | ) | READ_BIT(FLASH->ACR, FLASH_ACR_WRHIGHFREQ) |
| FLASH | Programming Delay This return value can be a value of FLASH Programming Delay |
| #define __HAL_FLASH_SET_PROGRAM_DELAY | ( | __DELAY__ | ) | MODIFY_REG(FLASH->ACR, FLASH_ACR_WRHIGHFREQ, (__DELAY__)) |
| __DELAY__ | FLASH Programming Delay This parameter can be a value of FLASH Programming Delay |
| none |
