RTEMS 6.1-rc8
Tests a fatal error. More...
Files | |
| file | tr-fatal-clock-xil-ttc-irq-install.c |
| file | tr-fatal-clock-xil-ttc-irq-install.h |
| struct | DevClockXilTtcValFatalIrqInstall_Context |
| Test context for spec:/dev/clock/xil-ttc/val/fatal-irq-install test case. More... | |
| RTEMS_SYSINIT_ITEM (OccupyClockInterrupt, RTEMS_SYSINIT_DEVICE_DRIVERS, RTEMS_SYSINIT_ORDER_FIRST) | |
| void | DevClockXilTtcValFatalIrqInstall_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void DevClockXilTtcValFatalIrqInstall_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code | ||
| source | is fatal source. |
| code | is fatal code. |
