RTEMS 6.1-rc8
| #define | __HAL_DMA_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_DMA_STATE_RESET) |
| Reset DMA handle state. | |
| #define | __HAL_DMA_GET_FS(__HANDLE__) ((IS_DMA_STREAM_INSTANCE((__HANDLE__)->Instance))? (((DMA_Stream_TypeDef *)(__HANDLE__)->Instance)->FCR & (DMA_SxFCR_FS)) : 0) |
| Return the current DMA Stream FIFO filled level. | |
| #define | __HAL_DMA_ENABLE(__HANDLE__) |
| Enable the specified DMA Stream. | |
| #define | __HAL_DMA_DISABLE(__HANDLE__) |
| Disable the specified DMA Stream. | |
| #define | __HAL_DMA_GET_TC_FLAG_INDEX(__HANDLE__) |
| Return the current DMA Stream transfer complete flag. | |
| #define | __HAL_DMA_GET_HT_FLAG_INDEX(__HANDLE__) |
| Return the current DMA Stream half transfer complete flag. | |
| #define | __HAL_DMA_GET_TE_FLAG_INDEX(__HANDLE__) |
| Return the current DMA Stream transfer error flag. | |
| #define | __HAL_DMA_GET_FE_FLAG_INDEX(__HANDLE__) |
| Return the current DMA Stream FIFO error flag. | |
| #define | __HAL_DMA_GET_DME_FLAG_INDEX(__HANDLE__) |
| Return the current DMA Stream direct mode error flag. | |
| #define | __HAL_BDMA_GET_GI_FLAG_INDEX(__HANDLE__) |
| Returns the current BDMA Channel Global interrupt flag. | |
| #define | __HAL_DMA_GET_FLAG(__HANDLE__, __FLAG__) |
| Get the DMA Stream pending flags. | |
| #define | __HAL_DMA_CLEAR_FLAG(__HANDLE__, __FLAG__) |
| Clear the DMA Stream pending flags. | |
| #define | DMA_TO_BDMA_IT(__DMA_IT__) |
| #define | __HAL_BDMA_CHANNEL_ENABLE_IT(__HANDLE__, __INTERRUPT__) (((BDMA_Channel_TypeDef *)(__HANDLE__)->Instance)->CCR |= (DMA_TO_BDMA_IT(__INTERRUPT__))) |
| #define | __HAL_DMA_STREAM_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| #define | __HAL_DMA_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified DMA Stream interrupts. | |
| #define | __HAL_BDMA_CHANNEL_DISABLE_IT(__HANDLE__, __INTERRUPT__) (((BDMA_Channel_TypeDef *)(__HANDLE__)->Instance)->CCR &= ~(DMA_TO_BDMA_IT(__INTERRUPT__))) |
| #define | __HAL_DMA_STREAM_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| #define | __HAL_DMA_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified DMA Stream interrupts. | |
| #define | __HAL_BDMA_CHANNEL_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((((BDMA_Channel_TypeDef *)(__HANDLE__)->Instance)->CCR & (DMA_TO_BDMA_IT(__INTERRUPT__)))) |
| #define | __HAL_DMA_STREAM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| #define | __HAL_DMA_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified DMA Stream interrupt is enabled or not. | |
| #define | __HAL_DMA_SET_COUNTER(__HANDLE__, __COUNTER__) |
| Writes the number of data units to be transferred on the DMA Stream. | |
| #define | __HAL_DMA_GET_COUNTER(__HANDLE__) |
| Returns the number of remaining data units in the current DMAy Streamx transfer. | |
| #define __HAL_BDMA_GET_GI_FLAG_INDEX | ( | __HANDLE__ | ) |
| __HANDLE__ | DMA handle |
| The | specified transfer error flag index. |
| #define __HAL_DMA_CLEAR_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| __FLAG__ | specifies the flag to clear. This parameter can be any combination of the following values:
| None |
| #define __HAL_DMA_DISABLE | ( | __HANDLE__ | ) |
| None |
| #define __HAL_DMA_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the DMA interrupt sources to be enabled or disabled. This parameter can be one of the following values:
| None |
| #define __HAL_DMA_ENABLE | ( | __HANDLE__ | ) |
| None |
| #define __HAL_DMA_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| None |
| #define __HAL_DMA_GET_COUNTER | ( | __HANDLE__ | ) |
| The | number of remaining data units in the current DMA Stream transfer. |
| #define __HAL_DMA_GET_DME_FLAG_INDEX | ( | __HANDLE__ | ) |
| The | specified direct mode error flag index. |
| #define __HAL_DMA_GET_FE_FLAG_INDEX | ( | __HANDLE__ | ) |
| The | specified FIFO error flag index. |
| #define __HAL_DMA_GET_FLAG | ( | __HANDLE__, | |
| __FLAG__ | |||
| __FLAG__ | Get the specified flag. This parameter can be any combination of the following values:
| The | state of FLAG (SET or RESET). |
| #define __HAL_DMA_GET_FS | ( | __HANDLE__ | ) | ((IS_DMA_STREAM_INSTANCE((__HANDLE__)->Instance))? (((DMA_Stream_TypeDef *)(__HANDLE__)->Instance)->FCR & (DMA_SxFCR_FS)) : 0) |
| The | FIFO filling state.
| #define __HAL_DMA_GET_HT_FLAG_INDEX | ( | __HANDLE__ | ) |
| The | specified half transfer complete flag index. |
| #define __HAL_DMA_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| __INTERRUPT__ | specifies the DMA interrupt source to check. This parameter can be one of the following values:
| The | state of DMA_IT. |
| #define __HAL_DMA_GET_TC_FLAG_INDEX | ( | __HANDLE__ | ) |
| The | specified transfer complete flag index. |
| #define __HAL_DMA_GET_TE_FLAG_INDEX | ( | __HANDLE__ | ) |
| #define __HAL_DMA_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_DMA_STATE_RESET) |
| __HANDLE__ | specifies the DMA handle. |
| None |
| #define __HAL_DMA_SET_COUNTER | ( | __HANDLE__, | |
| __COUNTER__ | |||
| __COUNTER__ | Number of data units to be transferred (from 0 to 65535) Number of data items depends only on the Peripheral data format. |
| The | number of remaining data units in the current DMAy Streamx transfer. |
| #define __HAL_DMA_STREAM_DISABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| #define __HAL_DMA_STREAM_ENABLE_IT | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| #define __HAL_DMA_STREAM_GET_IT_SOURCE | ( | __HANDLE__, | |
| __INTERRUPT__ | |||
| #define DMA_TO_BDMA_IT | ( | __DMA_IT__ | ) |
