RTEMS 6.1-rc8
VERID - Version Identifier Register | |
| #define | DAC_VERID_FEATURE_MASK (0xFFFFU) |
| #define | DAC_VERID_FEATURE_SHIFT (0U) |
| #define | DAC_VERID_FEATURE(x) (((uint32_t)(((uint32_t)(x)) << DAC_VERID_FEATURE_SHIFT)) & DAC_VERID_FEATURE_MASK) |
| #define | DAC_VERID_MINOR_MASK (0xFF0000U) |
| #define | DAC_VERID_MINOR_SHIFT (16U) |
| #define | DAC_VERID_MINOR(x) (((uint32_t)(((uint32_t)(x)) << DAC_VERID_MINOR_SHIFT)) & DAC_VERID_MINOR_MASK) |
| #define | DAC_VERID_MAJOR_MASK (0xFF000000U) |
| #define | DAC_VERID_MAJOR_SHIFT (24U) |
| #define | DAC_VERID_MAJOR(x) (((uint32_t)(((uint32_t)(x)) << DAC_VERID_MAJOR_SHIFT)) & DAC_VERID_MAJOR_MASK) |
PARAM - Parameter Register | |
| #define | DAC_PARAM_FIFOSZ_MASK (0x7U) |
| #define | DAC_PARAM_FIFOSZ_SHIFT (0U) |
| #define | DAC_PARAM_FIFOSZ(x) (((uint32_t)(((uint32_t)(x)) << DAC_PARAM_FIFOSZ_SHIFT)) & DAC_PARAM_FIFOSZ_MASK) |
DATA - DAC Data Register | |
| #define | DAC_DATA_DATA0_MASK (0xFFFU) |
| #define | DAC_DATA_DATA0_SHIFT (0U) |
| #define | DAC_DATA_DATA0(x) (((uint32_t)(((uint32_t)(x)) << DAC_DATA_DATA0_SHIFT)) & DAC_DATA_DATA0_MASK) |
CR - DAC Status and Control Register | |
| #define | DAC_CR_FULLF_MASK (0x1U) |
| #define | DAC_CR_FULLF_SHIFT (0U) |
| #define | DAC_CR_FULLF(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_FULLF_SHIFT)) & DAC_CR_FULLF_MASK) |
| #define | DAC_CR_NEMPTF_MASK (0x2U) |
| #define | DAC_CR_NEMPTF_SHIFT (1U) |
| #define | DAC_CR_NEMPTF(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_NEMPTF_SHIFT)) & DAC_CR_NEMPTF_MASK) |
| #define | DAC_CR_WMF_MASK (0x4U) |
| #define | DAC_CR_WMF_SHIFT (2U) |
| #define | DAC_CR_WMF(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_WMF_SHIFT)) & DAC_CR_WMF_MASK) |
| #define | DAC_CR_UDFF_MASK (0x8U) |
| #define | DAC_CR_UDFF_SHIFT (3U) |
| #define | DAC_CR_UDFF(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_UDFF_SHIFT)) & DAC_CR_UDFF_MASK) |
| #define | DAC_CR_OVFF_MASK (0x10U) |
| #define | DAC_CR_OVFF_SHIFT (4U) |
| #define | DAC_CR_OVFF(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_OVFF_SHIFT)) & DAC_CR_OVFF_MASK) |
| #define | DAC_CR_FULLIE_MASK (0x100U) |
| #define | DAC_CR_FULLIE_SHIFT (8U) |
| #define | DAC_CR_FULLIE(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_FULLIE_SHIFT)) & DAC_CR_FULLIE_MASK) |
| #define | DAC_CR_EMPTIE_MASK (0x200U) |
| #define | DAC_CR_EMPTIE_SHIFT (9U) |
| #define | DAC_CR_EMPTIE(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_EMPTIE_SHIFT)) & DAC_CR_EMPTIE_MASK) |
| #define | DAC_CR_WTMIE_MASK (0x400U) |
| #define | DAC_CR_WTMIE_SHIFT (10U) |
| #define | DAC_CR_WTMIE(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_WTMIE_SHIFT)) & DAC_CR_WTMIE_MASK) |
| #define | DAC_CR_SWTRG_MASK (0x1000U) |
| #define | DAC_CR_SWTRG_SHIFT (12U) |
| #define | DAC_CR_SWTRG(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_SWTRG_SHIFT)) & DAC_CR_SWTRG_MASK) |
| #define | DAC_CR_TRGSEL_MASK (0x2000U) |
| #define | DAC_CR_TRGSEL_SHIFT (13U) |
| #define | DAC_CR_TRGSEL(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_TRGSEL_SHIFT)) & DAC_CR_TRGSEL_MASK) |
| #define | DAC_CR_DACRFS_MASK (0x4000U) |
| #define | DAC_CR_DACRFS_SHIFT (14U) |
| #define | DAC_CR_DACRFS(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_DACRFS_SHIFT)) & DAC_CR_DACRFS_MASK) |
| #define | DAC_CR_DACEN_MASK (0x8000U) |
| #define | DAC_CR_DACEN_SHIFT (15U) |
| #define | DAC_CR_DACEN(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_DACEN_SHIFT)) & DAC_CR_DACEN_MASK) |
| #define | DAC_CR_FIFOEN_MASK (0x10000U) |
| #define | DAC_CR_FIFOEN_SHIFT (16U) |
| #define | DAC_CR_FIFOEN(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_FIFOEN_SHIFT)) & DAC_CR_FIFOEN_MASK) |
| #define | DAC_CR_SWMD_MASK (0x20000U) |
| #define | DAC_CR_SWMD_SHIFT (17U) |
| #define | DAC_CR_SWMD(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_SWMD_SHIFT)) & DAC_CR_SWMD_MASK) |
| #define | DAC_CR_UVIE_MASK (0x40000U) |
| #define | DAC_CR_UVIE_SHIFT (18U) |
| #define | DAC_CR_UVIE(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_UVIE_SHIFT)) & DAC_CR_UVIE_MASK) |
| #define | DAC_CR_FIFORST_MASK (0x200000U) |
| #define | DAC_CR_FIFORST_SHIFT (21U) |
| #define | DAC_CR_FIFORST(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_FIFORST_SHIFT)) & DAC_CR_FIFORST_MASK) |
| #define | DAC_CR_SWRST_MASK (0x400000U) |
| #define | DAC_CR_SWRST_SHIFT (22U) |
| #define | DAC_CR_SWRST(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_SWRST_SHIFT)) & DAC_CR_SWRST_MASK) |
| #define | DAC_CR_DMAEN_MASK (0x800000U) |
| #define | DAC_CR_DMAEN_SHIFT (23U) |
| #define | DAC_CR_DMAEN(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_DMAEN_SHIFT)) & DAC_CR_DMAEN_MASK) |
| #define | DAC_CR_WML_MASK (0xFF000000U) |
| #define | DAC_CR_WML_SHIFT (24U) |
| #define | DAC_CR_WML(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR_WML_SHIFT)) & DAC_CR_WML_MASK) |
PTR - DAC FIFO Pointer Register | |
| #define | DAC_PTR_DACWFP_MASK (0xFFU) |
| #define | DAC_PTR_DACWFP_SHIFT (0U) |
| #define | DAC_PTR_DACWFP(x) (((uint32_t)(((uint32_t)(x)) << DAC_PTR_DACWFP_SHIFT)) & DAC_PTR_DACWFP_MASK) |
| #define | DAC_PTR_DACRFP_MASK (0xFF0000U) |
| #define | DAC_PTR_DACRFP_SHIFT (16U) |
| #define | DAC_PTR_DACRFP(x) (((uint32_t)(((uint32_t)(x)) << DAC_PTR_DACRFP_SHIFT)) & DAC_PTR_DACRFP_MASK) |
CR2 - DAC Status and Control Register 2 | |
| #define | DAC_CR2_BFEN_MASK (0x1U) |
| #define | DAC_CR2_BFEN_SHIFT (0U) |
| #define | DAC_CR2_BFEN(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_BFEN_SHIFT)) & DAC_CR2_BFEN_MASK) |
| #define | DAC_CR2_OEN_MASK (0x2U) |
| #define | DAC_CR2_OEN_SHIFT (1U) |
| #define | DAC_CR2_OEN(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_OEN_SHIFT)) & DAC_CR2_OEN_MASK) |
| #define | DAC_CR2_BFMS_MASK (0x4U) |
| #define | DAC_CR2_BFMS_SHIFT (2U) |
| #define | DAC_CR2_BFMS(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_BFMS_SHIFT)) & DAC_CR2_BFMS_MASK) |
| #define | DAC_CR2_BFHS_MASK (0x8U) |
| #define | DAC_CR2_BFHS_SHIFT (3U) |
| #define | DAC_CR2_BFHS(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_BFHS_SHIFT)) & DAC_CR2_BFHS_MASK) |
| #define | DAC_CR2_IREF2_MASK (0x10U) |
| #define | DAC_CR2_IREF2_SHIFT (4U) |
| #define | DAC_CR2_IREF2(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_IREF2_SHIFT)) & DAC_CR2_IREF2_MASK) |
| #define | DAC_CR2_IREF1_MASK (0x20U) |
| #define | DAC_CR2_IREF1_SHIFT (5U) |
| #define | DAC_CR2_IREF1(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_IREF1_SHIFT)) & DAC_CR2_IREF1_MASK) |
| #define | DAC_CR2_IREF_MASK (0x40U) |
| #define | DAC_CR2_IREF_SHIFT (6U) |
| #define | DAC_CR2_IREF(x) (((uint32_t)(((uint32_t)(x)) << DAC_CR2_IREF_SHIFT)) & DAC_CR2_IREF_MASK) |
| #define DAC_CR2_BFEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_BFEN_SHIFT)) & DAC_CR2_BFEN_MASK) |
BFEN - Buffer Enable 0b0..Opamp is not used as buffer 0b1..Opamp is used as buffer
| #define DAC_CR2_BFHS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_BFHS_SHIFT)) & DAC_CR2_BFHS_MASK) |
BFHS - Buffer High Speed Select 0b0..Buffer high speed not selected 0b1..Buffer high speed selected
| #define DAC_CR2_BFMS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_BFMS_SHIFT)) & DAC_CR2_BFMS_MASK) |
BFMS - Buffer Middle Speed Select 0b0..Buffer middle speed not selected 0b1..Buffer middle speed selected
| #define DAC_CR2_IREF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_IREF_SHIFT)) & DAC_CR2_IREF_MASK) |
IREF - Internal Current Reference Select 0b0..Internal Current Reference not selected 0b1..Internal Current Reference selected
| #define DAC_CR2_IREF1 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_IREF1_SHIFT)) & DAC_CR2_IREF1_MASK) |
IREF1 - Internal ZTC (Zero Temperature Coefficient) Current Reference Select 0b0..Internal ZTC Current Reference not selected 0b1..Internal ZTC Current Reference selected
| #define DAC_CR2_IREF2 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_IREF2_SHIFT)) & DAC_CR2_IREF2_MASK) |
IREF2 - Internal PTAT (Proportional To Absolute Temperature) Current Reference Select 0b0..Internal PTAT Current Reference not selected 0b1..Internal PTAT Current Reference selected
| #define DAC_CR2_OEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR2_OEN_SHIFT)) & DAC_CR2_OEN_MASK) |
OEN - Optional Enable 0b0..Output buffer is not bypassed 0b1..Output buffer is bypassed
| #define DAC_CR_DACEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_DACEN_SHIFT)) & DAC_CR_DACEN_MASK) |
DACEN - DAC Enable 0b0..The DAC system is disabled. 0b1..The DAC system is enabled.
| #define DAC_CR_DACRFS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_DACRFS_SHIFT)) & DAC_CR_DACRFS_MASK) |
DACRFS - DAC Reference Select 0b0..The DAC selects DACREF_1 as the reference voltage. 0b1..The DAC selects DACREF_2 as the reference voltage.
| #define DAC_CR_DMAEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_DMAEN_SHIFT)) & DAC_CR_DMAEN_MASK) |
DMAEN - DMA Enable Select 0b0..DMA is disabled. 0b1..DMA is enabled. When DMA is enabled, the DMA request will be generated by original interrupts. The interrupts will not be presented on this module at the same time.
| #define DAC_CR_EMPTIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_EMPTIE_SHIFT)) & DAC_CR_EMPTIE_MASK) |
EMPTIE - Nearly Empty Interrupt Enable 0b0..FIFO Nearly Empty interrupt is disabled. 0b1..FIFO Nearly Empty interrupt is enabled.
| #define DAC_CR_FIFOEN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_FIFOEN_SHIFT)) & DAC_CR_FIFOEN_MASK) |
FIFOEN - FIFO Enable 0b0..FIFO is disabled and only one level buffer is enabled. Any data written from this buffer goes to conversion. 0b1..FIFO is enabled. Data will first read from FIFO to buffer then go to conversion.
| #define DAC_CR_FIFORST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_FIFORST_SHIFT)) & DAC_CR_FIFORST_MASK) |
FIFORST - FIFO Reset 0b0..No effect 0b1..FIFO reset
| #define DAC_CR_FULLF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_FULLF_SHIFT)) & DAC_CR_FULLF_MASK) |
FULLF - Full Flag 0b0..FIFO is not full. 0b1..FIFO is full.
| #define DAC_CR_FULLIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_FULLIE_SHIFT)) & DAC_CR_FULLIE_MASK) |
FULLIE - Full Interrupt Enable 0b0..FIFO Full interrupt is disabled. 0b1..FIFO Full interrupt is enabled.
| #define DAC_CR_NEMPTF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_NEMPTF_SHIFT)) & DAC_CR_NEMPTF_MASK) |
NEMPTF - Nearly Empty Flag 0b0..More than one data is available in the FIFO. 0b1..One data is available in the FIFO.
| #define DAC_CR_OVFF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_OVFF_SHIFT)) & DAC_CR_OVFF_MASK) |
OVFF - Overflow Flag 0b0..No overflow has occurred since the last time the flag was cleared. 0b1..At least one FIFO overflow has occurred since the last time the flag was cleared.
| #define DAC_CR_SWMD | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_SWMD_SHIFT)) & DAC_CR_SWMD_MASK) |
SWMD - DAC FIFO Mode Select 0b0..Normal mode 0b1..Swing back mode
| #define DAC_CR_SWRST | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_SWRST_SHIFT)) & DAC_CR_SWRST_MASK) |
SWRST - Software reset
| #define DAC_CR_SWTRG | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_SWTRG_SHIFT)) & DAC_CR_SWTRG_MASK) |
SWTRG - DAC Software Trigger 0b0..The DAC soft trigger is not valid. 0b1..The DAC soft trigger is valid.
| #define DAC_CR_TRGSEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_TRGSEL_SHIFT)) & DAC_CR_TRGSEL_MASK) |
TRGSEL - DAC Trigger Select 0b0..The DAC hardware trigger is selected. 0b1..The DAC software trigger is selected.
| #define DAC_CR_UDFF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_UDFF_SHIFT)) & DAC_CR_UDFF_MASK) |
UDFF - Underflow Flag 0b0..No underflow has occurred since the last time the flag was cleared. 0b1..At least one trigger underflow has occurred since the last time the flag was cleared.
| #define DAC_CR_UVIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_UVIE_SHIFT)) & DAC_CR_UVIE_MASK) |
UVIE - Underflow and overflow interrupt enable 0b0..Underflow and overflow interrupt is disabled. 0b1..Underflow and overflow interrupt is enabled.
| #define DAC_CR_WMF | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_WMF_SHIFT)) & DAC_CR_WMF_MASK) |
WMF - FIFO Watermark Status Flag 0b0..The DAC buffer read pointer has not reached the watermark level. 0b1..The DAC buffer read pointer has reached the watermark level.
| #define DAC_CR_WML | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_WML_SHIFT)) & DAC_CR_WML_MASK) |
WML - Watermark Level Select
| #define DAC_CR_WTMIE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_CR_WTMIE_SHIFT)) & DAC_CR_WTMIE_MASK) |
WTMIE - Watermark Interrupt Enable 0b0..Watermark interrupt is disabled. 0b1..Watermark interrupt is enabled.
| #define DAC_DATA_DATA0 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_DATA_DATA0_SHIFT)) & DAC_DATA_DATA0_MASK) |
DATA0 - FIFO DATA0
DATA0 - FIFO DATA0
| #define DAC_PARAM_FIFOSZ | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_PARAM_FIFOSZ_SHIFT)) & DAC_PARAM_FIFOSZ_MASK) |
FIFOSZ - FIFO size 0b000..FIFO depth is 2 0b001..FIFO depth is 4 0b010..FIFO depth is 8 0b011..FIFO depth is 16 0b100..FIFO depth is 32 0b101..FIFO depth is 64 0b110..FIFO depth is 128 0b111..FIFO depth is 256
| #define DAC_PTR_DACRFP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_PTR_DACRFP_SHIFT)) & DAC_PTR_DACRFP_MASK) |
DACRFP - DACRFP
DACRFP - DACRFP
| #define DAC_PTR_DACWFP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_PTR_DACWFP_SHIFT)) & DAC_PTR_DACWFP_MASK) |
DACWFP - DACWFP
DACWFP - DACWFP
| #define DAC_VERID_FEATURE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_VERID_FEATURE_SHIFT)) & DAC_VERID_FEATURE_MASK) |
FEATURE - Feature Identification Number 0b0000000000000000..Standard feature set 0b0000000000000001..C40 feature set 0b0000000000000010..5V DAC feature set 0b0000000000000100..ADC BIST feature set
| #define DAC_VERID_MAJOR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_VERID_MAJOR_SHIFT)) & DAC_VERID_MAJOR_MASK) |
MAJOR - Major version number
| #define DAC_VERID_MINOR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DAC_VERID_MINOR_SHIFT)) & DAC_VERID_MINOR_MASK) |
MINOR - Minor version number
