RTEMS 6.1-rc8
This source file contains the implementation of rtems_configuration_get_maximum_barriers(), rtems_configuration_get_maximum_extensions(), rtems_configuration_get_maximum_message_queues(), rtems_configuration_get_maximum_partitions(), rtems_configuration_get_maximum_periods(), rtems_configuration_get_maximum_ports(), rtems_configuration_get_maximum_regions(), rtems_configuration_get_maximum_semaphores(), rtems_configuration_get_maximum_tasks(), and rtems_configuration_get_maximum_timers(). More...
#include <rtems/config.h>#include <rtems/extensionimpl.h>#include <rtems/rtems/barrierimpl.h>#include <rtems/rtems/dpmemimpl.h>#include <rtems/rtems/messageimpl.h>#include <rtems/rtems/partimpl.h>#include <rtems/rtems/ratemonimpl.h>#include <rtems/rtems/regionimpl.h>#include <rtems/rtems/semimpl.h>#include <rtems/rtems/tasksimpl.h>#include <rtems/rtems/timerimpl.h>#include <rtems/score/objectimpl.h>Functions | |
| uint32_t | rtems_configuration_get_maximum_barriers (void) |
| Gets the resource number of Barrier Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_extensions (void) |
| Gets the resource number of User Extensions Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_message_queues (void) |
| Gets the resource number of Message Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_partitions (void) |
| Gets the resource number of Partition Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_periods (void) |
| Gets the resource number of Rate-Monotonic Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_ports (void) |
| Gets the resource number of Dual-Ported Memory Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_regions (void) |
| Gets the resource number of Region Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_semaphores (void) |
| Gets the resource number of Semaphore Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_timers (void) |
| Gets the resource number of Timer Manager objects configured for this application. | |
| uint32_t | rtems_configuration_get_maximum_tasks (void) |
| Gets the resource number of Task Manager objects configured for this application. | |
