RTEMS 6.1-rc8
This source file contains the implementation of _Base64_Encode() and _Base64url_Encode(). More...
#include <rtems/base64.h>Functions | |
| int | _Base64_Encode (IO_Put_char put_char, void *arg, const void *src, size_t srclen, const char *wordbreak, int wordlen) |
| Outputs the source buffer in base64 encoding. | |
| int | _Base64url_Encode (IO_Put_char put_char, void *arg, const void *src, size_t srclen, const char *wordbreak, int wordlen) |
| Outputs the source buffer in base64url encoding. | |
| const uint8_t | _Base64_Encoding [64] |
| Maps a 6-bit integer to the corresponding base64 encoding. | |
| const uint8_t | _Base64url_Encoding [64] |
| Maps a 6-bit integer to the corresponding base64url encoding. | |
