RTEMS 6.1-rc8
This header file provides Classic API directive attributes. More...
#include <stdint.h>Go to the source code of this file.
| #define | RTEMS_APPLICATION_TASK 0x00000000 |
| This attribute constant indicates that the Classic API task created by rtems_task_create() or rtems_task_construct() shall be an application task. | |
| #define | RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000200 |
| This attribute constant indicates that the Classic API barrier created by rtems_barrier_create() shall use the automatic release protocol. | |
| #define | RTEMS_BARRIER_MANUAL_RELEASE 0x00000000 |
| This attribute constant indicates that the Classic API barrier created by rtems_barrier_create() shall use the manual release protocol. | |
| #define | RTEMS_BINARY_SEMAPHORE 0x00000010 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() shall be a proper binary semaphore or mutex. | |
| #define | RTEMS_COUNTING_SEMAPHORE 0x00000000 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() shall be a counting semaphore. | |
| #define | RTEMS_DEFAULT_ATTRIBUTES 0x00000000 |
| This attribute constant represents the default attribute set. | |
| #define | RTEMS_FIFO 0x00000000 |
| This attribute constant indicates that the Classic API object shall manage blocking tasks using the FIFO discipline. | |
| #define | RTEMS_FLOATING_POINT 0x00000001 |
| This attribute constant indicates that the Classic API task created by rtems_task_create() or rtems_task_construct() shall be able to use the floating point hardware. | |
| #define | RTEMS_GLOBAL 0x00000002 |
| This attribute constant indicates that the Classic API object shall be a global resource in a multiprocessing network. | |
| #define | RTEMS_INHERIT_PRIORITY 0x00000040 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() shall use the Priority Inheritance Protocol. | |
| #define | RTEMS_LOCAL 0x00000000 |
| This attribute constant indicates that the Classic API object shall be a local resource in a multiprocessing network. | |
| #define | RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() shall use the Multiprocessor Resource Sharing Protocol. | |
| #define | RTEMS_NO_FLOATING_POINT 0x00000000 |
| This attribute constant indicates that the Classic API task created by rtems_task_create() or rtems_task_construct() will not use the floating point hardware. | |
| #define | RTEMS_NO_INHERIT_PRIORITY 0x00000000 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() will not use the Priority Inheritance Protocol. | |
| #define | RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() will not use the Multiprocessor Resource Sharing Protocol. | |
| #define | RTEMS_NO_PRIORITY_CEILING 0x00000000 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() will not use the Priority Ceiling Protocol. | |
| #define | RTEMS_PRIORITY 0x00000004 |
| This attribute constant indicates that the Classic API object shall manage blocking tasks using the task priority discipline. | |
| #define | RTEMS_PRIORITY_CEILING 0x00000080 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() shall use the Priority Ceiling Protocol. | |
| #define | RTEMS_SEMAPHORE_CLASS 0x00000030 |
| This attribute constant represents the mask of bits associated with the Classic API semaphore classes RTEMS_BINARY_SEMAPHORE, RTEMS_COUNTING_SEMAPHORE, and RTEMS_SIMPLE_BINARY_SEMAPHORE. | |
| #define | RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020 |
| This attribute constant indicates that the Classic API semaphore created by rtems_semaphore_create() shall be a simple binary semaphore. | |
| #define | RTEMS_SYSTEM_TASK 0x00008000 |
| This attribute constant indicates that the Classic API task created by rtems_task_create() or rtems_task_construct() shall be a system task. | |
Typedefs | |
| typedef uint32_t | rtems_attribute |
| This type represents Classic API attributes. | |
