RTEMS 6.1-rc8
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the GICv3. More...
| #define | PRIORITY_DEFAULT 127 |
| #define | MPIDR_AFFINITY2(val) BSP_FLD64(val, 16, 23) |
| #define | MPIDR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 16, 23) |
| #define | MPIDR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23) |
| #define | MPIDR_AFFINITY1(val) BSP_FLD64(val, 8, 15) |
| #define | MPIDR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 8, 15) |
| #define | MPIDR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 8, 15) |
| #define | MPIDR_AFFINITY0(val) BSP_FLD64(val, 0, 7) |
| #define | MPIDR_AFFINITY0_GET(reg) BSP_FLD64GET(reg, 0, 7) |
| #define | MPIDR_AFFINITY0_SET(reg, val) BSP_FLD64SET(reg, val, 0, 7) |
| #define | ICC_SGIR_AFFINITY3(val) BSP_FLD64(val, 48, 55) |
| #define | ICC_SGIR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 48, 55) |
| #define | ICC_SGIR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 48, 55) |
| #define | ICC_SGIR_IRM BSP_BIT32(40) |
| #define | ICC_SGIR_AFFINITY2(val) BSP_FLD64(val, 32, 39) |
| #define | ICC_SGIR_AFFINITY2_GET(reg) BSP_FLD64GET(reg, 32, 39) |
| #define | ICC_SGIR_AFFINITY2_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39) |
| #define | ICC_SGIR_INTID(val) BSP_FLD64(val, 24, 27) |
| #define | ICC_SGIR_INTID_GET(reg) BSP_FLD64GET(reg, 24, 27) |
| #define | ICC_SGIR_INTID_SET(reg, val) BSP_FLD64SET(reg, val, 24, 27) |
| #define | ICC_SGIR_AFFINITY1(val) BSP_FLD64(val, 16, 23) |
| #define | ICC_SGIR_AFFINITY1_GET(reg) BSP_FLD64GET(reg, 16, 23) |
| #define | ICC_SGIR_AFFINITY1_SET(reg, val) BSP_FLD64SET(reg, val, 16, 23) |
| #define | ICC_SGIR_CPU_TARGET_LIST(val) BSP_FLD64(val, 0, 15) |
| #define | ICC_SGIR_CPU_TARGET_LIST_GET(reg) BSP_FLD64GET(reg, 0, 15) |
| #define | ICC_SGIR_CPU_TARGET_LIST_SET(reg, val) BSP_FLD64SET(reg, val, 0, 15) |
| #define | ICC_IGRPEN0_EL1 "S3_0_C12_C12_6, %0" |
| #define | ICC_IGRPEN1_EL1 "S3_0_C12_C12_7, %0" |
| #define | ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0" |
| #define | ICC_IGRPEN0 ICC_IGRPEN0_EL1 |
| #define | ICC_IGRPEN1 ICC_IGRPEN1_EL1 |
| #define | ICC_PMR "S3_0_C4_C6_0, %0" |
| #define | ICC_EOIR1 "S3_0_C12_C12_1, %0" |
| #define | ICC_SRE "S3_0_C12_C12_5, %0" |
| #define | ICC_BPR0 "S3_0_C12_C8_3, %0" |
| #define | ICC_BPR1 "S3_0_C12_C12_3, %0" |
| #define | ICC_CTLR "S3_0_C12_C12_4, %0" |
| #define | ICC_IAR1 "%0, S3_0_C12_C12_0" |
| #define | MPIDR "%0, mpidr_el1" |
| #define | MPIDR_AFFINITY3(val) BSP_FLD64(val, 32, 39) |
| #define | MPIDR_AFFINITY3_GET(reg) BSP_FLD64GET(reg, 32, 39) |
| #define | MPIDR_AFFINITY3_SET(reg, val) BSP_FLD64SET(reg, val, 32, 39) |
| #define | ICC_SGI1 "S3_0_C12_C11_5, %0" |
| #define | WRITE64_SR(SR_NAME, VALUE) __asm__ volatile("msr " SR_NAME " \n" : : "r" (VALUE) ); |
| #define | WRITE_SR(SR_NAME, VALUE) WRITE64_SR(SR_NAME, VALUE) |
| #define | READ_SR(SR_NAME) |
