RTEMS 6.1-rc7
This source file contains the implementation of support functions for the validation test cases. More...
#include "tx-support.h"
#include "ts-config.h"
#include <rtems/test.h>
#include <rtems/score/smpimpl.h>
rtems_id | DoCreateTask (rtems_name name, rtems_task_priority priority) |
void | StartTask (rtems_id id, rtems_task_entry entry, void *arg) |
void | DeleteTask (rtems_id id) |
void | SuspendTask (rtems_id id) |
void | SuspendSelf (void) |
void | ResumeTask (rtems_id id) |
bool | IsTaskSuspended (rtems_id id) |
rtems_event_set | QueryPendingEvents (void) |
rtems_event_set | PollAnyEvents (void) |
rtems_event_set | ReceiveAnyEvents (void) |
rtems_event_set | ReceiveAnyEventsTimed (rtems_interval ticks) |
void | ReceiveAllEvents (rtems_event_set events) |
void | SendEvents (rtems_id id, rtems_event_set events) |
rtems_mode | GetMode (void) |
rtems_mode | SetMode (rtems_mode set, rtems_mode mask) |
rtems_task_priority | GetPriority (rtems_id id) |
rtems_task_priority | GetPriorityByScheduler (rtems_id task_id, rtems_id scheduler_id) |
rtems_task_priority | SetPriority (rtems_id id, rtems_task_priority priority) |
rtems_task_priority | GetSelfPriority (void) |
rtems_task_priority | SetSelfPriority (rtems_task_priority priority) |
rtems_task_priority | SetSelfPriorityNoYield (rtems_task_priority priority) |
rtems_id | GetScheduler (rtems_id id) |
rtems_id | GetSelfScheduler (void) |
void | SetScheduler (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority) |
void | SetSelfScheduler (rtems_id scheduler_id, rtems_task_priority priority) |
void | GetAffinity (rtems_id id, cpu_set_t *set) |
void | GetSelfAffinity (cpu_set_t *set) |
void | SetAffinity (rtems_id id, const cpu_set_t *set) |
void | SetSelfAffinity (const cpu_set_t *set) |
void | SetAffinityOne (rtems_id id, uint32_t cpu_index) |
void | SetSelfAffinityOne (uint32_t cpu_index) |
void | SetAffinityAll (rtems_id id) |
void | SetSelfAffinityAll (void) |
void | Yield (void) |
void | YieldTask (rtems_id id) |
void | AddProcessor (rtems_id scheduler_id, uint32_t cpu_index) |
void | RemoveProcessor (rtems_id scheduler_id, uint32_t cpu_index) |
rtems_id | CreateMutex (void) |
rtems_id | CreateMutexNoProtocol (void) |
rtems_id | CreateMutexFIFO (void) |
void | DeleteMutex (rtems_id id) |
bool | IsMutexOwner (rtems_id id) |
void | ObtainMutex (rtems_id id) |
void | ObtainMutexTimed (rtems_id id, rtems_interval ticks) |
void | ObtainMutexDeadlock (rtems_id id) |
void | ReleaseMutex (rtems_id id) |
Thread_queue_Queue * | GetMutexThreadQueue (rtems_id id) |
void | RestoreRunnerASR (void) |
void | RestoreRunnerMode (void) |
void | RestoreRunnerPriority (void) |
void | RestoreRunnerScheduler (void) |
Thread_Control * | GetThread (rtems_id id) |
Thread_Control * | GetExecuting (void) |
void | KillZombies (void) |
void | WaitForExecutionStop (rtems_id task_id) |
void | WaitForIntendToBlock (rtems_id task_id) |
void | WaitForHeir (uint32_t cpu_index, rtems_id task_id) |
void | WaitForNextTask (uint32_t cpu_index, rtems_id task_id) |
void | GetTaskTimerInfo (rtems_id id, TaskTimerInfo *info) |
void | GetTaskTimerInfoByThread (struct _Thread_Control *thread, TaskTimerInfo *info) |
void | ClockTick (void) |
void | FinalClockTick (void) |
Simulates a clock tick with the final expire time point of UINT64_MAX for all clocks. | |
void | FatalInitialExtension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
void | SetFatalHandler (FatalHandler fatal, void *arg) |
void | SetTaskSwitchExtension (rtems_task_switch_extension task_switch) |
void | ClearExtensionCalls (ExtensionCalls *calls) |
void | CopyExtensionCalls (const ExtensionCalls *from, ExtensionCalls *to) |
void | StartDelayThreadDispatch (uint32_t cpu_index) |
void | StopDelayThreadDispatch (uint32_t cpu_index) |
bool | AreInterruptsEnabled (void) |
bool | IsWhiteSpaceOnly (const char *s) |
bool | IsEqualIgnoreWhiteSpace (const char *a, const char *b) |
