RTEMS 6.1-rc7
rtems_shell_env_t Struct Reference
#include <shell.h>
rtems_name magic
bool managed
const char * devname
const char * taskname
bool exit_shell
bool forever
int * exit_code
bool exit_on_error
bool echo
char cwd [256]
const char * input
const char * output
bool output_append
FILE * parent_stdin
FILE * parent_stdout
FILE * parent_stderr
rtems_id wake_on_end
rtems_shell_login_check_t login_check
uid_t uid
 The real and effective UID of the shell task in case no login check is present.
gid_t gid
 The real and effective GID of the shell task in case no login check is present.
Private environment associated with each shell instance.
Field Documentation
◆ magic
rtems_name rtems_shell_env_t::magic
'S','E','N','V': Shell Environment
