RTEMS 6.1-rc7
console-config.c File Reference
This source file contains NOEL-V/APBUART definitions of BSP_output_char_function_type and :: BSP_output_char and an implementation of console_initialize(). More...
#include <rtems/bspIo.h>
#include <rtems/console.h>
#include <rtems/sysinit.h>
#include <rtems/termiostypes.h>
#include <bsp/fatal.h>
#include <bsp/fdt.h>
#include <bsp/irq.h>
#include <bsp/riscv.h>
#include <libfdt.h>
#include <grlib/apbuart.h>
#include <grlib/apbuart_termios.h>
#define RISCV_CONSOLE_IS_COMPATIBLE(actual, actual_len, desired)
rtems_status_code console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console initialization entry point.
 RTEMS_SYSINIT_ITEM (riscv_console_probe, RTEMS_SYSINIT_BSP_START, RTEMS_SYSINIT_ORDER_LAST_BUT_5)
BSP_output_char_function_type BSP_output_char = riscv_output_char_init
 This function pointer references the kernel character output implementation.
BSP_polling_getchar_function_type BSP_poll_char = NULL
 This function pointer may reference the kernel character input implementation.
◆ RISCV_CONSOLE_IS_COMPATIBLE
#define RISCV_CONSOLE_IS_COMPATIBLE (   actual,
  actual_len,
  desired
Value:
(actual_len == sizeof(desired) \
&& memcmp(actual, desired, sizeof(desired) - 1) == 0)
◆ console_initialize()
rtems_status_code console_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the console device driver.
Parameters
[in]majoris the device driver major number.
[in]minoris the device driver minor number.
[in]argis the parameters to this call.
Return values
RTEMS_SUCCESSFULThe device driver is successfully initialized.
Initialize all serial drivers specified in driver_context_table
Parameters
[in]major
[in]minor
[in]arg
Return values
RTEMS_SUCCESSFULInitialization completed
This routine initializes the console IO driver.
Parameters
Parameters
majormajor number
minorminor number
Output parameters: NONE
Returns
void
Variable Documentation
◆ context
unsigned context
Context identifier.
Context register selection.
