RTEMS 6.1-rc7
mscan-base.h File Reference
MSCAN register definitions and support functions. More...
#include <stdbool.h>
#include <bsp/mpc5200.h>
struct  mscan_context
 MSCAN context that has to be saved throughout the initialization mode. More...
#define MSCAN_BIT_RATE_MIN   10000
#define MSCAN_BIT_RATE_MAX   1000000
#define MSCAN_BIT_RATE_DEFAULT   125000
#define MSCAN_FILTER_NUMBER_MIN   0
#define MSCAN_FILTER_NUMBER_2   2
#define MSCAN_FILTER_NUMBER_4   4
#define MSCAN_FILTER_NUMBER_MAX   8
#define MSCAN_FILTER_ID_DEFAULT   0U
#define MSCAN_FILTER_MASK_DEFAULT   0xffffffffU
#define MSCAN_TRANSMIT_BUFFER_NUMBER   3
MSCAN Control Register 0 (CANCTL0)
#define CTL0_RXFRM   (1 << 7)
#define CTL0_RXACT   (1 << 6)
#define CTL0_CSWAI   (1 << 5)
#define CTL0_SYNCH   (1 << 4)
#define CTL0_TIME   (1 << 3)
#define CTL0_WUPE   (1 << 2)
#define CTL0_SLPRQ   (1 << 1)
#define CTL0_INITRQ   (1 << 0)
MSCAN Control Register 1 (CANCTL1)
#define CTL1_CANE   (1 << 7)
#define CTL1_CLKSRC   (1 << 6)
#define CTL1_LOOPB   (1 << 5)
#define CTL1_LISTEN   (1 << 4)
#define CTL1_WUPM   (1 << 2)
#define CTL1_SLPAK   (1 << 1)
#define CTL1_INITAK   (1 << 0)
MSCAN Bus Timing Register 0 (CANBTR0)
#define BTR0_SJW_MASK   0xc0
#define BTR0_BRP_MASK   0x3f
#define BTR0_SJW(btr0)   ((btr0) << 6)
#define BTR0_BRP(btr0)   ((btr0) << 0)
#define BTR0_GET_SJW(btr0)   (((btr0) & BTR0_SJW_MASK) >> 6)
#define BTR0_GET_BRP(btr0)   (((btr0) & BTR0_BRP_MASK) >> 0)
MSCAN Bus Timing Register 1 (CANBTR1)
#define BTR1_SAMP_MASK   0x80
#define BTR1_TSEG1_MASK   0x0f
#define BTR1_TSEG2_MASK   0x70
#define BTR1_SAMP   (1 << 7)
#define BTR1_TSEG1(btr1)   ((btr1) << 0)
#define BTR1_TSEG2(btr1)   ((btr1) << 4)
#define BTR1_GET_TSEG1(btr0)   (((btr0) & BTR1_TSEG1_MASK) >> 0)
#define BTR1_GET_TSEG2(btr0)   (((btr0) & BTR1_TSEG2_MASK) >> 4)
MSCAN Receiver Flag Register (CANRFLG)
#define RFLG_WUPIF   (1 << 7)
#define RFLG_CSCIF   (1 << 6)
#define RFLG_RSTAT_MASK   (3 << 4)
#define RFLG_RSTAT_OK   (0 << 4)
#define RFLG_RSTAT_WRN   (1 << 4)
#define RFLG_RSTAT_ERR   (2 << 4)
#define RFLG_RSTAT_OFF   (3 << 4)
#define RFLG_TSTAT_MASK   (3 << 2)
#define RFLG_TSTAT_OK   (0 << 2)
#define RFLG_TSTAT_WRN   (1 << 2)
#define RFLG_TSTAT_ERR   (2 << 2)
#define RFLG_TSTAT_OFF   (3 << 2)
#define RFLG_OVRIF   (1 << 1)
#define RFLG_RXF   (1 << 0)
#define RFLG_GET_RX_STATE(rflg)   (((rflg) >> 4) & 0x03)
#define RFLG_GET_TX_STATE(rflg)   (((rflg) >> 2) & 0x03)
MSCAN Receiver Interrupt Enable Register (CANRIER)
#define RIER_WUPIE   (1 << 7)
#define RIER_CSCIE   (1 << 6)
#define RIER_RSTAT(rier)   ((rier) << 4)
#define RIER_TSTAT(rier)   ((rier) << 2)
#define RIER_OVRIE   (1 << 1)
#define RIER_RXFIE   (1 << 0)
MSCAN Transmitter Flag Register (CANTFLG)
#define TFLG_TXE2   (1 << 2)
#define TFLG_TXE1   (1 << 1)
#define TFLG_TXE0   (1 << 0)
MSCAN Transmitter Interrupt Enable Register (CANTIER)
#define TIER_TXEI2   (1 << 2)
#define TIER_TXEI1   (1 << 1)
#define TIER_TXEI0   (1 << 0)
MSCAN Transmitter Message Abort Request (CANTARQ)
#define TARQ_ABTRQ2   (1 << 2)
#define TARQ_ABTRQ1   (1 << 1)
#define TARQ_ABTRQ0   (1 << 0)
MSCAN Transmitter Message Abort Acknoledge (CANTAAK)
#define TAAK_ABTRQ2   (1 << 2)
#define TAAK_ABTRQ1   (1 << 1)
#define TAAK_ABTRQ0   (1 << 0)
MSCAN Transmit Buffer Selection (CANBSEL)
#define BSEL_TX2   (1 << 2)
#define BSEL_TX1   (1 << 1)
#define BSEL_TX0   (1 << 0)
MSCAN ID Acceptance Control Register (CANIDAC)
#define IDAC_IDAM1   (1 << 5)
#define IDAC_IDAM0   (1 << 4)
#define IDAC_IDAM   (IDAC_IDAM1 | IDAC_IDAM0)
#define IDAC_IDHIT(idac)   ((idac) & 0x7)
typedef struct mpc5200_mscan mscan
 MSCAN registers.
bool mscan_enable (volatile mscan *m, unsigned bit_rate)
 Enables and initializes the MSCAN module m.
void mscan_disable (volatile mscan *m)
 Disables the MSCAN module m.
void mscan_interrupts_disable (volatile mscan *m)
 Disables all interrupts for the MSCAN module m.
bool mscan_set_bit_rate (volatile mscan *m, unsigned bit_rate)
 Sets the bit rate for the MSCAN module m to can_bit_rate in [bits/s].
void mscan_initialization_mode_enter (volatile mscan *m, mscan_context *context)
 Enter initialization mode for the MSCAN module m.
void mscan_initialization_mode_leave (volatile mscan *m, const mscan_context *context)
 Leave initialization mode for the MSCAN module m.
void mscan_sleep_mode_enter (volatile mscan *m)
 Enter sleep mode for the MSCAN module m.
void mscan_sleep_mode_leave (volatile mscan *m)
 Leave sleep mode for the MSCAN module m.
volatile uint8_t * mscan_id_acceptance_register (volatile mscan *m, unsigned i)
 Returns the address of the CANIDAR register with index i of the MSCAN module m.
volatile uint8_t * mscan_id_mask_register (volatile mscan *m, unsigned i)
 Returns the address of the CANIDMR register with index i of the MSCAN module m.
unsigned mscan_filter_number (volatile mscan *m)
 Returns the number of active filters of the MSCAN module m.
bool mscan_set_filter_number (volatile mscan *m, unsigned number)
 Sets the number of active filters of the MSCAN module m to number and returns true if number is valid.
bool mscan_filter_operation (volatile mscan *m, bool set, unsigned index, uint32_t *id, uint32_t *mask)
 Sets or gets the filter ID and mask in id and mask depending on set of MSCAN module m. The filter is selected by the value of index.
void mscan_filter_clear (volatile mscan *m)
 Sets the filter ID and mask registers of the MSCAN module m to default values.
void mscan_get_error_counters (volatile mscan *m, unsigned *rec, unsigned *tec)
 Returns the receiver and transmitter error counter values in rec and tec of MSCAN module m.
